Old July 1st, 2018, 02:42 PM   #1
Cep
Front brake hard braking question
I had to make an "emergency" stop today as a light decided to turn yellow on me and stopping seemed like the best decision. I braked hard, more and more weight going to the front, then something happened, it sounded like the brake pads skipping , not the tire locking. Wasnt a great sound and i eased off and rolled through the intersection as there was no traffic.
Would something like this happen if the pads / rotors were "glazed"?
I am debating whether to bring to a local shop to inspect the brakes. Im just a bit worried how much they will want tp charge though. I know i should do it myself but not sure if i have the skills to tackle the brakes or not.
2012 bike has 4500 miles. I bought it last year with 2500 miles on it.
Thanks!!
Cep is offline   Reply With Quote
Old July 1st, 2018, 03:32 PM   #2
AwDang
Motorcycle(s): 286, 296, 599, 799
Did the bars wiggle at all?
Did you get ABS back then in Canada?
AwDang is offline   Reply With Quote
Old July 1st, 2018, 03:42 PM   #3
Cep
No abs but thats sorta what it felt like.
No wiggle either
I have been noticing the last month a sort of vibration rubbing feeling/sound under heavy braking. This was the hardest i have ever braked. I think.
Old July 1st, 2018, 04:17 PM   #4
I would inspect everything carefully for signs that the pads are worn out or damaged, look carefully at the disk and its mounting bolts, and anything else you can inspect. It's possible that new pads would fix it, but it's impossible to tell long-distance like this.
Nothing to do with your current problem, but when you get it straightened out, you need to go do some practicing of hard stops somewhere where there is no traffic. You don't want to learn how the motorcycle behaves while you're trying to stay alive, you need to already know.
Old July 1st, 2018, 04:19 PM   #5
Ram Jet
Ram Jet's Avatar
No wiggle either
Make sue the pins your caliper "floats" on aren't corroded and are lubricated. I just installed new pads on my 2005 Pontiac Montana at 78,000 miles. When the auto was assembled the lower caliper pins were never lubricated and both the inboard pads were like new, the outer pads were the only pads making contact with the disc. The lower pins were actually rust pitted. I can't believe the brakes worked at all. With just the outer pads doing all the work I'm surprised the wheel bearings didn't fail.
If your pads and disc were "glazed" they most likely would just squeal when braking.
Bill
Old July 1st, 2018, 04:23 PM   #6
AwDang
Our rotor can also develop a dish or plate shape to it. You can try to watch it run thru the pad and see if it’s at a slight angle. You may have to pull the rotor off the wheel and put it on a flat surface to see if it’s dished.
Old July 1st, 2018, 07:22 PM   #7
Cep
Thx for the replies
This is my first bike and i get obsessed over things big and small... but anyways, i just went out and did some practice, emerg braking from about 80km, things seemed pretty decent. I locked up the front very briefly a couple times and you sure can hear it when that happens. Maybe that is what happened earlier not sure.
Either way will monitor it some more.
Old July 1st, 2018, 08:04 PM   #8
It could be that what you felt was lockup. I'm glad you did some practicing. I've been riding since the '70s, and I still practice fast stops once in a while, especially if I get a new motorcycle.
Old July 2nd, 2018, 06:32 AM   #9
Check your steering stem.
Grab the front brake and hold it firmly while you push and pull on the bars aggressively. Listen for a clicking or clunking from the steering stem area.
The collar below the top triple can become loose, and allow for too much give between the stem and the frame.
One of our Ninjas had some issues of that type, and we replaced the bearings with tapered roller bearings, which cured the problem.
More info - https://faq.ninja250.org/wiki/Steeri...ng_replacement
Old July 2nd, 2018, 08:33 AM   #10
I would give everything on the front end of the bike a very thorough looksee. So, check out the head bearings, handlebars, master cylinder, forks, triples, caliper, brake hose, rotor, etc. All of it. Make sure nothing is worn, leaking, loose, oxidized, etc etc.
Once all of that is satisfactory to you (remember you're the one that has to ride this thing, so you're the important one), I'd take it to a big empty parking lot and *cautiously* do some braking drills to attempt to recreate the condition or otherwise revalidate the braking system to yourself. Start easy and gradually work your way into harder braking and recreate the conditions (speed and aggressiveness of braking) that gave you that feeling in the first place.
Be careful. Be diligent. Start small and work big. If you're able to recreate the condition, it can be diagnosed and fixed. If you're not able to recreate the condition, you will have proven the braking system to yourself, inspected the whole thing for roadworthiness, and given yourself some good practice time on braking skills. Win win situation.
Old July 2nd, 2018, 10:00 AM   #11
Also check wheel-bearings.
Old July 2nd, 2018, 02:06 PM   #12
RARELY do you hear front wheel lockup. And what you describe... I hear from riders about 1000 times per year. My gut tells me, you had what vet riders call CHATTER. At the race level, its actually a good thing, it lets you know you are at the razors edge. In due time, its something you will learn to love to hate. Cause when you bike is super smooth, you chase it to go faster. When your bike gives you feedback like chatter, you wander wtf is going on.
As far as hard bits go, there are some great posts here for things to check and even some mentions of "the problem is the rider." Never take that as an insult, 90%+ of the time riders cause their own issues. Take it with a smile and a willingness to learn. As did some of the posters in this very there that I trained to break super hard to the very edge. And one... past it that now has some rubber on his leathers.
I have a question though..........
You had an "emergency braking" situation, but then rolled through an intersection with no cars? What happened?!?!?!? Animal? UFO's? Bigfoot? Sorry, I am missing something.
ps.... After you get the basics of braking down. AND I do mean REALLY DOWN then try reading this thread. https://www.ninjette.org/forums/showthread.php?t=196883
Best of luck to you sir and never be afraid to question things.
Old July 2nd, 2018, 02:24 PM   #13
Cep
Thx again all!
I rolled through the intersection because the sound totally freaked me out and i decided to stop braking so hard at that point. But again i knew it was safe to do so.
I have been practicing a lot of braking the past 24 hrs.
Im still considering taking it in and asking them to check the front end thoroughly. I really dont know what im looking at there. But my hard braking routines seemed to go well.
Would it be a mistake to bring it to a shop?
And no im never insulted... i am a noob! But wanting to learn. I picked up the bike late aug 2017 and 1 hour later i low sided slammed hard down on my shoulder and broke left collarbone. Clean break. So basically i started riding in april 2018. Im pretty confident on the little ninja now but im itching to do a track day. Also im taking the total control advanced rider level 1 this month should be fun.
Then the question becomes do i get a new bike next year and sell the 250. Honestly id like to keep it. Sigh who knows.... so many decisions. And so little money hahaha.
Anyways thx for all the suggestions. Much appreciated!
Old July 2nd, 2018, 05:52 PM   #14
Excellent! Many seasoned riders never do that, but it's a very important thing to do.
I've been riding for about 40 years, and bought my 250 about three years ago. I have bigger, faster bikes, but have no plans to sell the 250. The first day I rode it, I said that if I could never have another motorcycle for the rest of my life, I'd be perfectly happy with just the 250.
You'll love it on the track, too.
Old July 2nd, 2018, 06:08 PM   #15
Ram Jet
Ram Jet's Avatar
I feel the same way about my 07'. My ninth and last bike - no need for anything better. Sorry Kawasaki but you rang my bell for the last time but thank you also for my H1.
Bill
Old July 2nd, 2018, 06:23 PM   #16
Well, I can't say my 250 is my last one, but I don't plan to part with it.
(your 250 is seven feet long?)
Old July 2nd, 2018, 07:29 PM   #17
Ram Jet
Ram Jet's Avatar
It sometimes feels like it when I try to do a U turn on a two lane country road. It must be my age.
Bill
Rider panics during hard braking and crashes akima Videos 18 November 13th, 2015 12:34 PM
Hard Braking Turned Into a Tank Slapper Navigator 2008 - 2012 Ninja 250R Tech Talk 25 September 24th, 2015 11:54 AM
tail up under hard braking alex.s Riding Skills 13 April 1st, 2015 08:26 AM
Front brake lever stiffer after heavy braking jasonz1c 2008 - 2012 Ninja 250R Tech Talk 5 December 8th, 2013 04:48 PM
ZZR-250 Front Brake Question johnjohn 1986 - 2007 Ninja 250R Tech Talk 6 August 31st, 2010 04:38 AM
