September 27th, 2015, 02:18 PM | #1 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Mirror Image!
Went for a cool, crystal clear, autumn ride this morning on the KLR250 around West Seattle via Ambaum, Marine View Drive, Alki, West Marginal Way, and Burien Freeway. Lovely low-traffic ride: the baby KLR is just right for rough pavement, potholes, and urban streets.
Noticed something kind of interesting on the freeway: the image in the left-hand mirror is significantly better (less vibration) than in the right-hand mirror. Any ideas as to why? Clutch basket and exhaust system are on the LH side of bike. But any frame vibration to the mirrors is fed through the steering head bearings, wiring, and cabling. Any thoughts? Or similar (or different) observations? |
September 27th, 2015, 02:25 PM | #2 |
Maybe the bushing/ball in the articulating joint isn't tightened down and the mirror is shaking? Is one easier to move than the other when you adjust the mirrors?
Or maybe there's something slightly different about the mounts? idk. Small differences in the base with a cantilevered weight might make just enough difference in vibration frequency that you could notice it visually in the mirror's movement. |
September 27th, 2015, 02:52 PM | #3 |
And what do you see in the mirror? Does it look like this?
September 27th, 2015, 03:44 PM | #4 |
Participant
Only when I look at myself (in either mirror).
September 28th, 2015, 05:37 AM | #5 |
The vibration reaching the steering head is the same, but how it behaves from that point on depends basically of the mass of each side, including the handle bar half and things mounted on it.
Everything has a natural frequence regarding vibrations, the half or side that vibrates more has a natural frequence that is closer to the frequence of the vibrations reaching the steering head. You could experiment adding some weight to the right mirror or right side of the handlebar.
September 28th, 2015, 05:37 PM | #6 | |
Participant
But first, I will try to determine qualitatively if the two mirrors behave differently from each other at various frequencies (RPMs). Fortunately, the vib in the baby KLR mirror is not debilitating. (K75 has no apparent mirror vib, by the way. Smooth...). |
[superbikeplanet.com] - Soup Random Image Servermatron Thing (click on image to refre | Ninjette Newsbot | Motorcycling News | 0 | January 21st, 2015 04:21 PM |
WTT for left stock mirror or mirror set | Aodrn | Motorcycle-related | 8 | September 28th, 2014 08:42 PM |
Love this image | Apex | Off-Topic | 1 | February 9th, 2012 10:04 PM |
