January 24th, 2011, 03:11 PM | #1 |
Airbox ducts to carbs
I was putting my bike back together today, and the rubber ducts that go from the aribox to the carbs would not go on. One of them was totally deformed. I noticed it when I took the bike apart. I think it happened the last time I put the carbs back on; I didn't quite get the duct around the carb and it remained squished awkwardly for probably weeks if not months.
Anyway, I ordered new ducts, but I don't know how long it will take to get them in. Can I still run the bike even if the ducts aren't perfectly seated against the carbs? |
January 24th, 2011, 03:13 PM | #2 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
I wouldn't do it just because you run a risk of getting dirt into your motor.
January 25th, 2011, 07:30 AM | #3 |
^+1000
January 25th, 2011, 11:30 AM | #4 |
Smoker
instead of buying new ones, you could have soaked the old ones in some hot water for a few minutes. Woulda fixed em right up. And no, do not run it without them - you are getting unfiltered air in the engine and running super lean.
January 25th, 2011, 01:35 PM | #5 |
Thanks for the tip. I will do that anyway and save them in case I ever need a spare.
January 29th, 2011, 01:00 PM | #6 | |
Are you sure this will work for the air ducts? I ask because my order from Ron Ayers has not shipped, and I have a race a week from tomorrow. I don't even know if the bottom end of this motor is any good and I'm running out of time. |
January 29th, 2011, 05:17 PM | #7 |
January 30th, 2011, 07:11 PM | #8 |
Sho'nuff, it did the job. Pulled both ducts and both boots and gave 'em a hot bath. The air ducts look brand new, perfectly round and unmolested. Wife was not happy about the smell, and boy did (does) it smell.
Will fit them tomorrow. Maybe I can cancel my order before it ships. Jinx, I apologize for doubting. |
April 2nd, 2014, 06:37 AM | #9 |
Join Date: Mar 2014 Motorcycle(s): 1998 kawasaki GPX250 Posts: 53
I'll revive this thread with a question! Are their any tricks or tips for getting the Air ducts from the carbs to the air box on without cutting my hands to shreds? I managed it in the end but man what a nightmare! Also the tightening springs area bugger to get on too.
For God did not send His Son into the world to condemn the world, but that the world through Him might be saved. John3:17 |
April 2nd, 2014, 06:42 AM | #10 | |
Here, take this for when you need it. You can thank me later... because I ordered 10 of em.
clamp around airbox to carbs | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 4 | August 28th, 2014 07:31 AM |
remove and reinstall carbs - stock airbox | red | 2008 - 2012 Ninja 250R Tech Talk | 22 | July 16th, 2013 07:09 PM |
How do I get the carbs off of the stock airbox? | Ben M | 2008 - 2012 Ninja 250R Tech Talk | 11 | September 28th, 2012 11:21 PM |
'08+ Airbox | Countersteer | Motorcycle-related | 0 | June 10th, 2012 12:50 PM |
Full exhaust + airbox mod = how hi maintenance are the carbs/jetting? | 675Raisinator | 2008 - 2012 Ninja 250R Tech Talk | 14 | December 27th, 2011 12:05 PM |
