May 21st, 2016, 10:38 AM | #1 |
Just sittin on my stool..
Join Date: May 2016 Motorcycle(s): 2012 Ninja 250 Posts: 429
Adjusting clutch.
So I have watched a few tutorials on YouTube on how to get your clutch to engage closer to the handle bars. I have small hands and I have found out I stall out a lot becAuse after about half way up my hand it mostly extended and I just let go of the clutch because to me It feels like the top of the clutch.
My question is is it safe to do this on your own? I asked my mechanic friend and he said adjusting it won't fix the problem I would need to buy adjustable levers. But those are 100 bucks! Looking for a cheap way out here. |
May 21st, 2016, 10:51 AM | #2 |
Your friend is mostly right. That adjustment is for the cable and not really intended to adjust the lever for personal preference but sometimes it's "close enough".
If you are after adjustable levers that are decent, have a look for "the2wheels" levers on ebay. I have been riding with those for a long time now. Many members here have them (or very similar) and have experienced some fading. I got the silver ones and mine have not, but I keep my bike in the garage too so ymmv. There is another member here who has a friend's shop that sells similar levers that are considerably less than a big face.
May 21st, 2016, 10:52 AM | #3 |
Check eBay, that's where I got mine,
http://www.ebay.com/itm/271847513274...%3AMEBIDX%3AIT I have these on both my Ninjette and EX500, good value, and they work.
May 21st, 2016, 10:52 AM | #4 |
PSA: Please be very careful when installing new levers. An improper brake lever install can lead to a VERY unpleasant riding experience.
May 21st, 2016, 10:57 AM | #5 |
Wow those are cheap! Is it safe to have shorty levers??
May 21st, 2016, 11:03 AM | #6 |
Of course it's safe, but "safe" is relative to your hand's ability to grip the lever. Shorties are preferred by riders who brake with 2 fingers (which is a skill). If you prefer full length ones, they have those too at a very similar cost.
May 21st, 2016, 11:15 AM | #7 |
Oh! And if you attempt the lever install yourself. Be mindful that the clutch perch bolt is SUPER easy to strip out. So don't over tighten it too much or that will be the next part you're looking for.
Changing levers is a very easy job, should only take you about 5 mins per. Just triple check your brake side to make sure it's right, and then check it again.
May 21st, 2016, 11:32 AM | #8 | |
May 21st, 2016, 01:34 PM | #9 |
Join Date: Apr 2016 Motorcycle(s): 01 Ninja 250 Posts: 69
Just follow one of the MANY tutorials on YouTube. Seriously should take a total of 5 mins. The brake lever can be done in about 30 seconds. The clutch lever takes only a couple of mins.
All you need is a 10mm socket. Loosen and remove the nuts on the bottom first, then loosen and remove the the bolt on top. If you find it difficult to get access to the bottom nut, just loosen the nut that compresses the assembly to the bar and then rotate the assembly. Be careful on the clutch lever and do not break the the sensor post that's made of plastic. Also, get the cheap ones from eBay, should run you about $20 and about 10 days to deliver from China. 99% of the levers you find on eBay are all the same Chinese ones. |
May 21st, 2016, 02:00 PM | #10 |
cadd cadd cadd
MOTM - May '15
The search function is helpful. Give it a try sometime.
https://www.ninjette.org/forums/sear...archid=2188756
Riding it like I financed it. Last futzed with by cadd; May 21st, 2016 at 04:53 PM. |
May 21st, 2016, 02:14 PM | #11 | |
May 21st, 2016, 03:06 PM | #12 |
cadd cadd cadd
MOTM - May '15
If you don't like my reply then fack off with your tiny hands.
Riding it like I financed it. |
May 21st, 2016, 03:28 PM | #13 |
Kitty has claws
May 21st, 2016, 03:38 PM | #14 |
If your hands are weak, then maybe shorty levels won't be good, due to most of us whom have shorty use 2 fingers, which is what there made for mostly. You could play it safe and just get the standard size. Worst case scenario is you can buy the shorty ones later once your more confident, and build up those muscles. Yes your hand muscles will be better, along with your core.
May 21st, 2016, 03:54 PM | #15 | |
May 21st, 2016, 04:02 PM | #16 |
Shorty vs full size is an ergonomics/skill choice that only you can make. Using all 4 fingers on a short lever is fine as long as it doesn't compromise being tight on the bars, hand and wrist comfort and so on. Replacing the stock levers should be an 100% improvement to rideability, and not take away from another aspect just to get them.
@cadd - I clicked the link, no results?!?!?!?
Goal: Shake A Million Hands | Look through the corners | Track Day Prep | Closest track? | The Mid-Ohio School Last futzed with by csmith12; May 22nd, 2016 at 07:17 AM. Reason: spelling |
May 21st, 2016, 04:40 PM | #17 | |
I've heard the same thing, if you need measurements of mine, let me know.
Adjusting chain. | mcwidave | 1986 - 2007 Ninja 250R Tech Talk | 7 | August 2nd, 2015 10:01 PM |
Adjusting the headlight? | WaydeUltima | 1986 - 2007 Ninja 250R Tech Talk | 3 | July 24th, 2015 02:13 AM |
Adjusting headlights? | uKER | 2013 - 2017 Ninja 300 Tech Talk | 2 | July 8th, 2013 07:50 PM |
Adjusting Choke | astricklin | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 5th, 2013 06:06 PM |
Adjusting my mirror | RaZeDaHeLL | General Motorcycling Discussion | 6 | January 22nd, 2012 02:34 PM |
