April 30th, 2013, 07:18 AM | #1 |
Join Date: Mar 2011 Motorcycle(s): Suzuki marauder 250 2001 & Ninja 250R 2010 Posts: 26
Bike stalls when touch throttle
hello everyone,
last sunday it was sunny so i washed my bike and then my bf made some change just like what we saw on this video: http://www.youtube.com/watch?v=nkIP1tb317s right after, when i start my bike rpm was low, so i tried to put the choke on to max. its better but still not enough. we tried to put back the screw on the choke cable in the original position, but the problem persist. As soon as we give a little gaz the bike stalls, and that even when the rpm to rev at 5000. also, when i sit on my bike and lift it off the stand, the bike would stall too. after 30min of warming, the bike slowly starts to respond but not really good either. before all this, i dont even have to warm it up and on choke i can just take off.(not saying that im doing this all the time but when im in a rush i just take off on the choke) what is the problem? please help me thanks My bike infos: ninja 250 2010 synthetic oil change every 5000 km my bike drinks 91 octane gaz sometimes 94. sleeps in garage has 24 000 km from 2011 untill now. spark plugs havent been changed yet. Last futzed with by Cycy; April 30th, 2013 at 09:47 AM. |
April 30th, 2013, 08:15 AM | #2 |
dirty boy
MOTM - Apr '14
So you had no problems before your BF started messing around with your choke cable correct? (i can't watch video right now so i have no idea what the guy did)
My question is why mess with it then? But that is beyond the point. Ok, So if you had no issues before then clearly the choke cable is the issue as nothing else has changed right? After the bike is warmed up can you take the choke off with out bike stalling? If so what rpm does the bike idle at? |
April 30th, 2013, 08:16 AM | #3 |
Hi Carine.
Adjust your idle mixture screw. It could be that it's set too low. You'll want to have the bike warmed up and set the idle to roughly 1500 rpms. The Manuals states 1350 rpms, but I find it runs better at 1500. The bike will benefit from new spark plugs as well. I tend to replace mine ever valve adjustment although they could be ran longer. Our bike runs fine off 87 octane. Putting anything more is just wasting money.
April 30th, 2013, 08:20 AM | #4 |
MOTM - Mar '13, Jun '14
Sounds water logged
April 30th, 2013, 08:24 AM | #5 |
1) go undo what you did and make sure that the choke still works as it's supposed to.
2) Higher octane is not better. Higher octane is harder to burn, the only reason you would need it is if you advanced the ignition, or if the engine is ancient and knocks a lot. 3) did you do ANYTHING else to the bike? Has it sat for any period of time longer than about 2 weeks? was it 100% perfect before you adjusted the choke cable? |
April 30th, 2013, 09:21 AM | #6 |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
clogged needle, to much fuel, choke not working correctly, a bf that dose not have a idea what the hell he is doing. This may be some of your issues.
Hey Unregistered never go faster than your brakes can be applied... |
April 30th, 2013, 09:29 AM | #7 | |
Yes before that my bike was ok. the thing is that the choke ''button'' only react when we get to the half point. What the video was showing, is to get that choke button to be fully usefull from start to end. when i take off in the morning its cold (0degree Celsius) so when i put to first gear the sound of it is horrible. makes me feel bad for the transmission. anyway, with the choke on the bike could rev at 5000 but as soon as i touch the throttle here comes the problem again. after waiting for MORE than half hour which is not normal, the bike would react normal again and rev between 1500-2000 |
April 30th, 2013, 09:30 AM | #8 | |
April 30th, 2013, 09:31 AM | #9 |
April 30th, 2013, 09:34 AM | #10 | |
the bike was doing fine, i was riding just ok everyday to work since a month. THAT day when he messed with my bike that SAME day right after trying to start it the problem showed up |
April 30th, 2013, 09:36 AM | #11 |
April 30th, 2013, 09:43 AM | #12 |
When ever I have a issue like this I pull the carbs of rebuild them reset all the stuff back to start and then slap it all back together.
April 30th, 2013, 09:58 AM | #13 | |
April 30th, 2013, 10:00 AM | #14 |
April 30th, 2013, 10:14 AM | #15 | |
after 30min of playing with the choke and idle (the bike is now warm because the engine is still running) the idle seems to have no problem. i can manage to make the bike run at 1500rpm with the choke completely off. otherwise, when i just start the bike even at 15 degrees Celsius, the choke open in max position, the bike seems to want to stall, when i turn the idle screw, its not working at all |
April 30th, 2013, 11:49 AM | #16 |
Drain the bowls of the carbs; you may have introduced some water while washing the bike.
http://faq.ninja250.org/wiki/Draining_the_carbs http://faq.ninja250.org/wiki/How_to_...he_float_bowls You only need a 3 mm long Allen wrench and a piece of hose and a glass recipient.
April 30th, 2013, 11:59 AM | #17 | |
If you have set the idle adjustment knob, so that the bike idles at 1500 when it is warm, it works. When the choke is on and the idle speed is high, the throttle link lever does not sit on the idle adjustment screw, that's why your able able to get any adjustment out it, with the choke on. If the bike is stalling when you give it gas with the choke on, the engine is cold and the fuel mixture is rich. Opening the throttle can make it more rich and bog. Decrease the choke in very tiny increments as the engine speed goes up during warm up, then give it small throttle input. Also, as others have indicated, run 87 octane gas. It performs better in the Ninja 250. |
April 30th, 2013, 12:28 PM | #18 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
My vote goes to water in the fuel....
April 30th, 2013, 05:50 PM | #19 |
heres some update: i didnt have time to do everything but at least i changed the spraks plug and i bought a spray can for carburetor cleaner and i spray some of it in the air filter. Before(before all this happens), my idle used to hang a little and comes back down slowly after giving some gaz. but now after spraying the carb cleaner theidle seems to respond a little faster. i dont know if theres anything related to my problem but we will see tomorrow when its more cold:-)
May 1st, 2013, 04:35 AM | #20 |
Hello everyone!!!!!!!!!!!!
this morning i tried to start my bike and everything was normal again! i think the carb cleaner spray helped a lot! i dont know how it could be related to the choke cable but im just glad that my bike works again!! =D thanks for your help and enjoy ur rides!!! |
May 1st, 2013, 05:05 AM | #21 |
Normal again aye... hmmm That can happen when light reflects off Venus through swap gas at the very same time you go to start your bike.
All is well again!
May 6th, 2013, 07:19 AM | #22 |
hi everyone its me again! (and im sorry lol)
I thought the problem was fixed but again this morning it came back! always monday huh? (maybe my bike is garfield) i found a video which is close to my problem.
Link to original page on YouTube. |
May 6th, 2013, 07:41 AM | #23 |
dirty boy
MOTM - Apr '14
Completely unrelated but could not help but notice The i'm assuming guy in that vid you posted has the softest pansy a$$ arms and hands i have ever seen, like baby smooth soft. Now that i am done sounding creepy on topic, I think that guy in the vid is flooding the bike causing it to stall as it is not at optimal working temp yet. Needs to either let it warm up more or just ride with the choke on for a little bit. I could be wrong. |
May 6th, 2013, 07:49 AM | #24 |
But even if i leave the choke on as soon as i touch the throttle the bike stalls =(
what i did this morning: i opened the air filter and sprayed some carb cleaner while the bike was running, the bike seems to want to stall after each spray. anyway, and then when i turn the throtle it sounded weird but started to be okay again.. i really wonder if i need to go to the garage. (its so stupid that everything started to break down just by touching the choke cable) |
May 6th, 2013, 08:09 AM | #25 | |
Not letting it warm up enough will do the same thing. Apply the choke first before starting the bike, don't blip the throttle while the engine is cold, a slow gradual decrease as the rpms rise is OK, but if the engine does not take small throttle inputs, leave the choke on a little longer. |
May 6th, 2013, 08:15 AM | #26 |
Read post #16 above.
May 6th, 2013, 11:36 AM | #27 |
someone told me about the seafoam. have anyone of you tried it before?
May 6th, 2013, 12:00 PM | #28 | |
I prefer Star Tron Fuel Treatment. Star Tron also makes a marine formula, however you don't have to worry about over dosing or getting the mix ratio wrong. A little Star Tron goes a long way. |
May 6th, 2013, 02:19 PM | #29 |
OMG its horrible! it really scares me by looking at the pictures of what the seafoam did to mkulchar!
now im really confuse! I dont know anymore! why so many people like seafoam??? and where can i get that star tron? i live in damn Quebec city where some of the products are unavailable >=( ____________ ok nevermind i called a store and they have it. Do i directly put this product in the gas tank? |
May 6th, 2013, 02:29 PM | #30 |
May 13th, 2013, 09:15 AM | #31 |
LAST UPDATE: it was SO SO SOOOOOO stupid! everyone kept telling me to check the air hose and i did! but looks like i did it with both eyes closed. i checked my air hose and everything looks ok, but at the last moment just before i put down the gaz tank the air hose bends. so yeah, what i did: i cut the hose just 2inches because its too long and now no more problem. FOR REAL lol =p
thanks for your help!!! |
May 20th, 2013, 12:35 AM | #32 |
Great to hear!
Full throttle kills bike, throttle lag response. | Diegone | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 30th, 2014 03:25 AM |
stalls sometimes when applying throttle | ninja12345 | 2008 - 2012 Ninja 250R Tech Talk | 11 | November 3rd, 2013 07:41 PM |
[superbikeplanet.com] - Touch Down, See Marquez Touch Elbow | Ninjette Newsbot | Motorcycling News | 0 | April 17th, 2013 12:30 PM |
A nice safe way to stay in touch while on the bike | codestp202 | General Motorcycling Discussion | 37 | August 11th, 2012 04:16 PM |
[twisted throttle] - Triumph Street Triple (2012) - Twisted Throttle Project Bike | Ninjette Newsbot | Motorcycling News | 0 | February 13th, 2012 07:10 AM |
