Old November 2nd, 2014, 11:01 PM   #1
xomilin
Motorcycle(s): 07 EX250
Bike hates the cold starts.
I've been having to leave early in the mornings on my bike and its about 40'F so not that cold yet, and my bike is nearly completely draining the battery before I can ever get it to start to actually run. Slightly warmer temperatures its been perfectly fine, so I was wondering if anyone had any suggestions on ways to fix this. Its my only transportation aside from borrowing my dad's bike when I absolutely have to so I need it to work!
PS. Had major compression issues before, got them all worked out so hopefully I dont need to mess with that again.
would messing with the fuel mixture be a good idea..?
Thanks in advance!
xomilin is offline   Reply With Quote
Old November 3rd, 2014, 02:16 AM   #2
Ghostt
Ghostt's Avatar
Are you apply the choke properly?
violente et ignorantia
ZX-2R BLOG
Old November 3rd, 2014, 05:22 AM   #3
xomilin
Fully engaging the choke to start. Normally when I use choke it'll Rev up to about 4k and slowly drop. But the lever is not backing off.
Old November 3rd, 2014, 05:30 AM   #4
allanoue
allanoue's Avatar
MOTM - Sep '14
Can you post a video of a cold start?
Old November 3rd, 2014, 05:52 AM   #5
Ghostt
Ghostt's Avatar
When as the last time the carburetors were cleaned?, is there a fuel filter installed? Sounds like your carbs are in need or a cleaning maybe.
ZX-2R BLOG
Old November 3rd, 2014, 05:58 AM   #6
Ghostt
Ghostt's Avatar
http://faq.ninja250.org/wiki/What_is..._at_startup%3F
ZX-2R BLOG
Old November 3rd, 2014, 06:00 AM   #7
xomilin
I bought the bike about 3 months ago.. for a month it was in the shop getting the compression worked on. I know they had to repair parts of the carb, but that's the closest to a Cleaning that I can document.
And i got a video just uploading.
Old November 3rd, 2014, 06:01 AM   #8
xomilin
Old November 3rd, 2014, 06:52 AM   #9
agentbad
agentbad's Avatar
When I first got my bike I had the same issue until I cleaned my choke inside the carbs. Changing the spark plugs can help to then set the fuel screws 2.5 turns out.
Old November 3rd, 2014, 08:21 AM   #10
Is the battery in good condition? Is it spinning the engine over strongly? Check the voltage before you try to start it - you should get 12.7V or very close. When you are cranking it over, check it again - you should see 11V or around there. If it's 10V or below it's not enough.
What oil is in it? Running a 5W-40 synthetic oil like Rotella T6 will increase cranking speed over a 10W-40 oil and may help.
How fresh is the gas? If it's been sitting with summer-blend gas in it for a while and it's in the 40s now it won't want to start easily. Fresh 87 octane without ethanol is your best choice, but go up in octane only if you need to get away from ethanol. Keep the tank as full as possible to avoid condensation forming.
Running a strong fuel system cleaner like Techron Concentrate at 1oz per gal once a year is a good idea, as is adding a stabilizer and draining the float bowls if you are planning to store it in the off-season.
You also may need to make carb adjustments. Cold air will make a carbed bike run leaner, so if it's tuned for summer gas and 80F temps it isn't going to run the same on winter gas at 40F.
After it's fully warm make adjustments to the idle mixture screws (turning out is richer) and then set the idle speed to 1300.
Old November 3rd, 2014, 08:22 AM   #11
xomilin
http://youtu.be/mHiFUahZUdI
Old November 3rd, 2014, 08:29 AM   #12
Try backing off the choke some or opening the throttle slightly - it's close.
I wouldn't crank over and over for that length of time consistently. Make some changes and find the "sweet-spot".
It was almost to the point where the battery needs to be charged. I think you will need to make some carb adjustments when it's fully warm.
Old November 3rd, 2014, 08:29 AM   #13
If the jetting is stock, then my best guess that the above cleaning and adjustment will take out most of the cold nature that your bike has. The choke and other "hidden" passages are commonly untouched when a carb is cleaned. Many just clean the jets and go. And of course, you need a good strong battery.
Good luck!
Old November 3rd, 2014, 08:31 AM   #14
Ghostt
Ghostt's Avatar
Originally Posted by Ghostt View Post
Once again, read the above, and try that, also it seemed close a number of times, keep cranking it over, don't stop when it starts to catch .
ZX-2R BLOG
Old November 3rd, 2014, 08:34 AM   #15
xomilin
Yeah just got a new battery for it yesterday so before it would have died after about 6 attempts.
Old November 3rd, 2014, 08:38 AM   #16
I agree - you can continue to crank a bit longer instead of letting off when it is just starting to catch.
As soon as it sounds like it has enough fuel to catch you might try backing the choke off or giving it a little throttle.
Old November 3rd, 2014, 08:39 AM   #17
KY representin'
Dat be gitin' him rollin' but he be needing ta fix dat cold natured issue as well. Addressin' da symptoms only be allowin' da prollem ta git worser and I figger it's maskin' a bigger prollem in dem carbs. It aint real good for da stater eider.
Old November 3rd, 2014, 08:46 AM   #18
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
Open the throttle all the way as you try to start it with the choke to get as much fuel in as possible, and once like it sounds like it will start then close the throttle and allow it start.
Honestly though, i don't think your compression issues are worked out cause it just does not sound right when you try to start it, in fact it sounds like it has low compression and requires the cranking of the engine to heat it up enough to seal it and raise the compression to finally start it.
Listen to how the sound of the engine changes after a few seconds of running where the thumping stops and then you get a nice engine purr.
Old November 3rd, 2014, 08:49 AM   #19
When was the last valve check/adjustment?
Old November 3rd, 2014, 08:59 AM   #20
Skullz
Skullz's Avatar
You could try something like this on a timer set for a few hours before leaving to work.
It should bring the temp up enough to get it to start fairly quick.
http://www.northerntool.com/shop/too...9139_200339139
Old November 3rd, 2014, 09:34 AM   #21
xorbe
xorbe's Avatar
This! Solved all my cold start problems. I don't even use the choke now (California though).
Old November 3rd, 2014, 10:55 AM   #22
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Check cold compression then try spraying some gum cutter into the air box. If it starts right up then you need more fuel. Check choke circuit in carb then richer idel screws or pilot jetting.
Worlds fastest 250 ninja
Old November 3rd, 2014, 10:59 AM   #23
Ghostt
Ghostt's Avatar
The OP just needs to learn how to use the choke, at the most his carbs need a meticulous cleaning.
ZX-2R BLOG
Old November 3rd, 2014, 02:27 PM   #24
allanoue
allanoue's Avatar
MOTM - Sep '14
It isn't fuel injected. You have to give it way more throttle when it cough a bit. That is all.
Edit:
Having said that: csmith12 and Racer X know there stuff.
Bike starts better cold than on a hot day? SqueezyCheez 2008 - 2012 Ninja 250R Tech Talk 8 August 11th, 2014 12:20 PM
cold starts gkarats 2008 - 2012 Ninja 250R Tech Talk 4 October 30th, 2013 02:14 PM
Engine dies during cold starts, normal? caineroad 2008 - 2012 Ninja 250R Tech Talk 9 October 24th, 2013 04:10 AM
Hard cold starts after valve adjustment n4mwd 1986 - 2007 Ninja 250R Tech Talk 2 October 19th, 2011 10:23 AM
Bike running too cold? Is that even possible? TreyE 1986 - 2007 Ninja 250R Tech Talk 19 October 21st, 2009 04:33 AM
