Old April 28th, 2013, 01:31 PM   #1
woofer987
Causual Browser
Motorcycle(s): 2010 Kawasaki Ninja 250R
Occasionally shifts to neutral from 1st to 2nd
I have an interesting thing that has happened to me on ocasion. Sometimes when I am accelerating fairly hard, my bike shifts from 1st to neutral rather than to 2nd. I know im applying enough pressure to the shifter so it will go into 2nd, but It still does it. Usually only on hard acceleration. other than that its fine when shifting and I haven't had any other problems with it.
Be not afraid of going slowly, be afraid only of standing still.
woofer987 is offline   Reply With Quote
Old April 28th, 2013, 02:28 PM   #2
Joshorilla
Bass Master General
Joshorilla's Avatar
Bumps and stuff do this for me, i'm sometimes in second and a pothole will take me into neutral.
Old April 28th, 2013, 02:51 PM   #3
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
This happens to me on ocassion between 2-3 under WOT but usually miss shifts and stays in 2nd instead of going to third..also happens between 3-4. It rarely ever goes into nuetral but just missing engagement between gears. I chock it up to just being a typical Kawi tranny. I was spoiled with Hondas when I raced offroad..bare none best shifting...every Kawi MX bike I owned had notchy shifting.
Try being mindful when shifting making sure you follow through all the way with your shift. If your still popping into N then it could possibly be an internal problem. Adjusting your shifter can help quite a bit.
kirk595x is offline   Reply With Quote
Old April 28th, 2013, 09:19 PM   #4
woofer987
Causual Browser
Alright this makes me feel better about it. Every time it happened I would pull over and let it sit for a minute haha. Thanks!
Old April 28th, 2013, 09:53 PM   #5
Bob2010
Bob2010's Avatar
Yeah. I still do that sometimes. Nothing is funnier than hearing me take off hard in first then rev the piss out of the imaginary gear before 2nd
2010 Red Ninja 250
2009 Black Ninja 250
Old April 28th, 2013, 09:56 PM   #6
woofer987
Causual Browser
Yeah I'm glad I'm not the only one
Old May 6th, 2013, 07:52 AM   #7
wsrussell7
Motorcycle(s): ninja 250r
I have this happen occasionally, but do yall ever have the problem where you cant get into to go into gear? Like it'll be either stuck in neutral or a different gear. I have to let out the clutch some if its in gear, and then pull it back in and switch gears.
wsrussell7 is offline   Reply With Quote
Old May 6th, 2013, 08:00 AM   #8
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Never when in motion, but at stops i think it is pretty common and a simple rocking back and forth with the clutch in will allow you to get the bike to shift.
Old May 6th, 2013, 08:52 AM   #9
Welcome wsrussell7!
300 Slipping out of 2nd and into neutral anacron 2013 - 2017 Ninja 300 Tech Talk 38 June 7th, 2016 09:36 AM
Going from 1st to 2nd I hit neutral?? TwoWheelNinja General Motorcycling Discussion 6 October 10th, 2012 07:49 PM
Downshifting by itself from 2nd into neutral?? azimmer11 2008 - 2012 Ninja 250R Tech Talk 6 August 15th, 2012 08:23 AM
1st Gear or Neutral when at a red light? ajcadoo General Motorcycling Discussion 27 April 21st, 2012 09:32 PM
Shifts "hard" in 1st - 3rd athimmel 2008 - 2012 Ninja 250R Tech Talk 10 July 8th, 2009 11:44 PM
