May 23rd, 2012, 08:07 AM | #1 |
Drdriftking007
Join Date: Apr 2012 Motorcycle(s): 2007 Ninja 250 Posts: 67
Kick Stand Question
So when I place my bike down on the kick stand i feel like it leans too much to the side. Is there any way to fix this issue?
May 23rd, 2012, 08:11 AM | #2 |
You feel this way even when parked on flat, solid ground?
You could slide a 2x4 or whatever thickness of wood that will raise it up to your liking but unless something is up with your kickstand or your parking on a hill, I doubt it's over to far. In fact you don't want it to stand straight up as it would be easier to knock it over. Got a pic?
May 23rd, 2012, 08:19 AM | #3 | |
Drdriftking007
June 8th, 2012, 02:47 PM | #4 |
Drdriftking007
bump
June 8th, 2012, 02:49 PM | #5 |
Drdriftking007
June 8th, 2012, 04:48 PM | #6 |
Hmmm, that does seem to be over farther than normal. Everything is tight and where it should be right?
Kickstand bent? Because it kinda looks like it is near the mount point. Hard to tell for sure from the pic. Kickstand mount point bent/damaged in any way?
June 8th, 2012, 04:54 PM | #7 |
So you can compare to yours.
June 8th, 2012, 05:30 PM | #8 |
its easy to bend one of the paws on the kickstand if you leave it down and try to turn into it. maybe the previous owner did this. either way, that amount of lean is a non-issue. if anything, its safer in the wind.
June 11th, 2012, 06:39 AM | #9 |
Perhaps a new bracket will suffice?
Would you remove the kick stand sensor? | nr19952910 | 2008 - 2012 Ninja 250R Tech Talk | 18 | April 1st, 2015 02:45 AM |
Kick stand spring came off... | miks | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 25th, 2013 04:07 PM |
damn kick stand... | ninja_thresh_hold | !%@*#$%!)@#&!%@ I crashed! | 7 | July 14th, 2012 09:16 AM |
Kick stand spring | gamma500 | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 7th, 2009 08:50 PM |
center kick stand | mr.niftie | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 15th, 2009 06:18 AM |
