Old March 10th, 2014, 04:00 AM   #1
Josh_kcco
Josh_kcco's Avatar
Motorcycle(s): '04 Ninja 250R
How many of you (centerstand)
Have it actually use your center stand?
Been debating to myself if I should take it off or not.
Josh_kcco is offline   Reply With Quote
Old March 10th, 2014, 04:08 AM   #2
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Leave it on as it's miraculously useful when you want to clean your chain, swap a sprocket, or change your oil, etc.
Old March 10th, 2014, 05:08 AM   #3
Originally Posted by Josh_kcco View Post
Have it actually use your center stand?.............
I never use the side stand, as I love the center one.
Old March 10th, 2014, 05:15 AM   #4
Take it off, see if you like it. You can always put it back on. The center stand was one of the first things to go on my pregen but I have rear stands as well.
Old March 10th, 2014, 06:27 AM   #5
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
As both a former pregen and now newgen owner I can say the two biggest changes I miss are the reserve and the centerstand.
Used it heavily due to limited storage space and during minor upkeep.
<-- Linky
Old March 10th, 2014, 06:38 AM   #6
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Centerstand allows me to park bike between cars in garage. Centerstand is very useful for adjusting/cleaning chain and removing rear wheel.
Old March 10th, 2014, 06:47 AM   #7
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Someone stole mine and replaced it with a side stand! It would be more useful having a center stand then a side one.
Old March 10th, 2014, 08:14 AM   #8
Rogue
Hooligan
Rogue's Avatar
Motorcycle(s): 2013 Ninja EX300
I would love to have a center stand on mine. They're so useful for quick maintenance and storage - not to mention I wouldn't keep tripping over the rear stand every time I walk past the bike in the garage.
Qui patiens est, teres. Teres est, ieiunare. | Twitter: @Rogue_300
Last futzed with by Rogue; March 10th, 2014 at 01:09 PM. Reason: capitalization
Rogue is offline   Reply With Quote
Old March 10th, 2014, 08:16 AM   #9
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
As with the above mentioned uses for general maintenance, I will be replacing fork seals and bushes, when the parts turn up, and the centre stand will be most useful for that.
baxtc1 is offline   Reply With Quote
Old March 10th, 2014, 09:28 AM   #10
EMSRacer07
EMSRacer07's Avatar
Yea the maintenance assist with the centerstand is a plus. I got rid of the side stand and just use the centerstand.
Old March 10th, 2014, 10:50 AM   #11
Josh_kcco
Josh_kcco's Avatar
the only time I use the center stand is when I park in the parking lot of my work. or when in the garage for maintained but I bought a rear swing arm stand..
maybe the life of the indecisive....
ill just remove it and see if I like it. im just a tad lazy when it comes to things like this..
Old March 10th, 2014, 11:45 AM   #12
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I use my EX500's centerstand every time I get gas, in addition to all the other uses that have been posted.
Old March 10th, 2014, 01:41 PM   #13
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
I use mine a lot...if I didn't have one I would HAVE to find an alternate way to get the wheel/s off the ground...mainly for maintenance and cleaning..and refueling as stated above
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old March 10th, 2014, 04:23 PM   #14
I took mine off. I kept it and still use it for servicing. If you take it off, KEEP IT!
I never used it other than in the garage. Now I just have a rear stand. Both methods have their perks and downsides.
Old March 10th, 2014, 04:39 PM   #15
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
The service stand saved the back side of my bike in the crash I just had.
Old March 11th, 2014, 07:10 AM   #16
abandonhope16
I use it for service and when I'm parked in the garage. I feel the bike has a smaller footprint when on the center stand and takes up less space. As a result, I can fit 2 cars and the kids wagon, stroller, etc without much fuss. Its under the bike, I dont really see it and its useful to me; I wouldn't take it off.
abandonhope16 is offline   Reply With Quote
Old March 11th, 2014, 02:01 PM   #17
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Wow, lots of people like this centerstand..... I couldn't wait to get mine off when I bought my rear stand and I haven't regretted it since.
Mods: Offset clutch pressure plate
Old March 11th, 2014, 03:31 PM   #18
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
bro do you even center stand?
they're too heavy
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old March 11th, 2014, 09:11 PM   #19
Josh_kcco
Josh_kcco's Avatar
they're too heavy
actually they weigh like a pound... lol
Old March 11th, 2014, 09:12 PM   #20
Josh_kcco
Josh_kcco's Avatar
so i took it off today (centerstand) going to give it a test run and see if it i like it.
Old March 11th, 2014, 11:54 PM   #21
xxgibeastxx
Motorcycle(s): 2014 Ninja 300
My 00 EX250 doesnt have one but my 06 Ninja 250 has one. The 06 is a parts bike and the center stand has been a life save when taking this bike apart. Been great to have. After everything is taken off will see if I can attach the center stand to my 00 EX250 if its possible.
xxgibeastxx is offline   Reply With Quote
Old March 13th, 2014, 10:31 PM   #22
poorfatjames
Motorcycle(s): 1974 Honda CB550F, 1986 Kawasaki Ninja 250, 1975 Honda CB400F, [sold: 1999 Suzuki SV650]
and that weight is at the very bottom center of the bike...exactly where you'd want it, if it has to be there.
My first bike had a center stand, second didn't. Was so sure I NEEDED one because it really is very useful that I bought an aftermarket center stand. But you know what? I had already adapted to just the kickstand and the centerstand is still sitting in my garage 10 years later. Lol. but you know what? I lie. I didn't adapt, I bought a bike stand lift.
I use my ninja's centerstand about 2/3 of the time.
poorfatjames is offline   Reply With Quote
Old March 14th, 2014, 10:50 AM   #23
b.miller123
b.miller123's Avatar
Motorcycle(s): 1998 Ninja 250 2007 Yamaha R6 2003 Honda RC51... sold :(
I took mine off since I have the Muzzy 2-1 exhaust. I didn't really use it as I have rearstands. I can see how it would be usefull if you had limited space or didn't own rearstands.
You need to get a forward handled rear stand. I have one of these and it is by far my favorite stand (I have two other pitbull SS rear stands).
Or you can get a stand with a removable handle.
b.miller123 is offline   Reply With Quote
Old March 14th, 2014, 02:46 PM   #24
Insan3guy
Insan3guy's Avatar
Motorcycle(s): 2015 zx6r
I use my centerstand every time I get gas. seems to let a few tenths of a gallon more into the tank. If you just use your bike as a commuter I'd say leave it on
Insan3guy is offline   Reply With Quote
Old March 14th, 2014, 03:38 PM   #25
Kokosun
Are you sure about that?
Name: That's "Sir" to you!
Motorcycle(s): Ninja 250R-F16, Versys KLE650 CAF
I use my centrestand ... pretty much all the time when it's in the garage. My Versys doesn't have a centre stand so I can appreciate how useful it is on the ninjette.
Kokosun is offline   Reply With Quote
Old March 15th, 2014, 03:52 AM   #26
n4mwd
n4mwd's Avatar
Unless you have a reason to take it off, then leave it on. Its far too useful to get rid of if you don't have to. When you have to work on your bike, you will be glad you left it on.
My Ninja Blog
Old March 15th, 2014, 10:59 AM   #27
Josh_kcco
Josh_kcco's Avatar
unless you have swing arm stand =]
Old March 15th, 2014, 11:05 AM   #28
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
I've never had a center stand, but I'll say I've got a swing arm and I can imagine the center being useful FOR standing up the swing arm -- wouldn't have to do the game of standing the bike up off the kickstand just enough to get into the spools while petrified you're going to over do it an drop the poor ninjette.
Old March 15th, 2014, 01:02 PM   #29
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
My turbo bike is a 2001 frame. I removed the side stand to make room for the shift linkage with lower pegs. Center stand only.I did have to add a stop to mine since the stand rests on the exhaust.
Worlds fastest 250 ninja
Old March 15th, 2014, 01:09 PM   #30
dcj13
Participant
dcj13's Avatar
One can save even more weight by removing the sidestand and leaning the bike up against a tree or building or something when parking it.
Old March 15th, 2014, 01:43 PM   #31
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
I have the pitbull (front/rear) with removable handles, love em.
If I didn't have stands, a center stand would be nice. I say keep it.
Old March 15th, 2014, 04:44 PM   #32
n4mwd
n4mwd's Avatar
The center stand keeps the spring arm unsprung, which makes it easier to get behind the tire when you need to. I'm also not convinced that the stands are that secure with the pregen. The newgens have a place for spools to go I think.
Another thing about the center stand is that it gives twice the support of the side stand so it will hold the bike up on softer sand than the side stand will. Of course, you should always carry a plate with you to use for that purpose, but if you forgot, you can use the center stand if you have one.
My Ninja Blog
Old March 15th, 2014, 04:50 PM   #33
dcj13
Participant
dcj13's Avatar
...Another thing about the center stand is that it gives twice the support of the side stand so it will hold the bike up on softer sand than the side stand will. Of course, you should always carry a plate with you to use for that purpose...
A metal cover for a duplex electrical wall box works well as a sidestand plate. An aluminum can (sodapop or beer) works in a pinch
Old March 15th, 2014, 06:07 PM   #34
n4mwd
n4mwd's Avatar
I bought a thin steel 3" diameter cover plate for 5 cents at a thrift store a long time ago. I think its something used for electrician work. Fits perfectly in my jacket pocket and is really thin so I never notice its there. Its always there when I need it.
But I still wouldn't trade my center stand for anything. Its just too handy. I've actually been wondering if it would be possible to take a pregen center stand and bolt it to a 300.
My Ninja Blog
WTB centerstand for '04 Ninjette Tennessee Budd Items Wanted 3 December 4th, 2014 08:41 AM
[motorcycle.com] - 2013 Triumph Trophy SE Recalled for Centerstand Problem Ninjette Newsbot Motorcycling News 0 January 2nd, 2014 04:00 PM
my chain touches centerstand after upgrades Oaklandish 1986 - 2007 Ninja 250R Tech Talk 11 July 28th, 2011 09:38 PM
Centerstand all of a sudden contacting the exhaust? Grn99Kawi 1986 - 2007 Ninja 250R Tech Talk 6 September 7th, 2009 02:32 PM
[motorcyclistonline] - The Centerstand Quartet Ninjette Newsbot Motorcycling News 0 June 19th, 2008 05:01 AM
