July 12th, 2016, 07:59 PM | #1 |
Join Date: May 2016 Motorcycle(s): 2017 Ninja 300 Winter Test Edition Posts: 589
MOTM - May '18
A warning for fellow migraine sufferers
I just got over a major scare. Seriously thought I was having a stroke!
I had been watching tv and got up to go get a drink of water and to take the trash out. When I went to grab my water bottle my left arm suddenly went completely floppy numb. I was frantically trying to shake it out to no avail when my brain said "hello!!! stroke symptoms!!! call 911!" I called and explained my situation. The total numbness only lasted like 30 seconds tops but while I was talking to 911 my whole left side went tingly numb from the shoulder down to my toes. They checked me out and told me it wasn't a stroke since I was able to walk to the door for them and talk and my face wasn't drooping but I was pretty scared. After they left I remembered that earlier in the day I had experienced a slight headache with visual aura. I'll get that once in a while and it's normally just a signal that a migraine is on the way. After doing a little research the two situations actually go together to form what is called a Hemiplegic Migraine. Quite scary, but the common symptoms are headache/migraine with visual aura, sudden numbness down one side, and a history of migraines. So if any of you get migraines, hopefully this type won't happen to you one day, but I would look it up just in case. That way if it does you don't freak out like I did. Definitely still call 911 cuz you never know if it's a stroke but it might not be. I was so freaked my pulse was 108 and BP was 140/87 (I'm always like 112/70). |
July 12th, 2016, 08:16 PM | #2 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Wow. Glad you're ok.!
July 12th, 2016, 09:38 PM | #3 |
Happy it was "less than more serious"...
July 12th, 2016, 10:06 PM | #4 |
Good that you got checked out and it was "only" a migraine headache.
July 13th, 2016, 04:09 AM | #5 |
MOTM - May '18
Thanks everybody
The paramedics were all cynical and acting like I was freaking over nothing. I wanted to ask them what they would do if out of nowhere half their body went numb. I'm glad I'm ok, and I know what to look out for now just in case it happens again but I sure hope it doesn't. |
July 13th, 2016, 10:27 AM | #6 |
Paramedics would stay calm, in order to keep you calm. If the paramedics freak out, you as the patient are more likely to also get upset. We take emotional cues from each other, and if someone else looks worried, we think there's something to be worried about.
They shouldn't dismiss your fears, though. I'm glad you're ok! |
July 14th, 2016, 11:16 AM | #7 |
Join Date: Oct 2015 Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike Posts: 556
MOTM - Nov '15
I get the "visual aura" thing on occasion where one eye briefly goes almost completely blurry. It usually lasts no more than 15 minutes from when I notice it starting to happen to being back to completely clear again. I asked my eye doctor about it and she said that it was actually a migraine but I was one of the lucky ones becasuse I don't get the headaches that other people do, only the blurry vision in one eye. I can still do almost anything when it happens, but it's pretty distracting so I suppose if I were on a motorcycle when it happened I would pull over and wait till it cleared up.
July 14th, 2016, 06:01 PM | #8 | |
MOTM - May '18
July 14th, 2016, 11:41 PM | #9 |
MOTM - July '15
I believe you. Doctors and paramedics can be dicks sometimes. I think they get into that line of work because they figure "blood n guts are cool. I can stomach seeing people in pain. so why not?" which stems from a lack of empathy for the pain of others, not the desire to help them.
At the end of the day, though, I'm glad they're all there. |
July 15th, 2016, 02:01 PM | #10 |
Glad you're okay.
This happens to me once in awhile as well, but it's both of my arms that go numb & tingly, and my fingers/hands freeze up. I also get really dizzy/nauseated during this time. I've gone to the doctor several times for different things related to it and they've never found anything wrong with me. I also faint sometimes as well. Only one time have I ever had numb arms and fainted at the same time. It's never happened while driving or at work or out in public by myself. The few times it did happen in public, I was always with someone. I do get severe headaches and quite a few different kinds, which has been happening my whole life. I get pretty bad motion sickness too, even if it's just on a swing going back & forth. No one has ever found anything wrong so.. what can ya do but suffer? |
July 15th, 2016, 03:04 PM | #11 |
i've gotten them a few times before. i mostly get ocular migraines... AKA scintillating scatomas. annoying, and scary if you dont know its harmless.
July 15th, 2016, 08:56 PM | #12 | |
MOTM - May '18
The unfortunate thing is that there must not be much money in migraine research. At least not with these rare types like ocular and hemiplegic. All of the articles I've read on the hemiplegic just state that no current research is being done and the condition is rare. Nice.... |
July 15th, 2016, 09:00 PM | #13 | |
MOTM - May '18
July 16th, 2016, 10:52 AM | #14 | |
July 16th, 2016, 11:39 AM | #15 |
MOTM - May '18
That's good. I smoke but I think I'll try to avoid them while going through one of mine. They say the reason they don't like using some common migraine medications for them is because constricting the blood vessels during one could lead to an actual stroke. So I don't know, I'm going to try what is recommended, avoid known triggers and keep as stress free as possible.
July 16th, 2016, 01:41 PM | #16 | |
Many times, I had to stop a trip because I could not see other than some peripherial areas. They lasted about 20 minutes. I seldom have those now, but strong headaches, especially if my wake up time changes. https://en.m.wikipedia.org/wiki/Scintillating_scotoma
To All My Fellow New Englanders | CC Cowboy | Off-Topic | 5 | January 4th, 2014 05:44 AM |
Hello fellow riders :) | redsuns03 | New Members | 9 | August 18th, 2012 08:22 AM |
Hello from L.A. looking for fellow racers! | Diablita | New Members | 10 | January 27th, 2010 04:44 PM |
Hello fellow ninjetters | NinjaBuckethead | New Members | 12 | October 13th, 2009 03:19 PM |
