July 12th, 2014, 11:06 AM | #1 |
Does my pre-gen need the diode mod?
Meant to post this a long time ago. anyways, quite a ways back I bought flush mounts and i moved the rear blinkers into the pods. both the flush mounts and the pods are clear smoked lens, so with the stock bulbs they flash white instead of amber, which isnt a huge deal but i bought amber leds for both the front and back. when i put the leds in, they wont come on at all. no flashing no nothing. no matter what combination i put them in (just one, all 4, whatever) i cant get any of them to light up or flash. will the diode mod solve my little problem? keep in mind that my brake light is a red led and it works like a champ. go fiure
Apparently it's bad to rev at girls when there's already one riding on the back? |
July 25th, 2014, 11:53 PM | #2 |
July 26th, 2014, 02:32 AM | #3 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite Posts: 332
Some LED bulbs are polarity sensitive. That is, if the ground and power leads are backwards, they won't work.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike. |
July 26th, 2014, 04:52 AM | #4 |
The diodes are only to correct for 4-way flash due to back flow through the indicator bulb.
You need to check that all your LED bubs are inserted into their sockets in the correct orientation. |
July 26th, 2014, 08:18 AM | #5 |
Wrench wench
Join Date: Jun 2014 Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS Posts: 415
Sorry, I can't help you with your issue, but I'd like to know where you got the leds. I've been looking to replace the crappy bulbs on the ninja for a while. The vibrations from this bike kill filaments like crazy.
July 26th, 2014, 09:16 AM | #6 |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
I don't know if the Ninja comes with an OEM thermo-mechanical flasher or an electronic one. If it's thermo-mechanical, you need to swap it out for an electronic one when using LED turn signals. The LEDs don't draw enough power to activate a thermo-mechanical flasher. Most auto parts stores carry replacement electronic flashers. Take the old one with you to match the pins on the flasher.
July 26th, 2014, 09:43 AM | #7 |
Join Date: May 2014 Motorcycle(s): 99 Ninja 250 Posts: 217
This what I just bought and I am waiting to receive it. Buy this as it should fix the issue. I have LED turn signals and they just turn on and stay on but do not flash and this should correct the issue.
http://www.superbrightleds.com/morei...asher/193/841/ |
July 26th, 2014, 09:51 AM | #8 |
When I installed LED's I had the same problem. The polarity was wrong, swap the wires around.
After that, if all four flash at once, you need the "Diode Mod", that will make them work left to right, but they will flash very fast. The electronic flasher will cure that problem. Summary: polarity matters, diode mod stops the "all four at once problem", electronic flasher cures the "too fast" problem. Three distinct, but interrelated issues.
July 26th, 2014, 04:56 PM | #9 | |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
These are not available in Australia as far as I can find. 1992 model, not bad for lights.
Originally Posted by jgcable; I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it. Last futzed with by baxtc1; July 26th, 2014 at 04:57 PM. Reason: Added info. |
August 21st, 2014, 05:10 AM | #10 | |
Diode = Only allows electricity to flow one direction No LED should allow a reverse connection, though I can see an assembly that includes two LEDs allowing it. Heck, they've got some component-sized LEDs with built-in flashers! |
August 21st, 2014, 08:52 AM | #11 | |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
We've done that on all the bikes. A "heavy duty" flasher would probably work to.
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
August 21st, 2014, 05:41 PM | #12 |
You're arguing semantics. LED bulbs that plug into standard bulb bases also have some simple circuitry in them that means the whole bulb system, not just the physical LED itself, can be described as polar or non-polar.
August 21st, 2014, 05:57 PM | #13 | |
Anyway, the simplest way to make a dual-polarity LED is to use two LEDs. I mentiomed that they do sell blinking LED components because it is interesting and makes me wonder if they will ever sell a dual LED component. |
August 21st, 2014, 06:06 PM | #14 |
Yes, I'm aware. But you correcting wordage online has no effect on the general public.
Like I said, the bulbs that use a standard base and have a cluster of large LED's on them also have some basic circuitry so that the same physical LED's light up, regardless of which base terminal is hooked up to which power lead. Or, if they're simpler and don't have the circuitry required to be 'non-polarized', they're just labelled as polar and require some thought/labeling to make sure they're hooked up correctly. General public = stupid. No use wasting energy. Marketing department =/= engineering department. |
August 21st, 2014, 08:07 PM | #15 |
Aren't members here part of the general public?
There's a difference between stupid and ignorant. Most folks are ignorant about some things, some are ignorant about many things. At one time, everyone was ignorant about everything. But those who learned/gained knowledge were no longer ignorant about the things they learned. No one knows everything. Stupid means foolish, slow, simpleminded, idiotic, etc. You can't fix stupid, but you can ignorance. |
August 21st, 2014, 08:20 PM | #16 |
Point taken, I should have written ignorant instead of stupid. I tend to use the two interchangeably when I shouldn't.
We could still make a strong argument for using stupid to describe the majority of the population of the world, but that's very OT and not necessary. |
August 22nd, 2014, 11:31 AM | #17 | ||
EX500 full of EX250 parts
This is a good summary of the issues. They often pop up together, but they're separate issues caused by separate things, with separate fixes. The diode mod won't fix hyperflashing, a new flasher won't fix reversed signal wires, etc.
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. | AFazakerley | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 5th, 2016 02:03 PM |
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames | kjohng | General Motorcycling Discussion | 5 | February 27th, 2013 10:03 AM |
FS/ part out new gen and pre gen 250r ninja | carlos | Motorcycle-related | 3 | May 14th, 2012 10:25 PM |
Pre-Gen headlight update/mod... | Socal5646 | 1986 - 2007 Ninja 250R Farkles | 10 | October 22nd, 2011 11:06 AM |
Diode Mod. | RedRider715 | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 12th, 2011 08:40 AM |
