Old February 28th, 2016, 10:48 AM   #1
Panda
not an actual panda
Rear brake dragging
When I lift the rear break pedal all the way up the rear brake is still dragging lightly on the disk.
I'm using an aftermarket rear set that is probably contributing to the problem.
Is there a way to adjust the rear brake cable so it I can get the pads away from the disk?
Old February 28th, 2016, 12:45 PM   #2
Ghostt
Ghostt's Avatar
No cable to adjust, it's hydraulic.
Stupid question time,
When you say drag, how much? And how do you know it's dragging?
Is the pedal putting some pressure on the master cylinder? If not have you serviced your caliper? Grease the slider pins? A caliper and/or slider pins can cause drag if it's been neglected.
violente et ignorantia
ZX-2R BLOG
Old February 28th, 2016, 12:52 PM   #3
Using aftermarket rearsets doesn't change how the rear brake operates when adjusted properly. http://faq.ninja250.org/wiki/How_do_...brake_lever%3F
Otherwise, sounds like it's time to clean the caliper.
Old February 28th, 2016, 01:34 PM   #4
MrAtom
MOTM - July '15
fwiw you should clean your brakes/grease the slider pins every time you change your pads.
Old February 29th, 2016, 07:35 AM   #5
Panda
not an actual panda
Originally Posted by Ghostt View Post
Is the pedal putting some pressure on the master cylinder? .
The pedal wasn't fully returning to the disengaged position. I dropped the bike on the right hand side and pranged the rear brake lever.
After reading your post and learning that there wasn't a cable adjustment I very carefully readjusted the rear brake lever. (I used a rubber mallet and whacked the rear brake lever up. It ended up moving about quarter to half an inch up.) This fully disengaged the rear brake and the wheel rotates normally now.
When it gets warmer and I feel more ambitious I'm going to pull the rearset off and reinstall the OEM one. I feel like the rearset isn't trued up anymore.
Thanks for the help all.
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. N-m 1986 - 2007 Ninja 250R Tech Talk 14 July 17th, 2014 04:13 AM
Front brake dragging Tigerpaw 2013 - 2017 Ninja 300 Tech Talk 8 September 18th, 2013 04:16 AM
Brake dragging issue n4mwd 1986 - 2007 Ninja 250R Tech Talk 19 December 30th, 2011 08:11 PM
