Old January 18th, 2013, 07:26 PM   #1
mikecronis
Motorcycle(s): 2008 Kawasaki Ninja 250R-J, 2005 Honda Superhawk VTR1000
Dynojet Kit 2393 Stage 3 (anyone try it?)
Looks like the Stage 2 by Dynojet stops at a size of "100" where the Stage 3 skips on over to "104". Too bad there's not a "102" size (as I'm in Colorado). I noticed DynoJet doesn't offer a pilot jet, just a main-jet whereas Factory Pro offers both. Wouldn't you want to fine-tune your carb jetting with both?
I've used DynoJet before in earlier model Ninjettes to good success, but Factory Pro's website looks 1990-esque. Recommendations? I have a nicely modded '08 (braided brakes, etc.) but intend on getting a full Yoshi exhaust (the carbon and titanium versions claim the same weight so I think it's a matter of aesthetics). De-snorkl'ed (runs odd now, and louder, probably a tad lean I suspect with a few micro-hesitations under WOT above 9k) and K&N'ed (not "podded").
So, do I need the pilot jet as supplied by Factory Pro or should I go Stage 3 on DynoJet (2393) or go large on the Stage 2 (2193)?
Also, finally, why not just buy a pilot jet and main jet from Kawi directly and save $$$? I did that with my Honda Superhawk 996. What would a DynoJet 102 size be in Kawi OEM speak and a pilot jet size of 42? For a main jet, don't I need two of 'em?
Mike
mikecronis is offline   Reply With Quote
Old January 18th, 2013, 08:15 PM   #2
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
Never bought a dynojet. Bought the jets separately yea way cheaper you just need to know YOUR set up.
Yes you need 2 main jets and 2 pilot jets for the 2 carbs
TUNE INFO:http://www.ninjette.org/forums/showthread.php?t=10208
JetsRus:http://www.jetsrus.com/a_jet_kit_str...50R_Ninja.html
THE GOOD LIFE
cuz is offline   Reply With Quote
Old January 18th, 2013, 08:30 PM   #3
mikecronis
Hey, thanks for the JetsRUs site! GREAT!
Old January 19th, 2013, 02:33 AM   #4
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Go to a # 40 pilot
Worlds fastest 250 ninja
Old January 19th, 2013, 02:36 PM   #5
mfresh
Knee-dragger in Training
mfresh's Avatar
Motorcycle(s): '09 Ninja 250R (Sunbeam Red)
I too have been trying to do some research on the Dynojet Stage 3 (2393) for the Ninja 250R and literally nothing shows up of interest on google except for this thread that was made yesterday.
Looks like most people opt to buy the jets individually these days? Any reason one shouldn't go for the "OEM equivalent" vs the "genuine" jets?
mfresh is offline   Reply With Quote
Old January 19th, 2013, 03:44 PM   #6
DaBlue1
DaBlue1's Avatar
Originally Posted by mikecronis View Post
.... I have a nicely modded '08 (braided brakes, etc.) but intend on getting a full Yoshi exhaust (the carbon and titanium versions claim the same weight so I think it's a matter of aesthetics). De-snorkl'ed (runs odd now, and louder, probably a tad lean I suspect with a few micro-hesitations under WOT above 9k) and K&N'ed (not "podded").
Are you jetting this bike for the elevation in Colorado Springs?
It sound like you may be running a little rich. Stock 250 Ninjas are nicely rich at 9k (see this dyno chart). Going to bigger mains and pilot jets for that elevation (6,035 feet ASL) will make it even richer. Normally there is a reduction in jet size. I see you plan on getting a full exhaust, but do you plan on leaving the airbox or putting on pods?
Old January 19th, 2013, 04:32 PM   #7
Racer x
Racer x's Avatar
Good call Blue. Forget what I said about the pilot above 5000 feet.
For the record I only use Keihn jets. I use tools to measure jets.Dyno jet jets work but don't come in as many sizes. And Dynojet does not have all the needles and pilots you need to fine tune.
Old January 25th, 2013, 09:30 PM   #8
mikecronis
After the snorkel removal, I'm getting indications that I'm overly lean at about 6-7k rpm and again around 10.5-11.5k. By adding a Yoshimura CF full pipe, I think I need to go up a size. I've owned pre-gens before and not jetting at this altitude with full-exhausts before and it was okay but a little too lean even still.
There's a guy Tony Strong who wrote-up a bit saying he found here in C.Springs he was successful only finally with using a Factory Pro pilot jet of 42 and a main jet of 102 after installing a full Yoshi setup with 2 shims on the needle. I did a little math and I suspect that's about right with a de-snorkeling and a K&N (non-pod, non-airbox-removal variety).
Racer X is an old sage from this, however, and I'm apt to take his advice on the 40 pilot instead of the 42.
Old January 25th, 2013, 11:14 PM   #9
DaBlue1
DaBlue1's Avatar
After the snorkel removal, did you shim?
Did Tony Strong have a dyno read out to verify his A/F Ratio?
Kogary who lives in Denver, CO, put a wide band O2 sensor on his stock bike and got some interesting results. This thread may help in your jetting efforts. http://www.ninjette.org/forums/showthread.php?t=67530
Old January 26th, 2013, 03:05 PM   #10
mikecronis
Nope, didn't shim. Probably needed to. Got some jets on the way though, and I'm pouncing on a Yoshi Full CF once my Superhawk 996 sells.
Old January 26th, 2013, 07:16 PM   #11
DaBlue1
DaBlue1's Avatar
That will definitely help, especially from 1/4 - 3/4 throttle. You may want to consider using a correction factor when jetting for your Altitude, Humidity, and Air Temperature.
Last futzed with by DaBlue1; January 26th, 2013 at 08:17 PM.
Need Advice: Stage II Dynojet Kit, Air Box Delete Bozley81 2008 - 2012 Ninja 250R Tech Talk 4 May 19th, 2012 06:05 PM
Dynojet Kit stage 2, used 250 miles, 08+ GlassAnkles Motorcycle-related 7 April 19th, 2012 10:28 AM
DynoJet Stage 2 THE BIG SITT Motorcycle-related 4 October 10th, 2011 07:54 PM
DynoJet Stage 2 Kit lonewolf05 Motorcycle-related 0 June 30th, 2011 05:06 PM
FEELER: Dynojet stage 2 jet kit 00v_Lucky Motorcycle-related 3 July 13th, 2010 12:44 PM
