Old April 16th, 2013, 04:34 PM   #1
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
Coolant leaking from the top of the engine...
How?? I have no idea, I hope warranty will cover it but is there a quick fix?
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound
LoneRonin is offline   Reply With Quote
Old April 16th, 2013, 04:39 PM   #2
Cap on tight?... let' start there.
Old April 16th, 2013, 05:01 PM   #3
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
That would depend on where exactly it is leaking.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old April 16th, 2013, 05:16 PM   #4
Any pics of where the leak looks the worst?
Old April 16th, 2013, 05:45 PM   #5
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Any servise or mods done to it recently?
Old April 16th, 2013, 06:37 PM   #6
LoneRonin
LoneRonin's Avatar
as tight as can be...
Please refer to the link below.
No I just filled it up a few days ago because I noticed the reservoir was empty so I assume it was already leaking...nothing other than that.
Pics can be found here:
http://www.gtamotorcycle.com/vbforum...-of-the-engine
Old April 16th, 2013, 06:50 PM   #7
DaBlue1
DaBlue1's Avatar
Bad o-ring on the head-thermostat water pipe.
Old April 16th, 2013, 06:53 PM   #8
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Ok so this happened to me on my first valve adjustment. The valve cover had never been off before but when I pulled it off I also pulled out the 90deg water pipe you have circled in yellow. The O-ring that goes around the bottom to seal the coolant was all deformed and twisted and had been like that from the factory(no leaks though). I couldn't wait for a new O-ring to arrive so I put it back together as it was since it was working before, no luck though. It started slowly weeping the very next day so 4 days later when the new O-ring arrived I installed it with some ****ing grease and that was that.
If your bike has a similar improperly installed O-ring like mine did then its bound to fail prematurely. You need to start buy cleaning the **** out of you bike and drying it, then warm the bike up enough to pressurize the coolant system and find the exact location of the leak. It's probably an easy fix once you find the right seal to replace or hose clamp to retighten.
Old April 16th, 2013, 06:53 PM   #9
LoneRonin
LoneRonin's Avatar
where is this o-ring found and which one is the head-thermostat water pipe? Is it an easy fix?
Old April 16th, 2013, 06:56 PM   #10
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
It's the pipe you have circledin yellow. It's easy after you remove enough stuff to get to it
Water pipe on engine head leaking cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 14 June 4th, 2020 08:07 PM
2004 EX250 Leaking Coolant After Change drc84 1986 - 2007 Ninja 250R Tech Talk 9 May 21st, 2014 03:11 PM
Coolant leaking into oil and oil leaking out of somewhere. Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 31 May 25th, 2013 04:09 PM
Leaking coolant Chuffmonkey 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2012 11:47 PM
radiator hose burst :( leaking coolant h0yitsdom 1986 - 2007 Ninja 250R Tech Talk 11 June 3rd, 2011 11:06 PM
