Old January 11th, 2013, 11:01 PM   #1
krolinked
Nerd
krolinked's Avatar
Which Master Cylinder should i get?
So I've tried to get an easier pull on my lever for ninja 250 by replacing stock with an R6 master cylinder. It was almost impossible to squeeze and downright dangerous, with very very little lever travel. Im guessing its because the leverage was changed in the wrong direction? Which lever should i get if I Want:
Lever to pull closer to bar, but be easier to pull?
Does this make sense, Im not sure how to explain it.
Old January 11th, 2013, 11:45 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Look here for my update this weekend http://www.ninjette.org/forums/showthread.php?p=617484
I've tied 4 masters of all different sizes.
Old January 12th, 2013, 05:44 AM   #3
lgk
I think the mc is too big, and the volume of fluid is too large for the stock brake calipers.
Old January 12th, 2013, 10:32 AM   #4
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
When looking at m/c setups, the relationship between the combined area of the caliper pistons and m/c pistons will have a drastic effect on feel. When using the stock caliper, a m/c replacement should be close to the piston diameter of the stock m/c.
Old January 12th, 2013, 10:41 AM   #5
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
by the way does anyone know what the piston size is on our stock Master cylinder?
Old January 12th, 2013, 10:51 AM   #6
dino74
dino74's Avatar
From everything I've read, I think you'd probably want a 18x16 Radial or 12mm Axial MC.
CVMA #55
Old January 12th, 2013, 11:14 AM   #7
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
18x16 radial is to big, I've got a 16x18 paired with my 4 Piston R6 caliper and it seems to be the perfect balance if still a bit on the stiff side. The ninja 250 caliper is 2 piston and they're smaller then the R6 pistons and estimate the surface area of the 250 is 40% of the R6. I'd estimate a 12-13 radial piston MC is needed but good luck figuring out what bike that comes on as it's OEM because I'm not sure where else your going to find it.
Old January 12th, 2013, 01:01 PM   #8
what was wrong with the oem mc anyway? still too hard?? i find its not difficult to lock up the front with the stocker MC and cheap double H pads.
DIY - Installing a ZX-6R Master Cylinder VeX 2008 - 2012 Ninja 250R Tech Talk 33 August 27th, 2018 11:30 AM
Aftermarket Master Cylinder krolinked Ninjettes At Speed 11 October 15th, 2014 07:12 AM
Front Master Cylinder Size FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 3 August 14th, 2013 02:38 PM
aftermarket front master cylinder?? tac12345 2008 - 2012 Ninja 250R Tech Talk 4 November 25th, 2012 01:03 PM
Master Cylinder woes.... Rawr 2008 - 2012 Ninja 250R Tech Talk 4 April 22nd, 2009 07:13 PM
