Old July 24th, 2013, 03:01 PM   #1
passive101
Motorcycle(s): 2009 Ninja 250
Question Side panels how to reinstall by seat?
I'm trying to get the side panels reinstalled properly on my 2009. I can get the 3 plugs to line up, but it's not high enough to get the screw in properly at the bottom.
I see there is a notch of plastic on the top center the goes by the front seat. Do both sides of that go behind the black plastic part attached to the bike, or do they go around that or in front of it? I think I have mine on the outside of it, because I seem to have a really big gap? Is there a trick to installing these things? Or maybe it's normal and I just don't remember there being such a big gap, but there is a plastic cut out on the panels which I assume does go somewhere and do something.
ETA I handled them with a bit more force and got them to go around that black plastic rubber thing. They are now much more flush looking
passive101 is offline   Reply With Quote
Old July 24th, 2013, 04:45 PM   #2
Aggrotech
Aggrotech's Avatar
Motorcycle(s): 12' Ninja 250
thats normal. they wont be 100% completely flush with the tank.
Aggrotech is offline   Reply With Quote
Old July 24th, 2013, 09:24 PM   #3
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
On mine, there's a metal tab coming off the tank with a rubber cover right near the top from edge of the seat. The catch part of the top of the side panel goes behind that (so the tab from the tank rests inside the catch on the panel.
I usually put that in first by slightly bowing the panel towards the tank, then push in the front plug, then the top back plug. The bottom back plug should just push in right after those two are in.
The screw hole is a bit up and to the left when I just leave it there, but the screw aligns everything and holds it in.
I can take pics if that might help?
Oops just saw your edit...
<-- Linky
Old July 24th, 2013, 10:03 PM   #4
passive101
Thanks Teri. I never thought that taking those off would be such a pain to get back in correctly.
Old July 24th, 2013, 10:13 PM   #5
NevadaWolf
NevadaWolf's Avatar
It does get easier the more you do it.
If you haven't seen it yet, I would recommend this thread: http://www.ninjette.org/forums/showthread.php?t=9933
Go through at least once and remove everything. See how they fit together, what bolt goes where, and really look. It'll save a lot of headache when you have to take the plastics off to tinker inside.
<-- Linky
Old July 25th, 2013, 09:38 AM   #6
ducttape.
Tyga Side Panels or Apex SS Brake Lines Driddle 2008 - 2012 Ninja 250R Farkles 10 July 16th, 2013 01:00 PM
Need rear side panels psych0hans Items Wanted 0 May 28th, 2012 11:21 AM
WTB: Black rear side panels kavo Items Wanted 0 May 4th, 2012 03:07 PM
WTB - Black side panels in CF for 08+ ninja Chubbs032 Items Wanted 1 April 22nd, 2010 11:46 PM
