Old December 22nd, 2012, 05:06 PM   #1
old3
Area-P tuner installed
My Area-P tuner arrived today. I have an Akra slip on for a 250 and a decatted stock header.
AWESOME.
The engine now pretty much totally exceeds anything I ever expected a 250 Ninja based engine could ever be, and it was already doing that stock! The torque is even better than before, pulls clean from 2500 RPM, hauls with a hit into the low mid around 4500, then flat pulls hard to around 12500. It might fall off there just a tad but I'm having trouble shifting fast enough to avoid the limiter. It popped the front wheel off the ground in the 1-2 shift.
WOW.
Open up the exhaust, add this tuner and let it rip. I'm probably running a touch fat too, still waiting for my K&N air filter panel.
Side benefit, I had upgraded to 93 octane last few weeks to track down a metallic tingle I could hear around 4-5k RPMs. I wrote it off as a fairing noise as the premium fuel seemed to lessen but not cure it.
Well, it is gone now. Had it earlier today, can't get it despite loading it hard uphill. It would do that everywhere before, flat land, down hill, anytime you applied fuel in that RPM range.
old3 is offline   Reply With Quote
Old December 22nd, 2012, 05:22 PM   #2
old3
Install tips. Whole job took about an hour.
I was able to drop the fairings onto the front fender and prop the fuel tank up with a 2x4.
Pull out the under rear seat tray and trim the plastic on the right front corner so the cable can run smoothly under the steel brace back there. It smooths the angle of the wire and no possibility of the seat pan crushing/damaging the wire. The tray pops out with 2 cotters and 2 pins. Very simple.
Loosen the next forward brace to fit everything under it.
Pull out the battery cover and trim that along the right side too to allow the cable to pass without obstruction.
I needed to use a long needle nose plier to release the right side injector connector. Best to use a flat tool to compress it rather than man handle it and damage it.
Be sure to run the wires under the heavy cable under the tank, good room in there to stash everything and it pluged right in.
I have been replacing the factory bolts as I go along with KTM and Husky 8mm head bolts for everything in 5 and 6mm. This allows you to tear it apart with a single 8mm T handle. What a treat to have this on a bike, I was spoiled by no Japanese bikes for years! Seat, fairings, side panels are now one size tool instead of 3.
Next time I pull the front top black covers those phillips screws are gone too! Starting to strip their heads already. Cheesy junk.
Old December 22nd, 2012, 06:17 PM   #3
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
You upgraded to a less efficient slower burning fuel?
AFM #676
Supersports are for n00bs
Old December 22nd, 2012, 06:37 PM   #4
Nice report!
Old December 22nd, 2012, 07:01 PM   #5
old3
To fight off detonation/pre-ignition?
Yes. Why?
edit!
Oh, missed the funny face. LOL, LMFAO, OMG, har-har-har!
Old December 23rd, 2012, 12:27 AM   #6
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Yes. Why?
edit!
Jim, to be honest I can hardly believe that the 300 should have probs with the ignition. The 300 is compared to the 250 much more emission-oriented, look at the CR and the setup of the ignition only and you'll see.
My 250 runs very well with 91 RON thats what you know as 87 MON.
Old December 23rd, 2012, 08:24 AM   #7
Old December 23rd, 2012, 10:12 AM   #8
old3
Don't have any other explanation. In NJ we get crap winter blends mandated by the state. Even the premium sucks.
The sound was like thin aluminum foil being wrinkled. Tinkle, tinkle, tinkle. It did not sound like the common death rattle of a car going uphill on low grade fuel. My Mustang is tuned for 93 and it will make a racket if you run low grade fuel and hammer it. Tough to describe but easy to hear over an open Akra can and open header, over wing noise on the highway in a full face helmet so loud enough.
I loaded the crap out of the engine uphill, 2500 RPMs, WOT. Noise is gone. I could dial up that noise at will from 4-5k everytime. I had thought it must be something else, like a vibration sensitive rattle of a bracket or something, the guts of the horn, whatever but the tune is what stopped it.
I'll be curious to hear if other 300 owners ever report the same noise. Unfortunately alot of them are buying their first bike so they are kinda lost with what they hear.
Old December 23rd, 2012, 10:20 AM   #9
allanoue
allanoue's Avatar
MOTM - Sep '14
Any chance that you could record the noise and share, for us noobs?
Old December 23rd, 2012, 11:02 AM   #10
old3
I'd rather not have had any detonation to begin with, I'm not gonna do it deliberately! I don't have anything that would "hear" the sound over wind across the device anyway
If you have it, you should be able to hear it clearly at 4k to 5k RPM, just roll on the throttle faster than the engine can keep up, load it at 3500 RPM and listen. If you hear anything except the intake/exhaust, like what I described, that is it.
Area-P said the bikes are lean inj the lower range, I'm betting that is it. Shooting for fuel economy they went too lean. Pretty common tune for Japanese bikes since the 1970s, lean low, OK to fat up top.
Old December 23rd, 2012, 11:06 AM   #11
kbryant
Area P
kbryant's Avatar
Thank you for the comments on the FI Micro Programmer. Our web page is now up
http://www.areapnolimits.com/product...a-300-2013.php
Old December 24th, 2012, 01:01 PM   #12
jaybo
Motorcycle(s): 13 ninja 300, 04 crf 250, 06 yz125
Hey was wondering which tune you used. Since you have deleted the cat and snorkel and have a slip on, I'm guessing you used the tune for the full exhaust with the snorkel removed and k@n replacement filter. Congrats on the mods coming together with the tune and the bike running like it should! Also thanks for posting info on the cats
jaybo is offline   Reply With Quote
Old December 24th, 2012, 03:06 PM   #13
old3
I asked they load the tune they used for their full system and K&N panel filter. That filter should be installed in the next few days too, just waiting on UPS.
The decat was easy if you weld and I'm sure really let the slip on combo work to its best potential.
Old December 25th, 2012, 01:02 AM   #14
Somchai
Freedom for Germany
Ok, yesterday i went out and tried to provoke detonation from pre-ignition (I'd advanced my ignition by 5°) - absolutly no chance.
The benzine we get here is 91 roz (your 87 moz) only and the quality i don't want to talk about - there is not much (i always compare this to Germany).
So for me this is really strange since the cr of the 250 is 11.6 to 1 and the 300 is 10.6 to one and here's a picture of the ignition-curves (I hope all my informations are right, correct me please if not).
The orange line is mine with 5° advanced,
the dark-green is the US-carbed with BRT-TIS,
the brown one is the European-Version,
the dark-blue is the standard Thai-Version,
the yellow line is the US-carbed standard,
and the light-blue is the new 300 Ninja.
Since I'd advanced my ignition my water-temperature is lower then before, so this indicates that there is absolut no problem in this range. And please remember the earlier Kwakis and the others also, before the companies started to care about emissions, always run the ignition in this ranges up to 45° degrees (retarding the ignition and lowering the cr with running lean is for emission-control). The very best example about this is the Chevy Corvette from the 70's to the 90's.
But at least I'm believing you, because you're sitting on the bike.
Old December 25th, 2012, 07:20 AM   #15
old3
IDK what to try to really confirm it is preignition but I can't even think of anything else it could be. It shouldn't be, but the noise is there. Engine source, clutch in it goes away, RPM and throttle load sensitive, not speed dependant. It got better with the tune till I dumped the gas can gas in it...
I'll be adding premium fuel soon, the roads are snow and ice covered right now so ASAP, and I'll follow up.
Old December 26th, 2012, 06:37 PM   #16
jaybo
Yeah I weld so I will probably do it this week, its to cold to ride so I can have the bike down for a few days If I need. Ive got some more weight cutting to do to ha ha. Unnecessary but its in my blood. I spent hundreds on titanium on my mx bikes but wont be going there this time.
Area P tuner old3 Motorcycle-related 4 February 7th, 2015 12:19 PM
area p tuner question jaybo 2013 - 2017 Ninja 300 Tech Talk 2 December 26th, 2012 06:23 PM
GB Area P Exhaust installed! Bosgarage57 1986 - 2007 Ninja 250R Tech Talk 17 August 6th, 2011 05:55 PM
Area P finally installed Snake 1986 - 2007 Ninja 250R Tech Talk 27 September 19th, 2010 02:02 PM
[superbikeplanet.com] - From The Archives: The Compassionate Tuner Ninjette Newsbot Motorcycling News 0 June 3rd, 2009 12:10 PM
