August 8th, 2014, 06:04 PM | #1 |
Join Date: Nov 2013 Motorcycle(s): R6, Kawi 250 Posts: 86
Who's lost the rear? (exit throttle)
This is more about what you can really get away with when throttling out of a corner on these bikes. I moved down from a built R6 so the more I've raced the more......aggressive I've become with the throttle-like stupid mid corner full throttle whacks So just to reassure me that I'm being stupid regail me with your highside stories or even if the ass end has come around on you I'd be curious to hear what happened. For reference I am running SC-2s, Elka rear shock and Racetech forks
August 9th, 2014, 09:26 AM | #2 |
Board Member
It can still happen with a 250. Don't get overly stupid mid-corner.
August 9th, 2014, 09:43 AM | #3 |
One word, rain...
Also, I had the rear bump out every now and then on the stock bits. Hasn't happened since the gsxr shock got installed. Under ideal conditions, just keep it pinned and she will pull through but you have to make a judgement call. Sometimes the better answer is to smoothly roll off, stand it up a bit to run wide and reset because gravel, wet leaves and such are sooooo unforgiving no matter what the bike is capable of. Practice your roll off as much as your roll on. - K. Code
Goal: Shake A Million Hands | Look through the corners | Track Day Prep | Closest track? | The Mid-Ohio School Last futzed with by csmith12; August 10th, 2014 at 10:48 AM. |
August 9th, 2014, 11:03 AM | #4 |
Yup. Rain.
August 9th, 2014, 05:59 PM | #5 |
Only time is during the rain.. On clean pavement (no sand--Live in Wisconsin)Have never had the rear wheel come out on me... Even giving it full throttle while im in the power band
September 9th, 2014, 06:26 AM | #6 |
Join Date: Oct 2012 Motorcycle(s): '04 R1 and '08 Ninja 250 Posts: 222
Draik lost the rear under acceleration for the first time this past weekend. It is possible to do even with a 250 in the dry, on a very abrasive track, with an SC1.
The only contributing factor that may have caused it that we can think of is that he started dragging his lower fairing. After that, he got his body postion improved and kept it from happening again, even though he ended up getting faster.
Check out this Ninja 250 roadracing youth---> TheDraik77 <--- My son |
September 9th, 2014, 06:35 AM | #7 |
I have had the rear go slack on me...
Dropped in to a corner and didn't have any more nuts to give, to keep accelerating or hold speed as the rev's went up going to the outside of the tire. Slacked the rear suspension and bounced like a pogo stick about 10 feet wider than anticipated. Strange feeling, its easier to do a downhill turn when the gravity horses start tugging at you faster than motor wants to go... |
September 9th, 2014, 06:38 AM | #8 |
Fighting Texas Aggie '05
Two ways I have felt the rear go on a 250, one was those awful IRC rocks being ridden too hard at track pace (I take responsibility for that one) and two being overwhelming the rear shock and you get the rear tire skipping and hopping through the corner. Hot Texas summer days towards the end of session, ridden hard with a sticky tire and a 190lb rider, the stock shock will struggle to keep the rear wheel in check.
Lost the rear | alex.s | !%@*#$%!)@#&!%@ I crashed! | 74 | March 4th, 2013 12:46 AM |
Lost Throttle Response | Corona | 2008 - 2012 Ninja 250R Tech Talk | 4 | January 30th, 2013 11:42 AM |
Someone dropped my bike. lost starter, rear signal. | arnoldc6 | 2008 - 2012 Ninja 250R Tech Talk | 7 | October 7th, 2012 07:51 PM |
[topix.net] - Joe Soucheray: We lost more than spelling when we lost the classifieds | Ninjette Newsbot | Motorcycling News | 0 | June 10th, 2012 12:30 AM |
my ninja stopped grabbing first gear or lost throttle response i think? | jon.b.calderon | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 16th, 2012 10:54 AM |
