Old June 2nd, 2015, 10:54 PM   #1
Floki
Motorcycle Nurse?
Floki's Avatar
Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100
2010 Track Build
I picked up a nice little 2010 with 4500 miles from Dallas, Texas last week for 2K that was mildly wrecked(or so I thought). It was cheaper to drive my car and ride it back while a friend drove my car on the 600 mile trip. Talk about a long ride, it took 12 hours for me to make it home.
Upon tear down, I found my right front fork to be bent, and I suspect my triples may be as well. I just ordered a set of used straight forks, okay hopefully straight ones, off ebay. The rest of the parts should be in as well.
Here is my list of parts to be installed
-SS lines and HH pads
-Clip ons and Yoshi Rearset adjusters
-.8kg springs, 10W oil, Emulators, and Pre-load adjusters
-'09 GSX-R shock with the dogbones that raise stock height 1/4''
-Area P exhaust damaged from ebay, KN filter to go in airbox, and stage 2 kit
-Pirelli SC2 up front and DR2 in rear 120/140 size
I may be forgetting something now, but I'll remember when it all comes in. Hopefully those doggies don't take too long like everyone says about burkhart cycles
File Type: jpg 00v0v_jBNvZY2bFSj_50x50c.jpg (983 Bytes, 208 views)
Floki is offline   Reply With Quote
Old June 3rd, 2015, 12:15 AM   #2
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Get real rearsets not the adjusters. Stock are designed to break on the plate near the bolting point so you wont get anything else out of them. Not as good feel through the rubber either. I believe Pirelli is making a 140 supercorsa now also - lots of grip, less life.
Build looks good! Have you used StompGrip before? I love the stuff. I also suggest having extra clip on bars on hand. They're usually $15 each.
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old June 3rd, 2015, 03:58 AM   #3
Cabecinhas
Motorcycle(s): Ninja 250R
Race fairings and a front radial brake master cylinder that can transmite more feeling of braking.
Last futzed with by Cabecinhas; June 3rd, 2015 at 06:09 AM.
Cabecinhas is offline   Reply With Quote
Old June 3rd, 2015, 05:49 AM   #4
Qomomoko
Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4
looks like a fun project....
front radial master sounds like a good idea.. for me too and extra clip on bars too..
Qomomoko is offline   Reply With Quote
Old June 3rd, 2015, 07:41 AM   #5
Floki
Motorcycle Nurse?
Floki's Avatar
My budgets running low for now, I figured I'd put off race fairings till later.
On rearsets, Do any of them come with solid mount pegs? Or is that an extra add on? I was wondering if any of the sets came with them.
Max, I couldn't find the SC2 in our size anywhere. I looked for a while then gave up to the Dr.
Old June 3rd, 2015, 10:17 AM   #6
Trailerboy531
You would probably have to get the SC2 from a vendor. When you say solid mount pegs do you mean not removable?
Pretty much every brand of rearset is adjustable so that you can find the best place for the peg that fits you.
CVMA #531
Old June 3rd, 2015, 10:46 AM   #7
Floki
Motorcycle Nurse?
Floki's Avatar
I mean The pegs that don't fold and you can rest on Jack stands if you need to.
Old June 3rd, 2015, 10:57 AM   #8
Most race/track oriented aftermarket rearsets like this. They are designed to have break points instead of folding.
Old June 3rd, 2015, 05:22 PM   #9
Trailerboy531
Yep - they will specifically state they are folding if they do. Not as common.
CVMA #531
Old June 4th, 2015, 11:37 AM   #10
Floki
Motorcycle Nurse?
Floki's Avatar
I scored an area P full system off eBay, 12'' can but it is not the race exhaust. Am I going to have ground clearance issues with that? It looks low and in the stock position
Old June 4th, 2015, 11:40 AM   #11
Your side stand and mounting tab will drag before exhuast.
Old June 4th, 2015, 12:15 PM   #12
Floki
Motorcycle Nurse?
Floki's Avatar
That's coming off too, just making sure I'll be okay with this setup.
Old June 4th, 2015, 01:34 PM   #13
Trailerboy531
By 'coming off' you mean you're taking an angle grinder to it, right? Removing the kickstand helps some but it's still pretty easy to drag that part of the frame. You can grind just under the weld there.
CVMA #531
Old June 4th, 2015, 04:18 PM   #14
Floki
Motorcycle Nurse?
Floki's Avatar
Yeah that's what I mean.
I'm working on my dampers with a file right now. This is a nice change of pace lol
Old June 4th, 2015, 05:25 PM   #15
just dont crash
Old June 4th, 2015, 05:39 PM   #16
Floki
Motorcycle Nurse?
Floki's Avatar
Yeah, crashing is expensive. I bought this to be a budget trackie
Old June 4th, 2015, 08:33 PM   #17
Floki
Motorcycle Nurse?
Floki's Avatar
My desired preload should be 10mm since I am using adjustable caps. I can then dial in sag with the adjusters and do not need to cut the spacers specifically for my weight and desired preload. Is this correct?
Old June 5th, 2015, 04:55 AM   #18
Qomomoko
are your springs form RACETECH? if so.. you making the holes per their instructions or varying a little?
Someone on here, think trackngear said RT instructions need fine tuning fyi... I have not messed with mine yet..I got stuff from RT too..
I got the .75 kg/mm springs
Old June 5th, 2015, 05:02 AM   #19
Floki
Motorcycle Nurse?
Floki's Avatar
Yes, springs and emulators from RT. I did it according to them, 6 5/16" holes
Old June 5th, 2015, 05:13 AM   #20
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
The stock preload is 17 mm and you should compare the preload-adjuster with the stock seat of the fork spring (Partno. 44029-1127) and measure the difference in height.
So you'll see if the preload-adjuster give you more preload and if this is the case, then cut fork collar.
Also don't forget when you put the gold valves inside that the spring comes higher, resulting in more preload also.
I'd cut mine to have the ability to adjust from 12 to 20 mm.
Good luck
Old June 5th, 2015, 07:49 AM   #21
Floki
Motorcycle Nurse?
Floki's Avatar
Doing jetting today and my Milwaukee offset driver broke. I got lucky as hell finding one, probably going to be a week before I get another one.
Old June 5th, 2015, 10:38 AM   #22
Floki
Motorcycle Nurse?
Floki's Avatar
man I hate the stock airbox
Old June 5th, 2015, 10:51 AM   #23
for realz
Old June 5th, 2015, 10:58 AM   #24
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
What do you weigh? Everyone has a preference and you can go fast on stock junk but in my experience if you cut the rods per Racetech instructions your going to need to move up in oil viscosity over 10W and your likely still going to have a few issues at the bottom of the stroke riding hard.
Old June 5th, 2015, 11:07 AM   #25
Qomomoko
what do you recommend for weight 150 lbs and 165 lbs with gear.. 330 lbs ninja with .75 kg /mm and i think I am putting 10 wt oil Spectro.. for my Ducati s4 I was told by RT to use 5 wt.. i'll check when get home..
its pregen with new gen tubes.. but RT springs and gold valve emulators.
Old June 5th, 2015, 11:34 AM   #26
Trailerboy531
If you're not racing this bike and it's just a track bike then why aren't you using pod filters instead of the airbox?
CVMA #531
Old June 5th, 2015, 11:37 AM   #27
Floki
Motorcycle Nurse?
Floki's Avatar
I want to race, eventually lol.
My fork tubes off ebay that said they weren't bent, are bent. YAY
Old June 5th, 2015, 01:08 PM   #28
Floki
Motorcycle Nurse?
Floki's Avatar
I weigh 180, and I can't just make the emulators stiffer to compensate?
Old June 5th, 2015, 03:56 PM   #29
Floki
Motorcycle Nurse?
Floki's Avatar
I cannot for the life of me find a straight fork on ebay. Cheapest set is 300 and I'm out 200 from the first set I bought. This really makes me want to put the old fork in, it is barely bent at all. There aren't even any depressions in the chrome
Old June 5th, 2015, 07:31 PM   #30
cuong-nutz
cuong-nutz's Avatar
Hit up Dan aka @PartsNinja. I think his site's been under renovations but he's been selling on ebay for some time now. See what he can do for you. He's helped quite a few people here and other racing buddies here in the South.
How bad are the forks bent? you should be able to return the ones you bought on ebay and get a full refund. You don't want to be running bent forks ESPECIALLY on the track. You're just asking for trouble. Not sure about the legalities for your race division.
HalfFast Racing Team
Old June 5th, 2015, 07:37 PM   #31
Trailerboy531
Yeah wtf return the bent forks. If the ad said straight and they're definitely not then return. eBay and PayPal are great about backing the buyer
CVMA #531
Old June 5th, 2015, 07:38 PM   #32
cuong-nutz
cuong-nutz's Avatar
You may be able to bend your bent tube back. Got any buddies in a machine shop with a nice press?
Old June 5th, 2015, 08:22 PM   #33
Floki
Motorcycle Nurse?
Floki's Avatar
The one I have isn't bent bad at all. The smallest amount of light shines through on a flat surface and it passes through the triples a little snugly. No pits in the chrome.
I should get a return but they deduct the 15 included in price for shipping plus the return shipping.
Old June 5th, 2015, 08:50 PM   #34
Trailerboy531
No - they deduct for people who don't stand up for themselves.
Type A personalities don't pay a cent. Your choice.
CVMA #531
Old June 7th, 2015, 05:56 PM   #35
Floki
Motorcycle Nurse?
Floki's Avatar
The plan is to find a machine shop too straighten the forks, since the bend it so slight.
But I have a questions. I'm reading up on the forks across generations and they say they're all basically the same fork, just with different bodies to attach brakes/fender. Could I buy a pregen/300 straight fork, new seals etc. and swap the fork tube onto my fork body? Not sure if they're actually that much the same or not.
Old June 8th, 2015, 07:38 AM   #36
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
The PreGen has 36mm forks while the newer bikes have 37mm, so those won't swap in. My understanding is that the 300 has "the same" forks, so those tubes should at least fit.
I'm a bit curious about swapping some NewGen/Gen2 500 fork parts around too. However, the 500 lists 5.1" of travel while the NewGen only lists 4.7". I'm wondering which part(s) create that travel limit, and if swapping some of the NewGen parts in would reduce my travel.
Old June 8th, 2015, 08:40 AM   #37
Floki
Motorcycle Nurse?
Floki's Avatar
I found a machine shop that said they have done it plenty of times. Also, I got the full refund on those forks and the guy said keep them so I have an extra set for the guy to straighten if he messes up. Hell yeah!
Old June 8th, 2015, 11:42 AM   #38
cuong-nutz
cuong-nutz's Avatar
That's good. That's usually the scenario. Good luck!
Old June 9th, 2015, 06:22 AM   #39
sharky nrk
sharky nrk's Avatar
unfortunately no, emulator adjustments really only work on compression - and high speed compression at that - the issue is really rebound related.
Old June 9th, 2015, 06:29 AM   #40
sharky nrk
sharky nrk's Avatar
Are the emulators installed per the RT instructions? Generally most people (myself and my brother whose suspension we installed ourselves included) around the paddock have found that the 10w oil with the RT GVE installed per instructions did not have enough rebound dampening, with a severe lack at the very bottom of the stroke.
Depending on your riding style, your weight, and your spring selection it may not be a huge deal. But we found that a a heavy rider that really pushed the front deep into its stroke had issues at the bottom. Heavy oil (25-30W) when GVE installed per instructions helped but made the action a bit sluggish in other areas. A new set of damper rods, modified differently allowed correction for most of the bottom of stroke issues with a lighter (15W I think) fluid.
It is going to be personal experience and preference to some degree though.
Track Day - Budget Build Artie 1986 - 2007 Ninja 250R Tech Talk 19 September 3rd, 2015 01:28 PM
Ninja 250 track build Braden07 Ninjettes At Speed 56 July 15th, 2015 12:44 PM
08 Ninja 250 track build ROB654 2008 - 2012 Ninja 250R Farkles 10 May 14th, 2015 08:32 PM
08 r6 Track/Race Build csmith12 Pictures 48 May 3rd, 2015 08:34 PM
Need help with Track build jmk420 Ninjettes At Speed 35 June 24th, 2014 05:59 PM
