Old January 26th, 2015, 06:24 AM   #201
swarfman64
Master modder
swarfman64's Avatar
Motorcycle(s): TURBO gpx250 99 CB250/500rs Sherco290 Trials Indian 1911big base (replica)
Sounds like good advice to me. With the torque the turbo adds it feels like 10000rpm changes are suited. Eventually the dyno will tell.
[B]Come and see my turbo ninja build, dyno build and other stuff at http://swarfman64.blogspot.com.au/20...rtia-dyno.html
swarfman64 is offline   Reply With Quote
Old January 26th, 2015, 06:42 AM   #202
garth285
KAWASAKI GURU
garth285's Avatar
Originally Posted by swarfman64 View Post
I wish I could help with your rpm problem. While I'm a long way off tuned at 9psi, a standard ignition system with cr9e plugs at 0.027", 25l/r pump and a 0.5:1 rising rate reg seem to be keeping up easily. I've got a new ignition map that seems to work with EGT 1150 and AFR 12.5:1 full load. I've got an old noisy motor so in stopping at 12000rpm. It looks like your pump/reg etc setup is better than mine so its gotta be something simple.Attachment 34522. I'm not saying that this map is great because its street tuned but gut feeling, but it is letting me go full noise to 12000rpm low egt and no knocking.
Very nice, yeah looks like you have it turned down to about 26-27* of timing. I tried turning my timing down to 25* and no change, I am convinced its my ECU. I know my fuel pressure is solid, my plugs are gaped down to .023 I Think it was (CR9E's), the coils ohm out, I dont think the coils are a weak point as they are also the same coils that are ran in 1000's and guys running nitrous or turbo on them dont have issues, I dont think its a wastegate issue because the boost holds fine and even with it disconnected it does the same thing. I dont think its the "tuning" side of it because I have tried everything from turning down the timing to turning it up, and I have been able to make the bike go rich or lean and still wont clear up, the bike hits a rev limiter, no knocking just a early limiter.
I know I'm dealing with all new territory since I have all ninja 300 stuff on my bike but I also found out woolich had some rev limiter issues with the zx-10r's so I'm hoping maybe it just has a software glitch.
I flashed the ecu back to stock and I am going to drop it in a stock bike and see what it does.
Old January 26th, 2015, 06:51 AM   #203
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I don't think you have a coil problem. But the 1000 will have twice the piston serface and lower cylinder pressure than a turbo 250cc. Don't assume anything at this point.
Worlds fastest 250 ninja
Old January 27th, 2015, 06:58 AM   #204
garth285
KAWASAKI GURU
garth285's Avatar
Very True!!!!
I finally have Woolich looking into the maps to see if there are any hidden limiters so we'll see.....
I was also thinking of something else today on my way into work, I am wondering if neutral has its own rev limiter or not, there is one listed in the software but I cannot edit it, I wonder if I run the bike with it thinking its in neutral if it will rev out.
I was also thinking if I wanted to be a super quid I could run my data logger and free rev the engine to the limiter and see what it does lol.... but I dont like to abuse the engines...
We'll see if they find any hidden limiters!
Old January 27th, 2015, 08:19 AM   #205
Racer x
Racer x's Avatar
My old boss was a German tool and die maker with Mercedes Benz back on the fifties. He worked on Fangios car in South America with the 600 and race car decvision. He would free rev engines till I was lying on the floor screaming STOP!!!! He was like " it's no problem" haha. So now I don't mind so much when I do a static test with the nitrous. If I am lean the engie will spike 14500 " it's no problem"
Last futzed with by Racer x; January 27th, 2015 at 02:36 PM.
Old January 27th, 2015, 01:22 PM   #206
swarfman64
Master modder
swarfman64's Avatar
Compressor surge?? When mine did it it's like a limiter. Like hitting a brick wall. With an exhaust/muffler it's easy to hear the intake air chopping. Just a thought.
Old January 28th, 2015, 04:37 PM   #207
MrSavvy
Man, your 250 looks so f***ing sexy. I bet it sounds amazing. Props!!
MrSavvy is offline   Reply With Quote
Old January 29th, 2015, 07:39 AM   #208
garth285
KAWASAKI GURU
garth285's Avatar
Just took a look at the limiter, i found an additional limiter and i have updated the definition for this, please test it out by updating to v3.2.5 of WRT.
Great news! Hopefully they fixed the rev limiter problem!!! I'm going to flash the ECU tonight and try it out!
Old January 29th, 2015, 11:07 AM   #209
QuickSiR
QuickSiR's Avatar
Motorcycle(s): Honda 599
Light at the end of the tunnel!!!!
QuickSiR is offline   Reply With Quote
Old January 29th, 2015, 11:28 AM   #210
garth285
KAWASAKI GURU
garth285's Avatar
Thats for sure! Cant wait to get home and try it out! Unfortunately I dont think I'll be able to get back to the dyno until next week but I have a tag and a tail section on the bike now so I can atleast do some small tuning to get it close.
Old January 30th, 2015, 04:35 AM   #211
garth285
KAWASAKI GURU
garth285's Avatar
Well I think the problem is fixed! Unfortunately I had very little time to mess with the bike last night and then had to get up at 5am to come into work early so I made some fuel changes and I'll give it a shot tonight.
I copied my old fuel maps into the bike and last time I had ran the bike I tried adding a ton of fuel to it up top.... well let just say at 10.3:1 AFR the bike is not happy lol.... I hit just about 11,000rpm though so I am getting close!
I'll flash the ECU with the fuel changes this afternoon and give it another shot, if all goes well I'll be off to the dyno sometime soon!
Will keep you guys posted.
Old January 30th, 2015, 05:13 AM   #212
QuickSiR
QuickSiR's Avatar
Excellent news!!
When it's all done. Then you'll have enough time to make a turbo kit for my 250!
Last futzed with by QuickSiR; January 30th, 2015 at 06:51 AM.
Old January 30th, 2015, 06:21 AM   #213
swarfman64
Master modder
swarfman64's Avatar
great news!
Old February 1st, 2015, 03:21 PM   #214
garth285
KAWASAKI GURU
garth285's Avatar
Well I'm still stuck at 10k rpm :-(
I tried the latest BIN and that did not help, I tried leaning the bike out a ton just incase it was going so rich it was breaking up and lastly I just moved my return fuel line.
Still no luck :-(
I am going to put a stock flash in the ECU and bring it south to my buddy to see if it has a 10k rpm limiter for him, if it doesnt then there has to be something I'm missing.
Old February 1st, 2015, 07:56 PM   #215
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Still no luck :-(
Shawn, that's no good message.
What I would do is to put your ecu in the bike of your buddy and look if it's showing an error code, so maybe to get an idea about whats wrong.
The bad thing with the 300 is that you can not delete it, like you can do with the 250. But maybe the guys from Woolich Racing know a way how to do it?
But let me please ask you again, did you replace the iap-sensor or do you use the stock sensor? To understand my question, the stock sensor is a vacuum sensor and you're putting boost on it.
Good luck.
Old February 1st, 2015, 11:17 PM   #216
swarfman64
Master modder
swarfman64's Avatar
Not good. If its any comfort I've parked mine until I've built the dyno. It's near impossible to tune any better without being able to watch the values in real time. Are you using a with a VE and alpha-n blended map?
Old February 2nd, 2015, 06:10 AM   #217
garth285
KAWASAKI GURU
garth285's Avatar
Good luck.
Yes I will try the ECU out on a stock bike and report back.
The IAP sensor is stock, but I have a T inline to the IAP sensor that goes to a one way check valve so that the sensor will see vacuum but will bleed off any boost or positive pressure that come on that line.
Old February 2nd, 2015, 06:14 AM   #218
garth285
KAWASAKI GURU
garth285's Avatar
Yeah I am using an Innovate LM-2 with thir Aux-Box so I am able to go out and run the bike and view the data right after I can see RPM, Air Fuel Ratio, TPS, Turbo Oil Pressure, boost/vacuum. Its a pretty great setup.
As far as the map modes, kawi uses a RPM vs. IAP for anything under 10% throttle and then RPM vs. TPS for anything about that. I am mainly just trying to tune the WOT so I'll take the bike on a loop and go WOT 1st and 2nd gear maybe 3rd and see what it does. On a good note I think I have all of the bike mapped except from 9600rpm up lol.
Old February 11th, 2015, 08:19 PM   #219
garth285
KAWASAKI GURU
garth285's Avatar
Well tested the ecu out and it's good. Going to try a few more things this weekend to see If I can get it to run properly.
This sucks......
Old February 18th, 2015, 08:03 PM   #220
garth285
KAWASAKI GURU
garth285's Avatar
Well I'm just about to give up on this thing......
I pulled my 300 rotor and compared it to the 250 tonight, I took a photo of both of them and overlaid the photo on the PC and found the marks are dead on the same between the 250 and 300.
The other thing I did was try to swap the wires on the ignition pickup incase there was a difference there..... tried it, bike wouldnt run and would just misfire.
I have tried multiple ECU maps and nothing had fixed the issue.
So the next I decided to check the cam timing, I got a little excited at first because I started lining everything up and had the 1T mark lined up and my cam marks were no where to be seen, a quick check of the service manual I saw that you need to line up the 2T mark to set the cam timing, well I moved it to that and it was spot on.
So now I have verified the timing marks on the flywheels are the same, my cam timing is good, my ECU is good, my fuel pressure is good, my spark is good, so on and so on.
So my next test might have to be to pull the turbo header off and run a stock header and see if it will free rev cleanly.
Still trying to figure out whats going on but not having much luck. Hell maybe I'll swap motors and see if the other one runs better...... not that I want to do it but I'm running out of options..... it doesnt help that now I'm house hunting and getting rid of a project will help with a down payment...... sigh......
Old February 18th, 2015, 08:42 PM   #221
Somchai
Freedom for Germany
Shawn since you're not so far away from the goal I think you should not give up, but I also understand sometimes when things don't do like they should it's frustrating.
So let me share an idea, I think you're problem could be any electronical behaviour and maybe you just didn't connect all the connections the Ninja 300 needs.
I didn't look for the wiring of it (even not for the 250, since I didn't need so), but I guess that also the gauge could be part of the electrical system in case of the 300.
The 300 is quite different to the 250-FI, since i.e. in the 250 one can delete the error-codes what in the 300 is not possible.
So short way after my long talk before, get an ecu from the european 250-FI and go with that could maybe help to take that way easier.
On german bay there is one but you should ask if they ship it to the US http://www.ebay.de/itm/Kawasaki-Ninj...item3cf13ce407
I wish you good luck and hope you'll find the solution
Old February 18th, 2015, 10:22 PM   #222
micoulisninja
modaholic junkie
Hell no !! Come on man, you 're so close !! You could let it be for a day or two, just to let your mind get into other stuff and get back to it with a clear head...
You have no idea how many obstacles I had to overcome to make mine work !
And I'm not sure yet how well it will perform after breaking-in or how long it will last...You know you have to be really patient when going your own way... I wish I could help you more somehow...
I am a great fan of your effort and I am sure that if you go for it, you will make it work eventually... just take your time...sometimes that is all it takes...
P.S. It just came to me but are you sure the fuel rail size is adequate for the high rpm ? becuase it might stay within the AFR while rpm go up slowly but what if the rate that fuel is being fed is not enough ?
Old February 18th, 2015, 11:02 PM   #223
swarfman64
Master modder
swarfman64's Avatar
Sorry, giving up isn't an option. Seeing what you've done so far I don't think you could walk away from it without it haunting you. So.....if there is anything I can do for you just ask. The end resaults are going to be unreal. Not to mention what the next person does,then the next......these turbo 250's are still in refined and in the development stages, you me and a few others are opening doors for others by doing this and showing the world.
That's my motivational speech for today, keep pushing!
Old February 18th, 2015, 11:33 PM   #224
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
I just started reading this thread lol..I was not expecting this!!
The Bike | The Truck
Old February 19th, 2015, 01:26 AM   #225
garth285
KAWASAKI GURU
garth285's Avatar
Yeah I know I have to figure it out, its just so frustrating!!!!! It doesn't help that I have limited time to even work on the damn thing but I've been trying to iron out this problem for damn near 2 and a half months!
I wish I had a ninja 300 I could throw this turbo kit on and see what it does!
Bahhh I'll keep you guys updated......
Old February 19th, 2015, 08:02 AM   #226
cuong-nutz
cuong-nutz's Avatar
Ill take a stab at your issue when I get some free time at the computer.
HalfFast Racing Team
Old February 19th, 2015, 11:22 AM   #227
cuong-nutz
cuong-nutz's Avatar
Have you checked your connections at your throttle bodies? TPS sensors/deletes. Did you remove the secondary butterflies? air vacuum hoses not collapsing? I don't know too much about the EFI setups :/
Old February 19th, 2015, 11:23 AM   #228
garth285
KAWASAKI GURU
garth285's Avatar
Secondary throttle plates are actually removed from the throttle bodies, they are a no no on turbo's
Old February 19th, 2015, 11:51 AM   #229
cuong-nutz
cuong-nutz's Avatar
How did you set up the line/check valve for your IAP sensor? It feels TB related.
Old February 19th, 2015, 11:55 AM   #230
You are confident the injectors you are using can supply enough E85 at max RPM?
jkv45 is online now   Reply With Quote
Old February 19th, 2015, 12:07 PM   #231
garth285
KAWASAKI GURU
garth285's Avatar
I have a T running inline to the IAP sensor and then on the end of the T it has my check valve to bleed off any boost, and to keep vacuum.
Also I have tried running the bike on just TPS and it does the same thing.
Old February 19th, 2015, 12:08 PM   #232
garth285
KAWASAKI GURU
garth285's Avatar
You generally have to add about 35-40% more fuel to keep E85 Happy. So if it takes a 245cc injector to be equal to running E85 a 330cc injector is about 35% more that needed which should be good with the turbo.
Stock injectors are 175cc/min, I installed 330cc/min injectors. Also am running a 255LPH pump so plenty of flow there, all lines are -6AN
Old February 19th, 2015, 02:23 PM   #233
cuong-nutz
cuong-nutz's Avatar
Boost leak? boost cut off?
throwing darts here
Old February 19th, 2015, 03:35 PM   #234
swarfman64
Master modder
swarfman64's Avatar
Just a thought. Try plug in your secondary butterfly actuator complete, just hanging off the loom. Have it filly operational except not physically fitted to manifold. It uses a tps style 0-5v signal which feeds back ecu.
Old February 19th, 2015, 06:48 PM   #235
garth285
KAWASAKI GURU
garth285's Avatar
It is connected and working I just removed the throttle plates so it's not effective.
As far as boost issues. The bike does it even with the turbo charge pipe off the bike so at zero boost in neutral it has the miss. I'm going to give a few more things a try this weekend when I have time. Work has been kicking my Ass.
Old February 19th, 2015, 07:01 PM   #236
swarfman64
Master modder
swarfman64's Avatar
Perhaps without plates in it, it doesn't find a stopper. during its key on procedure it cycles and most likely sets the ref voltages. just thinking out loud
Old February 19th, 2015, 07:05 PM   #237
garth285
KAWASAKI GURU
garth285's Avatar
Unfortunately it does have a blade stop inside the throttle body but that sensor does run a self check. When I get my kds hooked up I'll see if it's throwing any codes.
Old February 19th, 2015, 11:27 PM   #238
Somchai
Freedom for Germany
Allow me to ask one silly question Shawn, did you mount the speed-sensor?
But also I guess you did.
Old February 24th, 2015, 07:13 PM   #239
garth285
KAWASAKI GURU
garth285's Avatar
OK well I gave the bike a rest a little which timed out good because it was my 30th Birthday yesterday and I had dinners and parties to go to. I finally tonight buttoned the bike back up, going to mess with it more this week, I am going to go grab my buddys KDS cable so I can see if I have any FI lights coming on. I don't have a ninja 300 gauge cluster so I am not sure if something else is going on.
I am going to see if I can get a buddy of mine to try out some other parts, but I think I am getting closer to getting somewhere..... will keep you all posted of course!
Old February 24th, 2015, 07:27 PM   #240
garth285
KAWASAKI GURU
garth285's Avatar
Speed sensor is not plugged in but it does not have to be, I had someone test out on their ninja 300 if the speed sensor was unplugged if it would do anything funky and nothing happened, just showed 0mph
Racer X turbo build Racer x Ninjettes At Speed 313 January 23rd, 2016 11:13 AM
Turbo? Yes, TURBO! Somchai General Motorcycling Discussion 7 December 26th, 2013 12:06 PM
250 turbo on visordown alex.s General Motorcycling Discussion 17 August 29th, 2013 12:39 AM
Turbo 250! dyeforever General Motorcycling Discussion 3 May 1st, 2011 07:07 PM
Turbo Ninja! Neema12 General Motorcycling Discussion 24 July 20th, 2009 07:31 AM
