January 30th, 2013, 07:39 PM | #1 |
Join Date: Dec 2012 Motorcycle(s): 2007 Ninja 250 Posts: 14
Overheating problems
Alright, so I just finished fixing my 2007 ex250 and got it to running pretty well except that it overheats in stop and go traffic. What I have already done to the bike, is cleaned the carbs and the jets, readjusted the mixture screws, and did a valve adjustment. Unfortunately the chain popped off, but that is another issue, I am waiting for parts to come in to replace that and will be changing the gear ratio to 15/42. Anyways the question is, what do I do to prevent the bike from overheating? ad what is the purpose of the liquid coolant if it does not cool the bike? any input would help thanks
January 30th, 2013, 07:51 PM | #2 |
Did you just simply fill it up with coolant. Possibly there is still air in the system somewhere. Gotta burp that stuff out sir or she can still overheat.
January 30th, 2013, 07:51 PM | #3 |
Take a look at this:
http://faq.ninja250.org/wiki/Cooling_system Things that always help: Fresh coolant Proper type and level of oil Recommended idle rpm's Clean radiator fins
January 30th, 2013, 07:55 PM | #4 |
when filling it up, do I put it into the overflow? or directly into the radiator?
January 30th, 2013, 07:59 PM | #5 |
Here's some info on servicing the coolant system:
http://faq.ninja250.org/wiki/How_do_...ling_system%3F |
January 30th, 2013, 08:02 PM | #6 |
Thanks, I did not realize that the fan was not supposed to come on just below the red line, I got nervous because it got about a third of the way from the red line, good to know it is running just fine
January 30th, 2013, 09:04 PM | #7 |
Add to the radiator, fill 'er up, start 'er up, warm 'er up (cap off)... blip the throttle 3-5 times, top 'er off... good to go.
January 31st, 2013, 06:16 AM | #8 | |
Join Date: Jan 2013 Motorcycle(s): 2012 FZ6R, 2006 Ninja 250, 1977 Suzuki GS550 Posts: 186
I'm pretty much changing the entire cooling system except the rad. If after all this the fan still waits til redline to come on, I'll accept it.
2012 Yamaha FZ6R (mine) 2004 Kawasaki Ninja 250 (wife) 2003 Kawasaki Ninja 250 Street Fighter project |
January 31st, 2013, 05:22 PM | #9 | |
If temp is high and the new sensor of the fan doesn't command the fan to start, then the problem may be the radiator. Calcification of its walls cause difficulty to transfer heat and to flow coolant. The fan's sensor reads the temperature downstream the radiator, which should be just a little lower than the temp upstream, but not so much that the fan doesn't feel the need to start up.
February 1st, 2013, 06:06 AM | #10 | |
February 3rd, 2013, 11:25 AM | #11 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
How far exactly does your needle go before the fan kicks on? I just want to clarify that your bike does hit the redline? I thought my ninja was overheating when I first got it but it just moves close to the upper end of the gauge while the fan keeps it from overheating. Never had it actually hit the right line even sitting there in FL stop n go traffic in the summer.
February 3rd, 2013, 11:27 AM | #12 |
My gauge gets about one needle thickness before red before the fan kicks on
February 3rd, 2013, 01:15 PM | #13 |
February 5th, 2013, 07:02 PM | #14 |
Crashing sux
Join Date: Sep 2012 Motorcycle(s): 07 EX250, 04 ZX6R, 96 Vulcan EN500, 79 XS650-SF, 80 TS185 Posts: 62
your thermostat could be sticking partially closed or your water pump might could be not pumping enough fluid
overheating issue | tony7kp | 2008 - 2012 Ninja 250R Tech Talk | 9 | June 21st, 2012 10:50 AM |
Overheating | Avenged7Fold | 2008 - 2012 Ninja 250R Tech Talk | 8 | May 16th, 2012 06:23 PM |
New Oil/Overheating | kchava | 1986 - 2007 Ninja 250R Tech Talk | 7 | April 21st, 2011 11:16 AM |
Overheating issues, need of help. | murc585 | 2008 - 2012 Ninja 250R Tech Talk | 42 | April 13th, 2011 11:15 AM |
Overheating? | Reswob | 2008 - 2012 Ninja 250R Tech Talk | 23 | July 24th, 2010 12:03 PM |
