May 9th, 2012, 10:45 AM | #1 |
Join Date: Dec 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R Posts: 23
To choke or not to choke?
I own a 2011 Kawasaki Ninja 250R Carb version.
I always start her up early in the morning without turning the choke on and the engine seems to run fine and starts up without fail. My question is... Would it be better if I turn on the choke? Or would you say that using the choke function is always the best way to start a cold engine in the morning? Or just start the engine normally without using the choke? What would you advice? Thanks in advance and sorry for the noob question. |
May 9th, 2012, 10:47 AM | #2 |
Join Date: Apr 2012 Motorcycle(s): 2003 Kawasaki Ninja 250R Posts: A lot.
Don't use the choke...... It makes the engine run at higher rpm's even if jsut for a second.... Choke is for cold weather starting....
http://www.facebook.com/groups/DeMdNjPagrouprides/ I live my life a quarter mile at a time! Who is affraid of the big bad jiggles???? LOL |
May 9th, 2012, 10:48 AM | #3 |
Side not: When I saw the topic of this thread I thought some kid was sitting at his computer staring at internet pron wondering what to do... LOL
May 9th, 2012, 10:49 AM | #4 |
Naw, don't use it if you don't need it.
I am here for jokes that will soon follow.
May 9th, 2012, 10:57 AM | #5 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 650R Posts: 317
If it'll start & run reasonably well without it, skip the choke.
May 9th, 2012, 11:43 AM | #6 |
Join Date: Sep 2010 Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty Posts: A lot.
My motto is: when in doubt, choke.
May 9th, 2012, 11:49 AM | #7 |
Mark, Stay away from the xhamster! LOL
May 9th, 2012, 11:56 AM | #8 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
That's weird, because it can be 65F+ where I live in the morning. I almost always have to add a little choke to warm her up or she dies with any throttle. After about 30 seconds to 1 minute I turn it off and she's generally fine. Should I just leave it off and let her warm up naturally?
May 9th, 2012, 11:59 AM | #9 |
Choke is there for starting. Use it if needed. If it starts, idles, and responds to throttle quicker and easier with choke, use choke.
If it starts better without choke, don't use the choke. All completely dependent on the bike. A blanket answer of yes or no to, "should I use the choke" doesn't mean a thing. All I'm saying is, the choke is there for a reason; to make starting easier. It's not necessary, but if it makes starting easier, use it... |
May 9th, 2012, 12:08 PM | #10 | |
May 9th, 2012, 12:13 PM | #11 |
I've never heard of anything like that...
If you tune your mix screws properly for a warm bike, the bike will be capable of choke-less cold starts, but it will still start more easily and idle smoothly at about 2k with about 1/2 choke. After a minute, the bike will accept throttle, and you can ride off, turning the choke off when you notice the bike bogging a touch. Once it comes the rest of the way up to temp, you can run the bike as squidly as you want at the redline |
May 9th, 2012, 12:17 PM | #12 |
One Loyal Fox
Join Date: Apr 2012 Motorcycle(s): 2012 Ninja 250R (RIP), 2011 ZX-6R Posts: 869
I never thought about this, but I've been turning my bike on, if it was idling really rough and low, i'd bump the choke up a bit, though sometimes the bike will shut off if i turn the choke up too much. Is that normal? Is it just getting too much fuel? I guess from now on I'll just let it idle w/o choke until it's warmed.
May 9th, 2012, 12:29 PM | #13 |
Rough and low is pretty normal for a totally cold Ninjette. All 4 of mine acted the same way. In the mornings, I put the choke somewhere between 1/3 & 1/2, fire it up, and adjust it as necessary to achieve 2500 rpms, let it run like that for a couple of minutes, and it's usually good to go. Ride away with the choke on, and turn it off during the ride.
When the engine starts to warm, it'll be less willing to run right with the choke on. It should be turned off well before this starts to happen. |
May 9th, 2012, 12:56 PM | #14 |
One Loyal Fox
ahhh got it, that clears things up greatly. thank you for this info!!
May 9th, 2012, 08:03 PM | #15 |
THANK YOU for all the replies guys and for helping a noob out
Never using choke | kano6280 | 2008 - 2012 Ninja 250R Tech Talk | 22 | March 29th, 2012 03:26 PM |
choke? | reabo | 2008 - 2012 Ninja 250R Tech Talk | 4 | February 2nd, 2012 05:24 AM |
the choke | james250ninja | 2008 - 2012 Ninja 250R Tech Talk | 4 | November 6th, 2011 05:38 PM |
So how does choke work? | ericeng91 | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 15th, 2011 06:50 AM |
