Old August 9th, 2013, 08:56 PM   #1
linkinpark9812
Motorcycle(s): Black 2012 Ninja 250R
Embedded Computer Display System
MOD: I meant to post in 2012 ninja 250 farkles. Please move. Sorry about that.
Custom embedded system. Built and programmed by me. Uses two PIC micro controllers and some other accessories ICs.
Shows time, date, gear, status of some accessories. (Fuse Box On/Off, Aux LEDs On/Off, Running Lights On, and External Horn On/Off). Also has an "animation/notification" window. Will show animated turn signal, high beams on/off, etc.
Also shows information such as gyroscope (was going to be used for lean angle, not working out quite well), if the bike is centered, GPS info, Fuel info and MPG, some other info, etc.
Shows outside temp and compass. You can log your trip on it and download it later to the computer and see it on a map (that part was actually a module so I didn't code that, but I did code the interface to it).
Last futzed with by linkinpark9812; August 9th, 2013 at 10:00 PM.
linkinpark9812 is offline   Reply With Quote
Old August 9th, 2013, 08:58 PM   #2
linkinpark9812
A little messy, but everything beyond that is loomed. The blue wires in the top right hand corner actually have 4 wires in each, so that made the mess that much less. A lot of the wiring that runs back and forth on the bike is on the other side (hence all the wiring going to that side) and that is all loomed.
Old August 9th, 2013, 08:59 PM   #3
Very cool!
Old August 9th, 2013, 09:03 PM   #4
linkinpark9812
Step by step of board 1 of 2. In the last pic, you can also see the completed board 2 in the upper right hand corner.
board 1 is the main board, with the main micro-controller, some memory, inputs/outputs to bike, stuff like that. board 2 is mainly sensors (GPS, bluetooth, accelerometer, gyroscope, some I/O as well).
Old August 9th, 2013, 09:38 PM   #5
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
See @CycleCam303 my bike isn't the bigger wiring cluster**** of all time.
Old August 9th, 2013, 09:39 PM   #6
nice! how are you doing the gear? ratio between speed and rpm? or do you have switches on the mechenism?
Old August 9th, 2013, 09:57 PM   #7
linkinpark9812
hall sensors which detects a magnetic field (aka a magnet) which is on the gear shifter.
Old August 9th, 2013, 09:59 PM   #8
linkinpark9812
Ya here are the looms of wire on the left side of the bike.
Old August 9th, 2013, 10:12 PM   #9
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Wow that's great, did u already think about sales?
Old August 10th, 2013, 04:22 AM   #10
That is an awesome display! Great work.
Old August 19th, 2013, 03:37 PM   #11
linkinpark9812
Old August 19th, 2013, 03:39 PM   #12
That's pretty cool!
Old August 19th, 2013, 03:44 PM   #13
/merged
Old January 6th, 2014, 06:04 PM   #14
headshrink
headshrink's Avatar
Could you share the source & model or P/N of those sensors? I've been meaning to replace the magnetic switches on my cheapo Chinese-made gear indicator.
Old January 6th, 2014, 06:13 PM   #15
linkinpark9812
http://www.digikey.com/product-detai...02-A-ND/565511
Pulls down to ground when activated.
Old January 6th, 2014, 06:41 PM   #16
headshrink
headshrink's Avatar
Thanks!
My existing one is really more like this one: http://www.digikey.com/product-detai...0-010-ND/43977
I assumed they were the same type of thing. Will your type not work as a replacement? Mine are way too touchy and extremely difficult to adjust.
Old January 7th, 2014, 06:28 PM   #17
leed
leed's Avatar
Motorcycle(s): Time will tell
You should run a temp sensor to see what the temperature is beneath your jacket!
Looks great -- can't say I'd ever really need all that information though, but my bike only has speed and miles at the moment
Old March 22nd, 2014, 06:34 PM   #18
larry502
Motorcycle(s): ninja 250r 09
very cool. I do still with ardiuno but haven't done anything like this.
larry502 is offline   Reply With Quote
Old March 30th, 2014, 12:57 AM   #19
ninja250r81
ninja250r81's Avatar
very interested in this
Old March 30th, 2014, 09:50 AM   #20
JohnnyBravo
JohnnyBravo's Avatar
That's cool, way to many bells an whistles for my taste, my bike came stock with all the stuff I care about ATM
Old March 31st, 2014, 01:03 AM   #21
ninja250r81
A and B trip meter
Instant fuel
Average fuel
Coolant temperature
Outside temperature
Option
Air Fuel Ratio via Wideband Sensor
Exhaust Temperature
Gear Select
Old April 10th, 2014, 01:20 PM   #22
auntymunga
auntymunga's Avatar
Motorcycle(s): 2008 250r Ninja
I'd buy this. Hint hint
auntymunga is offline   Reply With Quote
Old April 10th, 2014, 11:30 PM   #23
linkinpark9812
Got the new one up and running for the most part, just need to test/calibrate the sensors!
Old April 11th, 2014, 06:55 PM   #24
ninja250r81
Sweet
Please Critique My Riding (Video Embedded) jeffb502 Riding Skills 47 April 23rd, 2014 03:28 PM
YouTube Embedded videos NevadaWolf Help 2 June 23rd, 2013 12:17 AM
Best embedded code comment on record Alex Off-Topic 14 April 4th, 2013 01:34 PM
Question for you computer geeks… I mean… computer experts THE BIG SITT Off-Topic 10 January 28th, 2012 12:18 AM
[visordown.com] - First Look: Transparentius - road display system Ninjette Newsbot Motorcycling News 0 January 4th, 2010 02:50 PM
