Old April 27th, 2019, 07:06 PM   #1
SNAKEBEATER
Motorcycle(s): 2007 EX250F
Post Weird stalling issue
I have a 2007 EX250F with just shy of 4,000 miles on it, that was running fine until yesterday. While riding in traffic on my way home the other day, the engine stalled when I pulled the clutch in to downshift and engine brake to slow down. I tried starting it, and it was acting like I was trying to cold start it. I pulled in the choke and let it run a minute, and got it going again. Granted, I had just taken it out on one of the longer ride's I've done on it, but nothing that it shouldn't have been able to handle.
A few miles later, the same thing happened. It seems to be an intermittent issue. I even adjusted the mixture to lean it out because it seemed to be running rather rich, and I figured leaning out the mixture might solve the problem.
after test riding it again earlier today, the same thing happened. I checked out the carburetors, made sure there were no blockages in the jets and that the bowls were clean.
I checked the air filter, and made sure there was no blockages there.
The only modification to the bike so far has been a baffle delete in the muffler. other than that, it seems to be a bone stock bike.
I even tried resetting the idle, which is now inconsistent. It'll be at 1500, and then after blipping the throttle, it'll settle at around 2500.
I'm out of Ideas at this point.
SNAKEBEATER is offline   Reply With Quote
Old April 27th, 2019, 07:16 PM   #2
a tank venting issue possible? or a weird float system malfunction?
Old April 27th, 2019, 08:51 PM   #3
SNAKEBEATER
Maybe, I'll check it out again tomorrow
Any other ideas would be greatly appreciated
Old April 27th, 2019, 09:00 PM   #4
Measure resistance of kickstand/sidestand switch in up and down position.
With kickstand up, measure resistance of switch, then wiggle its wires and connector.
Old April 28th, 2019, 07:38 AM   #5
I'm not seeing an electrical problem here, unless he's got multiple issues going on
fair enough, check/eliminate the sidestand switch...but additionally ponder this fact....an '07 with 4000 miles has done a LOT of sitting in its 12 year life
Old April 28th, 2019, 09:59 AM   #6
SNAKEBEATER
Previous owner said they started it at least twice a week, and I've been riding it pretty regularly since I bought it a little over a year ago as a starter bike to learn on.
But I do see your point. I'm going to go through the carburetor again and clear it out.
I'm also planning on a pod filter conversion to see if I can eliminate some of the gremlins between that and re-jetting the carbs
Old April 28th, 2019, 10:24 AM   #7
Welcome to what I call "the chase". I predict you'll be screwin' around quite a bit.
IMHO the quickest, most efficient, best all round path to a fine running, fuel efficient 2 fitty is starting with the known factory baseline...genuinely clear, well setup factory jetted carbs using stock airbox....just as it came from the dealership at brand new/running well behaved. Throw in a valve clearance check, plugs, filter service, blah blah.
Though I fully respect your right to take whatever path you desire.
Old April 28th, 2019, 10:28 AM   #8
Agreed. They run really well with the stock air intake system, and you don't have to listen to a lot of intake noise when you ride. That airbox is designed for performance, it's not just a flow restriction as it might seem.
Old April 28th, 2019, 10:51 AM   #9
The factory engineers were (evidently) doing more than smoking opium in the back room. A very effective design resulting in a sharp runner, responsive idle to redline right outta the box. Undeniable.
Old April 28th, 2019, 05:26 PM   #10
The bike ran fine when it left the showroom floor with factory airbox and filter (which is as large as ones on my CBR600RR; there's no restriction here). Why not just restore it back to factory-fresh clean condition?
Research pod-filters, they have numerous problems, such as stumbling in cross-winds. Many people convert back to factory air-box & jetting to get bike to work properly again. Check out these "carb cleaning" threads:
https://www.ninjette.org/forums/showthread.php?t=333176
https://www.ninjette.org/forums/showthread.php?t=330960
https://www.ninjette.org/forums/showthread.php?t=322846
https://www.ninjette.org/forums/showthread.php?t=321223
https://www.ninjette.org/forums/showthread.php?t=280658
Bike stalling & weird noise after CCT cleaning and lube DirtyAstronaut 2008 - 2012 Ninja 250R Tech Talk 8 June 18th, 2017 01:33 PM
Ninja 250 bogging/stalling issue avp957 2008 - 2012 Ninja 250R Tech Talk 11 June 23rd, 2014 11:45 AM
Kawasaki Faces N.H.T.S.A. Inquiry Over Possible Stalling Issue - ECU Recall Somchai 2013 - 2017 Ninja 300 Tech Talk 88 September 27th, 2013 10:18 PM
[nytimes.com] - Kawasaki Faces N.H.T.S.A. Inquiry Over Possible Stalling Issue Ninjette Newsbot Motorcycling News 0 July 19th, 2013 02:10 PM
idle/stalling issue - ive read the million threads on this topic. i swear. placetobe 1986 - 2007 Ninja 250R Tech Talk 18 August 14th, 2011 10:36 AM
