Old September 27th, 2014, 07:55 PM   #1
Citykid
Motorcycle(s): Many
Carb issues?
2011 ninja 250. When I got this bike the air box had been removed and there was no filter. Obviously a problem but the bike ran and was cheap. I put a k&n pod on it and suddenly it won't hardly run. So with no filter I can see air/fuel blowing out the no1 carb. Checked timing, valve clearance, and did leak down and all were good. Pipe is stock. When bike is idling I can see the slides fluttering and sometimes when I open the throttle they just continue to sit there and flutter. I cleaned the carbs and put 40 pilot and 110 main jets. Still same condition. Going to go back to stock jetting. 38 pilot and 98 main w/ fuel screw 3 turns out. Spark plugs are black but I can't figure out how it can possibly be too rich. I'm truly stumped. Please help.
Citykid is offline   Reply With Quote
Old September 28th, 2014, 02:09 PM   #2
Citykid
Motorcycle(s): Many
So finally found a video of what my carb is doing.
http://www.youtube.com/watch?v=N9a4h9zSODc
Exhaust valves are all .009" and intake valves are all .007"
Leak Down test showed 2% leakage.
Is this an engine problem or carb? Seems like the carb is over pressurizing the bowl and blowing fuel out the carb intake.
I guess I'll keep trying things until I find a solution. All ideas are welcome as I am running out of things to try.
Old September 28th, 2014, 02:34 PM   #3
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Seems odd, the fact that the K&N pods made it worse tells me your jetting is all wrong. Find a stock airbox and play around with the jetting.
Be careful. Remember you are
invisible
Old September 28th, 2014, 06:33 PM   #4
Check the float levels. Check the carb diaphragms for damage.
Turn the idle mixture screw to 2 1/2 turns in as a base and sync the carbs.
I'm not a big fan of pod filters myself.
Old September 28th, 2014, 06:39 PM   #5
DaBlue1
DaBlue1's Avatar
Reversion is the flow of the air fuel mixture out of the cylinder and into back into the intake manifold. Reversion happens even on a stock engine because the piston is moving up the cylinder before the intake valve closes. This is usually a sign of a needed valve adjustment or the timing is off.
https://www.youtube.com/watch?v=VLLZavItixY
The fact that you're missing the airbox may be a clue that the PO did something to the engine. (maybe have advanced the timing using a offset key). It's also possible your timing could be changed throughout the rev range, however at idle speed the result is carb spitting or reversion.
Old September 28th, 2014, 08:43 PM   #6
Welcome John!
Carb Issues...? HELP DaNinjaDragon 1986 - 2007 Ninja 250R Tech Talk 19 November 13th, 2014 05:31 PM
Carb Issues: you're not alone. Ninjinsky 1986 - 2007 Ninja 250R Tech Talk 16 August 11th, 2014 12:27 PM
have no clue - ZX-6R carb issues ftagod 2008 - 2012 Ninja 250R Tech Talk 5 September 2nd, 2011 05:03 PM
carb issues peeweecollins 1986 - 2007 Ninja 250R Tech Talk 4 July 20th, 2011 09:06 AM
Carb Issues ScraitT 2008 - 2012 Ninja 250R Tech Talk 2 November 11th, 2010 12:55 PM
