Old November 20th, 2013, 12:34 PM   #1
ans008
Motorcycle(s): 08 Ninja 250R
Weak Vacuum
So a while back I had to replace my fuel petcock as it was damaged, but I am still running into the same issue; bike will only run with petcock in PRIME position. I disconnected the vacuum hose at the carb with the bike running, and I found that there is VERY little vacuum present. Do any of y'all have any ideas as to why this is happening? The bike runs perfectly fine otherwise.
ans008 is offline   Reply With Quote
Old November 20th, 2013, 12:39 PM   #2
Damaged hose or plugged vacuum port?
Old November 20th, 2013, 12:42 PM   #3
ans008
I just pulled the hose itself off and it was free of any obstruction. Where do I go from here?
Old November 20th, 2013, 01:17 PM   #4
ans008
Ok I figured out what the issue was! As it turns out, the previous owner did route the vacuum hoses correctly. Everything is running fine now.
Front brakes getting weak over time. agentbad 1986 - 2007 Ninja 250R Tech Talk 5 June 19th, 2014 12:05 PM
weak rear brake -- a feature, not a flaw AlanDog General Motorcycling Discussion 14 May 17th, 2012 09:12 PM
Weak-ish Brake saxnbass 2008 - 2012 Ninja 250R Tech Talk 6 February 26th, 2012 07:11 PM
I'm Weak.... onetruevibe Off-Topic 32 June 17th, 2011 08:48 PM
Gas Tank, is it this weak? Betlog 2008 - 2012 Ninja 250R Tech Talk 5 January 16th, 2010 03:55 PM
