January 4th, 2014, 11:14 AM | #1 |
Join Date: Dec 2013 Motorcycle(s): '04 Ninja 250R Posts: 367
is this normal?
so sorry for making new threads all the time. =/
i have a 2004 ninja 250r. it has 2600 miles in it the only mod i had is a 15 tooth front sprocket. (this problem below has been there before this mod). Its been serviced completely since it was sitting for 8 years covered in a storage.. im not sure if the carbs have been cleaned by the previous owner just guessing they where when it got serviced. My question is, when im in 6th gear and i twist the throttle all the way down to where it stops, it feels as if the bike it bogging out, feels as if its getting sluggish. but when i release the throttle little bit from the stopping point (like barley twist my wrist up) it picks up and i can feel the power as its gaining speed. IS THIS NORMAL? or is it dues to dirty carbs. i hope i explained this good enough. |
January 4th, 2014, 11:17 AM | #2 |
maybe dirty carbs, maybe dirty air filter, maybe just bad jetting. it may have had different exhaust on it but the PO put the stock exhaust back on without putting stock jets back.
you really can't trust someone when they say full service completed. 9/10 times its bullshit. check all your fluids, clearances, and clean your intake filter and carbs
January 4th, 2014, 11:19 AM | #3 |
^^^^ what he said
Not normal. After you do the easy stuff, check for shims on the carb.
January 4th, 2014, 11:21 AM | #4 | |
ill check the air filter and look into the cleaning the carbs. i dont wanna pay the stealership for this. so ill be doing it myself. |
January 4th, 2014, 11:58 AM | #6 | |
Your pre-gen looks like new; hence, she maybe fully stock. What happens is that the engine is receiving too much air suddenly, because the internal mechanisms that the carburetors have to compensate for your input are not working properly. Rather than doing surgery now, I would continue rolling the bike as is. The more gasoline goes through the carbs and engine, the better for this baby to come back to life. Besides giving gas more progressively, as you should, one way to reduce that problem is to keep the engine above 8,000 rpm. If the problem persists after 1000 more miles, then it may be time for a full carb cleaning.
January 4th, 2014, 12:06 PM | #7 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
I would guess it's a carb issue. It might not have the stock main in it either. If I were you I would take the carbs off and see if anything is shimmed, or the jets have been changed.
January 4th, 2014, 12:06 PM | #8 |
Stock main is 105
January 4th, 2014, 01:12 PM | #9 |
January 4th, 2014, 01:18 PM | #10 |
Where did you take it in Kern? I know someone who runs a great shop in that area if you are looking for someone trusted to peek at the carbs.
January 4th, 2014, 01:24 PM | #11 |
January 4th, 2014, 01:29 PM | #12 | |
Yea it was in awesome condition when I bought. Looks show room new! I'll take your advice thanks man. It is fully stock besides the 15toothe sprocket I put on it. |
January 4th, 2014, 02:04 PM | #13 |
is that true? i had no idea pregen carbs were set so rich. must have been before the ARB and al gore kicked in.
for newgen stock jets are #98/#38
January 4th, 2014, 02:30 PM | #14 | |
I think even with a pod filter and full exhaust, I'm on 110 mains? idk. I'll have to go check. Thanks for the reminder. |
January 7th, 2014, 09:29 AM | #15 | |
January 7th, 2014, 10:57 AM | #16 |
January 7th, 2014, 01:01 PM | #17 |
Yes, Seafoam has helped me delay disassemble-cleaning work, .......... or so I believe.
Daily rides have no substitute.
January 13th, 2014, 03:04 PM | #18 | |
Join Date: Nov 2013 Motorcycle(s): Ninja 250 2001 KX125 2001 Posts: 85
my dirt bike did the same thing and it was a jetting issue |
January 13th, 2014, 03:47 PM | #19 |
January 13th, 2014, 05:01 PM | #20 |
January 14th, 2014, 01:02 AM | #21 |
January 14th, 2014, 01:33 AM | #22 |
Join Date: Jan 2013 Motorcycle(s): 03' Ninja 250ex Posts: 333
I'm a firm believer in Seafoam. I've ran it through every used vehicle I've had with good results. Also try "Startron" as a routine treatment...helps with the Ethanol in our Cali Fuel. If the bike is gonna sit for more than a few days then definitely have one of those treatments ran through the fuel system before non-op.
Perform Random Acts of Coolness!!ATGATT |
Is this normal? | bkc888 | 2008 - 2012 Ninja 250R Tech Talk | 8 | May 25th, 2012 06:07 PM |
Is this Normal? | AmplexorJ | 1986 - 2007 Ninja 250R Tech Talk | 28 | April 12th, 2012 08:21 AM |
Is this normal? | CynicalC | 1986 - 2007 Ninja 250R Tech Talk | 12 | November 16th, 2011 09:16 AM |
Hello from Normal | thisisbenji | New Members | 25 | September 8th, 2011 04:00 PM |
Is this normal? | kaiserz | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 9th, 2011 05:41 PM |
