January 15th, 2014, 12:26 AM | #1 |
Join Date: Oct 2013 Motorcycle(s): 2007 Ninja 250 Posts: 86
What does your ninja 250 sound like when warmed up?
I was riding with one my friend that owns a ninja 250, he actually has a 1989 ninja 250 and the engine sounds so smooth compared to mine. My bike makes a gogging and popping noise is that normal? whats wrong?
And I another question for my friend, he recently rebuilt his bike he took it to the shop and got everything done. When we were riding his bike often stalled he said its because the bike over heats a lot, we would have to wait a few mins to start it up. Do you guys know what is wrong? Thank you so much guys. here's the bike in action https://www.youtube.com/watch?v=Tup9...e_gdata_player the stripes on the fender are from previous owner :[ Last futzed with by itslocfoo; January 15th, 2014 at 02:13 AM. |
January 15th, 2014, 12:29 AM | #3 |
January 15th, 2014, 12:31 AM | #4 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
Sounds like you have a platypus in your airbox. Usually takes a crane to get it out.
Your friend on the other hand........he's got a flaming squirrel. Tell him to sell the bike and pray that it doesn't remember his address.
CVMA #531 |
January 15th, 2014, 01:00 AM | #5 | |
speechless. |
January 15th, 2014, 05:56 AM | #6 |
Join Date: Apr 2013 Motorcycle(s): '86 Honda VFR700 Posts: 173
January 15th, 2014, 06:10 AM | #7 |
Idle you say?
putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt putt
January 15th, 2014, 06:17 AM | #8 |
Seriously though, the differences in sound could come from many things;
Exhaust can Air filter Tuning Valve lash Vacuum leaks many many more First check inside your airbox for debris and the condition of your filter. Then check for vacuum leaks by misting some carb cleaner around the carbs, intake and airbox boots and near vac lines.
January 15th, 2014, 06:28 AM | #9 |
dirty boy
MOTM - Apr '14
sounds like an orgasm in my ear hole, not to be confused with someone orgasming into my ear hole
January 15th, 2014, 06:36 AM | #10 |
brum brum brum brum brum brumbrum brum brum brum brum brum click VRUUUUUUUUUM click VRUUUUUUUUM click VRUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUM click VRUUUUUUUUUUUUUUUUUUUUUM click VRUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUM click vroooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooooooooooooooooooooooooooooooooooo red light mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm click VRUM ooooooommmmmmm click VRUM click VRUM ooooooommmmmmm click VRUM ooooooommmmmmm OH GREEN LIGHT VVVVVVVVVVVRRRUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM And then I speed away never to be seen again.
January 15th, 2014, 06:41 AM | #11 | |
1st, your video is marked private 2nd, Tell you friend to check the coolant level in this bike. If it's full, he may have to burp it. Or more rare, but if the cap is damaged it may need to be replaced.
January 15th, 2014, 07:46 AM | #12 | |
Check that the overflow bottle is at the proper level, then remove the cap (engine has to be cold) and confirm the level in the radiator is up to the top. If so, you need to look farther. Most likely either the thermostat is not opening properly or the radiator itself is plugged - but I wouldn't ride it until you have it figured out and fixed. |
January 15th, 2014, 09:29 AM | #14 |
Wouldn't the pipes glow red as well with that? I dunno if that is a dumb question or not. I have never been THAT far off on my jetting to overheat an engine.
January 15th, 2014, 09:32 AM | #15 |
depends on the air temp. if its cool outside, the pipes get great convection cooling but if its hot they'll definitely glow. even if the engine temp is fine you can glow your pipes from hard work. (well you know, depends on the material of the pipe)
honestly if your cooling system is working at all it shouldn't be able to overheat. it probably just needs to be flushed with some new stuff. i bet its looking mighty black right now
What is this sound? Is this what out-of-spec valves sound like? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 24 | November 15th, 2021 05:48 PM |
Sputters When Warmed Up | Scattcatt | 2008 - 2012 Ninja 250R Tech Talk | 17 | November 10th, 2017 01:29 PM |
Does your 250 sound like a Moto GP Bike? | rojoracing53 | Videos | 10 | February 13th, 2013 10:47 PM |
[topix.net] - Have Your Heart Warmed By Biker Saving Drowning Calf | Ninjette Newsbot | Motorcycling News | 0 | October 27th, 2011 01:50 PM |
[topix.net] - 2011 KTM 250SX Motocross Test: not a Warmed-Over BNG Bike, but a... | Ninjette Newsbot | Motorcycling News | 0 | February 28th, 2011 08:30 PM |
