Old February 25th, 2012, 03:42 PM   #1
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
Weak-ish Brake
So a while ago, I put a stainless steel brake line on my Ninja's front brake. After installing it, I felt like the brake was weaker than it was with my OEM line on it. Having thought I may have just gotten some fluid on the break pads, I was just a bit more cautious and didn't think much of it. After a while of it not improving, I had a place look at it, and they said it should be fine, they see no problems with it. It still bothered me though, so I took it to another place a bit after and had it the brake line completely re-bled and the fluid replaced. Honestly, that didn't improve anything. So what should I do next? Do you guys thing it's the brake pads? If it is, should I have it replaced with EBC HH pads or should I try to have the stock pads fixed? I found something about glazing and fixing it by taking off the pad and lightly going over it a couple of times with 400 grit sandpaper.
I've been on my friend's 250 and his has a steel brake line as well, and his brake is much much stronger than mine. I'd really like to get my front brake working nice and strong, but am not sure what to do at this point.
saxnbass is offline   Reply With Quote
Old February 25th, 2012, 03:46 PM   #2
outasight20
outasight20's Avatar
Motorcycle(s): 2005 Yamaha FZ6
First thought was air bubbles in the line. Does the lever feel firm? Or squishy?
But you said they bled and refilled your lines. I guess if you trust someone else working on your brakes (I don't) then you shouldn't have any air bubbles.
I would try sanding the rotor with water and 400 grit paper, same with the surface of the pads. If that doesn't help, then I'm stumped.
outasight20 is offline   Reply With Quote
Old February 25th, 2012, 05:14 PM   #3
I would replace the pads.
If they got contaminated with oil, brake fluid or gasoline, they will not improve.
They have to be replaced eventually; hence, why not buy and try new ones and eliminate that factor.
If the problem is another one, you could always reinstall the original pads until they finish their useful life.
It is important to have the front brake at full capacity.
Old February 25th, 2012, 07:25 PM   #4
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
If it's not the pads, stumped
Old February 26th, 2012, 10:38 AM   #5
leed
leed's Avatar
Motorcycle(s): Time will tell
If you think it's the pads.. Swap the rear pads for the front pads to see if you can tell the difference. Stock pads on our 250's are Sintered HH already, so if you can't tell the difference with the rear pads up front (assuming they haven't been contaminated), then that's not the issue. Hopefully, though, it is.
Old February 26th, 2012, 11:03 AM   #6
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
here's a sweet trick i've learned for speed bleeding the ninja front brake at the track since the fluid tends to boil after every session, and works every time:
1) hold the front wheel with both hands front and back
2) press on the brake caliper with your knee so you compress the brake pad all the way into the caliper (or if it hurts just press enough to get a wood or plastic pry bar in there). This pushes all the fluid out of the caliper and often some bubbles with it, that won't get bled out using the normal method.
3) pump the brake lever for the first few mm of the lever stroke. Bubbles tend to get trapped right at the beginning of the stroke in the stock master cylinder.
4) then pump the brake until it is firm.
If that doesn't make the lever feel better, then get some vesrah brake pads: http://kurveygirl.com/shop/product_i...roducts_id=353
Rexbo is offline   Reply With Quote
Old February 26th, 2012, 07:11 PM   #7
racegunnr
racegunnr's Avatar
Motorcycle(s): 09 250r race bike, 06 R6 race bike, 06 YZ450f Tard
when i replaced the front line and pads it took forever to get a firm lever. even after using my power bleeder, thinking i got all the air out of the lines, still had a soft lever. i let her sit overnite, and the next day bled them again and still had alot of air in the caliper. took about another 30mins of bleeding, but, finally got a strong lever.
those front calipers are a biotch to bleed.
racegunnr is offline   Reply With Quote
ATG-ish as of today. Ninja Bob Motorcycle Gear 17 May 11th, 2014 09:06 PM
New-ish rider Insan3guy New Members 9 June 25th, 2013 03:30 AM
weak rear brake -- a feature, not a flaw AlanDog General Motorcycling Discussion 14 May 17th, 2012 09:12 PM
Custom Gauges: Tutorial-ish A7xschecter6661 1986 - 2007 Ninja 250R Farkles 10 August 22nd, 2011 08:36 PM
New rider with new(ish) 250! rodeo New Members 10 April 25th, 2011 10:40 PM
