Old March 26th, 2010, 05:39 PM   #1
divingtigger
Pedal Power
divingtigger's Avatar
Motorcycle(s): 2008 Ninja EX250R
Aftermarket undertail questions
Ok quick question for those of you with aftermarket undertails. What do you do with the parts that attach to the factory undertail?? Like the fuse box and the other stuff (computer thingy...name really escaping me right now)
Thanks
Using Pedal Power
divingtigger is offline   Reply With Quote
Old March 26th, 2010, 05:46 PM   #2
Momaru
Momaru's Avatar
I don't have an aftermarket undertail, but why not get a roll of double-sided foam tape or a few feet of velcro and just attach those components to the new tail?
Proud member of the Blue Army
Old March 26th, 2010, 07:29 PM   #3
deezyellownutz
deezyellownutz's Avatar
Motorcycle(s): 2007 Zx10R 2009 250R
I believe if you look at the HotBodies install for example, you "trim" the tray so the undertail fits over it but you still retain most of the needed parts to hold things together.
2007 Kawasaki ZX10R Red
2009 Kawasaki EX250R Special Edition
deezyellownutz is offline   Reply With Quote
Old March 26th, 2010, 07:46 PM   #4
divingtigger
Pedal Power
That might fix my fitament issues as well. Going to have to see if it will all fit together trimmed.
Using Pedal Power
Old March 26th, 2010, 08:54 PM   #5
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
I'd loose everything and velcro the rest into the new undertail.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old April 3rd, 2010, 08:05 PM   #6
kenji_808
Motorcycle(s): 2009 CT Blue 250R(Sold), 2008 Black & Silver Honda CBR600RR(Current)
for the hotbodies undertail kit
DO NOT CUT THE ENTIRE STOCK UNDERTAIL PLASTIC...
if you do your tail will sag and
you'll have real bad fitment issues with your passenger seat or seat cowl
how do know this? i did it my self so lesson learned guys
Posted via Mobile Device
kenji_808 is offline   Reply With Quote
Old April 4th, 2010, 03:42 AM   #7
welcome2thedawn
welcome2thedawn's Avatar
Motorcycle(s): 08 ninja 250r modded, 73 honda cl200, 74 kawasaki 400 triple
i have the hotbodies undertail...i just used a dremal tool and cut about an inch off each side of the black plastic piece...i know mine was a tight fit, but i got it on...also they say you should remove the brake reservoir...i did, but tried to cheat and leave some of the small metal pieces and scraped some paint off...i'd definately take off all the screws and the metal piece that it attaches to and cover that piece with a cloth
welcome2thedawn is offline   Reply With Quote
Old April 9th, 2010, 07:48 AM   #8
deezyellownutz
To late, I trimed an inch off the sides and it fits, it sags and looks like crap... I ended buying another undertray from ebay. $25... anyone looking for a hotbodies undertail? lol
Old April 9th, 2010, 11:14 AM   #9
divingtigger
Pedal Power
All that I did was zip tie the things to the cross members. Seems to work good.
Using Pedal Power
Old April 9th, 2010, 02:21 PM   #10
welcome2thedawn
what color?
Old April 9th, 2010, 05:46 PM   #11
deezyellownutz
Its unpainted. I still have the box and all. I did a test fit and now I am trying to decide if I want to go with it or not. All the directions and packaging is included.
Old April 13th, 2010, 12:52 PM   #12
FerociousNINJA
Motorcycle(s): 2008 Ninja TwoFiddy
Thumbs up
I'm going to be doing this install soon. Good feedback.
FerociousNINJA is offline   Reply With Quote
Old April 13th, 2010, 01:42 PM   #13
draco413
draco413's Avatar
Motorcycle(s): Blue 09 Ninja 250
just got mine today and starting to get intimidated about install it after reading the thread a lil. i think i might wait till i do the airbox delete
draco413 is offline   Reply With Quote
Old April 13th, 2010, 02:15 PM   #14
Yoda
Yoda's Avatar
Motorcycle(s): 08 Kawasaki Ninja 250R Blue
The install really is not bad if you have everything on hand that you need.
With the hotbodies kit it took trimming the stock undertail roughly an 1/8th to 1/4 inch back for everything to finally snug right up nice and tight. Took me way to long cause of multiple trips to the parts store for lost bolts and an LED turn signal flasher.
Mmmm when gone down you have look so good you will not.
Yoda is offline   Reply With Quote
Old April 13th, 2010, 03:46 PM   #15
draco413
draco413's Avatar
anybody think it would be a good idea to remove the stock undertail tie up the parts on the existing one, epoxy the tail light in put in disconnect for the lights and and mount or not a good idea or will not work
Old April 13th, 2010, 04:03 PM   #16
Yoda
Yoda's Avatar
Which kit did you get?
Old April 13th, 2010, 04:30 PM   #17
Momaru
Momaru's Avatar
Doesn't the paint on the undertails get all chipped from road debris?
That aside, how's brightness on the lighting for the turn signals?
Old April 13th, 2010, 04:41 PM   #18
draco413
draco413's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...27476542967401 link to a pic
Old April 13th, 2010, 05:11 PM   #19
Yoda
Yoda's Avatar
I have the smoked plastic because I figured road debris would ding up the paint. The LED turn signals are pretty darn bright IMO. Stock tail bulb is still bright thru the smoked plastic.
Instructions from hot body werent the greatest and you WILL need an aftermarket flasher to make the turn signals work.
A dremel with cutting attachment will be your friend, my recommendation is to trim a little at a time and keep test fitting it.
Ended up looking like this (just got the exhaust put back together from my paint project today)
Old April 13th, 2010, 05:23 PM   #20
Momaru
Momaru's Avatar
That ebay undertail looks like it was rattle-canned by a 3rd grader...
Exhaust repaint looks great Lee!
Old April 13th, 2010, 08:44 PM   #21
draco413
draco413's Avatar
yea i agree i even questioned him about that and it was the lighting cause from the pic and the first thing i did when i got it was put it next to the bike to see that match and it a lil darker than the bike but not noticeable unless ur really staring it down.....and what part are u supposed to trim down im totally confused about that.....i know the stock undertail but what part the edge where u screw it to the frame????? im confused
Old April 14th, 2010, 12:39 AM   #22
welcome2thedawn
here are a few pics of where i cut mine...also the part where my thumb is needs to be bolted up...if it's sagging i can't imagine what else would be pushing it down...it's also a pretty tight fit and since that top part goes over your light, i would think as long as the black plastic is attached to the frame, it shouldn't move
Old April 14th, 2010, 07:19 AM   #23
FerociousNINJA
Arrow
To my knowledge... yes. You will need a wheel hugger so the paint doesn't get torn up.
http://www.kawiforums.com/ninja-250r...product-4.html
Thx for posting the photos Dawn.
Old April 14th, 2010, 11:41 AM   #24
Brently7785
NinjArmy
Brently7785's Avatar
Motorcycle(s): 2009 Ninja 250R Diablo Black (SOLD)
I have the Traga fender eliminator kit. Looks amazing ans was easy to install. I would go that way if you are looking to do NO CUTTING like I did!
Brently7785 is offline   Reply With Quote
Old April 14th, 2010, 02:53 PM   #25
draco413
draco413's Avatar
@ dawn thanks for the pic now i know where to cut.....@ brent any pics....@ yoda did u use L brackets that came with the undertail?
Old April 14th, 2010, 03:22 PM   #26
Yoda
Yoda's Avatar
Dawns pics definitely show the areas you need to trim back. If you take your time and trim a little at a time the thing will fit tighter then (insert cliche here)
Yes I used the L brackets that came with it and mounted the plate just behind the signals where the plate light gets.
I actually checked with a couple cops in my area before I did this and they said as long as the plate is mounted horizontal and easily visible I would be good.
Old April 15th, 2010, 04:38 PM   #27
draco413
draco413's Avatar
ok so just finished install the undertail.....and guess what im about 99% sure ya guna need to use the stock undertail......it all saggy and sad looking....not really but it does look better besides the sag.....guna post pictures of it soon....but im guna wait till saturday and try with the stockundertail
Im So Cereal
Old April 15th, 2010, 04:44 PM   #28
Yoda
Yoda's Avatar
Yes the hot bodies undertail sandwiches against the stock undertail and the fairings slide over it to lock everything down
Only thing i had to do was zip tie the stock undertail up behind the tail light since once you drop the banana fender the bolt brackets etc are gone.
Im available for PMs, AIM or other methods if folks need more help with the Hotbodies install.
Old April 16th, 2010, 12:30 PM   #29
welcome2thedawn
if you're still having problems, maybe you should contact hotbodies...i had a question, and someone called me back right away....i don't understand what would be making it sag....do you have your tail light put in....it seems like the light fits in there so thight, and that thin piece goes over the light...i don't understand what wouldn't be holding it up
Old April 16th, 2010, 01:31 PM   #30
Davidb1986
Davidb1986's Avatar
Motorcycle(s): 2009 Ninja 250r SE green with Monster energy decals!!!
How much for the hotbodies undertail?
Now who wants to live their souls desire? One day we're born to realize. One sobering thought is forced upon. We should know, we'll know!!! - Leto's Headache by the band Chevelle
Davidb1986 is offline   Reply With Quote
Old April 17th, 2010, 07:07 AM   #31
draco413
draco413's Avatar
@yoda i have an idea to cut off the rivets from the banana fender and trim them off of the fender and possibliy drill some holes in the tail next to the holes where the screw went so i can still use the the same bolts and i might be PMing u.....@ dawn i was seeing how it looked without the stock undertail in place going to do it this afternoon with the stock undertail in place but i will surley call them if im still having problems
Im So Cereal
Old April 17th, 2010, 01:14 PM   #32
Yoda
Yoda's Avatar
I still have the bolts and banana tail pieces and had considered cutting the threaded part off the tail piece and reusing the bolts but after 12 hours of screwing with it i really did not feel like taking it all back apart just to do that. So zip ties worked fine. Shouldnt be a problem if you do the cut before you have it all back together.
Old April 17th, 2010, 07:46 PM   #33
FerociousNINJA
Exclamation
Can someone post photos of the saggy tail? And did the foot peks have to be removed?
Old April 17th, 2010, 09:08 PM   #34
draco413
draco413's Avatar
so just finished redoing the undertail.....everything is tight fitting but my passanger seat has a huge gap around it anyone else have this
Im So Cereal
Old April 19th, 2010, 12:09 PM   #35
FerociousNINJA
Arrow
I just did my install and a writeup.
http://www.ninjette.org/forums/showthread.php?t=42661
Old April 22nd, 2010, 12:52 AM   #36
Yeah. I noticed that the CP Blue one wasn't all that good either when the first guy to get one posted it up on Kawiforums.
It's not so visible in the video but it's obvious in the photos.
Hotbodies Undertail? SSANGHA 2008 - 2012 Ninja 250R Farkles 3 November 9th, 2012 03:05 PM
undertail help? ehanda 2008 - 2012 Ninja 250R Farkles 8 September 3rd, 2012 07:39 PM
Aftermarket slipon with aftermarket header Jojah17 2008 - 2012 Ninja 250R Tech Talk 10 July 20th, 2011 07:58 PM
Aftermarket Gauge Questions? Kevin2109 2008 - 2012 Ninja 250R Tech Talk 13 June 15th, 2011 01:16 PM
WTB aftermarket slip on exhaust and undertail Shaol1n Monk Items Wanted 1 May 31st, 2011 03:51 PM
