Old September 27th, 2009, 09:39 AM   #1
miniguns167
Motorcycle(s): ninja 250r
front sprocket
well ive read through the threads on removing the nut on the front sprocket and i guess mine is on super tight , im using a torque wrench and pulling well over 200lbs on it, it is bending my handle on my wrench, dont have access to impact at moment, any ideas??
miniguns167 is offline   Reply With Quote
Old September 27th, 2009, 09:54 AM   #2
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Use a cheater bar... put a piece of pipe over the handle, to make the total tool length longer. If you're bending the handle on your torque wrench, you might try using a breaker bar or even a wrench instead.
If you can haul/tow your bike, you might try stopping by an automotive garage and ask an auto technician to break it loose for you with an impact wrench.
Old September 27th, 2009, 10:09 AM   #3
miniguns167
i managed to break it loose i guess i just had to get pissed lol. thanks anyways. do you know how much torque it calls for when i put it back on?
Old September 27th, 2009, 11:46 AM   #4
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
http://www.ninjette.org/wiki/Fastene...Specifications
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old September 27th, 2009, 11:59 AM   #5
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
You did WHAT!!??!??!?
Never, EVER use a torque wrench to loosen a fastener!
That's a really, really good way to destroy your torque wrench!
If it's super-tight, do the following:
1) Go to Sears and purchase a half-inch drive breaker bar and a half-inch drive socket of the appropriate size. Also a few feet of pipe big enough to slip over the handle of the breaker bar, if you don't have it at home.
2) Use the breaker bar with pipe extension to apply a large amount of force to the fastener. If you do it right you can also carefully position a car jack under the handle and use it to apply even more force. I've used the jack-and-wrench method to loosen really, REALLY stuck stuff... like iron drain pipes that were installed 75 years ago. It's very dangerous, but effective.
3) Once the fastener is loose, take the now-bent breaker bar back to Sears for the Craftsman refund. A sheepish grin might help here.
If the "use a bigger lever" method fails, you might also try heating the fastener (CAREFULLY) with a propane torch, but it's easy to damage stuff that way.
Can't get front sprocket cover off Jason5885 2008 - 2012 Ninja 250R Tech Talk 8 April 4th, 2021 04:33 PM
13t front sprocket greatwhiteninja 2008 - 2012 Ninja 250R Tech Talk 14 August 3rd, 2011 09:35 AM
Front Sprocket Archerzz 1986 - 2007 Ninja 250R Tech Talk 66 June 29th, 2011 10:22 AM
Front sprocket, help!! cbowman78 2008 - 2012 Ninja 250R Tech Talk 34 November 14th, 2010 10:52 AM
15 Tooth Front Sprocket FerociousNINJA 2008 - 2012 Ninja 250R Tech Talk 5 September 14th, 2010 05:21 AM
