Old March 26th, 2017, 01:04 PM   #1
roundhouse
Motorcycle(s): 04 250R
Only runs on full throttle
And it will only run about 2,000 RPM. Carb was just rebuilt by pro after I rebuilt it and it is no better than when I did it. Spark is fine. Compression is good (R 192 L 179). I do not think there are any vacuum leaks. Fuel is getting to carbs but I do not know how much.
Engine will rev up with a shot of starter fluid. So it is a fuel delivery prob?
I took the petcock apart and cleaned it out before trying any of this and it was in poor shape but is spotless and flows now. Could that diaphragm thingy have anything to do with it?
I just cannot for the life of me figure this out. Any leads would be much appreciated.
I am so close! dying to ride it!
roundhouse is offline   Reply With Quote
Old March 26th, 2017, 03:10 PM   #2
ducatiman
ducatiman's Avatar
2000RPM at full throttle?
is your cable freeplay allowing the throttle plates to fully close?
does the idle adjust knob have any effect? (turning down from your 2000RPM?
does the choke offer any aid to starting?
To confirm adequate fuel flow...each bowl should contain 45-50cc of gas, you can drain each into a container to measure OR use clear tube on drain nipple to determine height.
How many turns are the pilot screws set at?
Your rebuilder synched the throttle plates? (bench synch)
Have you discussed with him? His recommendations?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 26th, 2017, 03:19 PM   #3
roundhouse
Idle screw has no effect
I pulled the bowls and I cannot be certain but it appeared to 7-8 teaspoons of fuel but I could be way off
pilot screws...........hum? What are these pilot screws you speak of?
carb was eye balled synced and I have made one of those sync contraptions our of bottles, stoppers and hose but I need it to idle on it's own before I attempt it.
so, pilot screws. what effect do they have? I will do some google work.
Thanks for your help!
Old March 26th, 2017, 03:31 PM   #4
ducatiman
ducatiman's Avatar
i asked you 7 questions...you've answered just 3 or 4.
Custom Carb Service
Old March 26th, 2017, 07:56 PM   #5
I think that's the key right there.
Sounds like there is a problem with the assembly or adjustment of the carbs. If you paid someone to do it, you should contact them. If they are a "pro" they will help you sort it out and re-check the assembly and adjustments. A real pro will do whatever it takes to make it right.
Old March 27th, 2017, 04:18 AM   #6
roundhouse
well alrighty then.
2000RPM at full throttle? Yes
is your cable freeplay allowing the throttle plates to fully close? Yes
does the choke offer any aid to starting? No and No
Old March 27th, 2017, 05:09 AM   #7
ducatiman
ducatiman's Avatar
Your rebuilder.....
have you discussed with him? His recommendations?
What methods did he use to clean? ultrasonic? sodablast?
I stand at the ready to give them a second look, if you choose. Apparently something remains seriously wrong.
Custom Carb Service
Old March 27th, 2017, 11:15 AM   #8
roundhouse
Your rebuilder.....
I do not know what he did. It was a buddy deal. the guy is a tech who owns a local lawn tractor sales and repair so I figured a small engine carb is a small engine carb.
Thanks, if I cannot get it going I may holler at ya. I assume I would ship the carbs?
Old March 27th, 2017, 11:31 AM   #9
ducatiman
ducatiman's Avatar
"Thanks, if I cannot get it going I may holler at ya. I assume I would ship the carbs?"
correct, I routinely do this, USPS Priority (using their medium box) about $13 to ship.
I invite you to read some forum feedback from fellow members https://www.ninjette.org/forums/showthread.php?t=239678
Custom Carb Service
Old March 27th, 2017, 04:48 PM   #10
roundhouse
I am going to take it apart and see if maybe there was trash in the line when I put it back on. If not I will definitely send it your way.
Surging at Full Throttle Foxrider64 Ninjettes At Speed 17 July 1st, 2016 08:45 PM
Full throttle kills bike, throttle lag response. Diegone 2008 - 2012 Ninja 250R Tech Talk 10 April 30th, 2014 03:25 AM
Losing power at full throttle trugracie 2008 - 2012 Ninja 250R Tech Talk 27 April 12th, 2014 06:43 PM
Working on a 05, starts and runs, just no throttle Gmtec2 1986 - 2007 Ninja 250R Tech Talk 14 April 2nd, 2013 12:47 AM
Bike only runs on full choke!! UjaasG35 2008 - 2012 Ninja 250R Tech Talk 13 May 15th, 2012 06:49 PM
