Old August 22nd, 2011, 01:14 PM   #1
nightrider
Motorcycle(s): Black '09 Kawasaki Ninja 250
Bike not starting?!
I tried to jump start it, did not work. Push start did not work. Tried placing a battery from my cousins bike that is running perfectly into mine, and it did not start. Although when it was connected for the jump start or connected to my cousins bike the electronics all came on. This bike has been sitting around for 2 years after a front end collision although it is all still intact and no visible damage other than cosmetic damage. It hasn't been ridden and had gas in it since the crash. Could someone help me out with this problem? what could be the issue? or issues?
nightrider is offline   Reply With Quote
Old August 22nd, 2011, 01:46 PM   #2
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
You need to take out the carbs and clean them out. When it sits for that long, fuel will gum up the carbs and prevent ignition.
http://www.ninjette.org/forums/showthread.php?t=44330
tons more info on the DIY page http://www.ninjette.org/forums/showthread.php?t=5586
The www.ModMy250.com guy
Old August 22nd, 2011, 01:50 PM   #3
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Kill Switch?
Old August 22nd, 2011, 09:14 PM   #4
nightrider
Originally Posted by CC Cowboy View Post
Kill Switch?
Nah that is good. Think its the carbs.
Old August 22nd, 2011, 09:15 PM   #5
nightrider
Would it cause the bike to not even turnover with a fresh battery?
Old August 22nd, 2011, 09:21 PM   #6
setasai
setasai's Avatar
Fuses? I was gonna say kill switch but fuses are the next thing down to check. If the engine turns over then the battery is fine and then next would be to check the carbs.
Old August 22nd, 2011, 10:45 PM   #7
nightrider
fuses are good engine is not turning over :/ even with a fresh battery
Old August 23rd, 2011, 06:34 AM   #8
Cuongism
Cuongism's Avatar
If it sat with gas in it for 2 years, your jets are definitely gummed up.
Old August 23rd, 2011, 07:58 AM   #9
CThunder-blue
ModMy250.com
If it's not even attempting to crank, then it's one of your safety switches. Kickstand, neutral, or .... I can't remember the 3rd one. Anyone?
Old August 23rd, 2011, 09:02 AM   #10
nightrider
How do I check which one it is, I am very new to riding and don't know much ATM. Any help on how to get this bike goin or even to turnover would be appreciated
Old August 23rd, 2011, 09:35 AM   #11
CThunder-blue
ModMy250.com
So, the first question is: Does it crank?
Old August 23rd, 2011, 10:11 AM   #12
setasai
setasai's Avatar
Clutch?
Crank = yes: carbs most likely
Crank= no: one of the switches or battery or fuse
Old August 23rd, 2011, 10:13 AM   #13
Safety switches are clutch, kickstand, neutral, and kill switch.
Old August 23rd, 2011, 10:14 AM   #14
CThunder-blue
ModMy250.com
Clutch?
Thanks. I thought it was clutch, but wasn't 100% sure. Alex, maybe if you get a moment, you could take pics of the various switches? This questions seems to pop up a lot. Maybe a quick wiki?
Old August 23rd, 2011, 10:15 AM   #15
Next time the bike is out in the sun, sure. I don't know where the neutral switch is, but the other 3 are easy to view.
Old August 23rd, 2011, 11:44 AM   #16
LazinCajun
LazinCajun's Avatar
Motorcycle(s): 2008 Ninja 250 (Blue!)
The neutral switch is buried above the front sprocket on the left side. It's labeled as #8 in the picture below (this is from the service manual, page 16-16). Another good way to find it is to look at the OEM part diagrams: it's part number 13151. (See for example http://www.cheapcycleparts.com/model...semblies/25695) It's been a while since I had to deal with my neutral switch, but IIRC if the neutral light comes on and goes off appropriately I *think* it's ok.
To get to it, you definitely have to take off the front sprocket cover. There's a connector that plugs into it like in the following picture (labeled as #1):
LazinCajun is offline   Reply With Quote
Old August 23rd, 2011, 09:44 PM   #17
nightrider
all your help is appreciated my cousin took a look at the switchs they are fine so are the fuses. SOmeone said to me it could be the tip over sensor since the bike was in front end collission.Anyone know about this?
Old August 23rd, 2011, 09:45 PM   #18
Cuongism
Cuongism's Avatar
I'm 99% positive that the 250 doesn't have a tip over sensor since it's carbed.
Old August 23rd, 2011, 09:46 PM   #19
No tip-over sensor on these bikes.
Old August 23rd, 2011, 10:36 PM   #20
nightrider
in that case then it would have to be one of the switchs since it doesnt turnover, and isn't the neutral since the neutral light comes on. how do i check the other two
Old August 23rd, 2011, 10:52 PM   #21
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
continuity tester to check switches.
"Beep them out".
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old August 24th, 2011, 07:54 AM   #22
CThunder-blue
ModMy250.com
At least with the kickstand switch, you can tell just by pulling it up and trying to start the bike. Easy way to knock it off the list. Neutral switch is a kill switch. The neutral light is just an indicator telling you it's in neutral. I don't think they sit on the same circuit. Although I'm not looking at the manual so I could be wrong.
Old August 24th, 2011, 09:29 AM   #23
setasai
setasai's Avatar
You still havent answered us if it cranks or clicks at all. A new battery that isnt fully charged will still click (starter is ok) but wont crank (battery dead).
Old August 24th, 2011, 09:31 AM   #24
CThunder-blue
ModMy250.com
From his original post, it looks like they tried another battery and that didn't solve the problem.
Old August 24th, 2011, 10:01 AM   #25
LazinCajun
LazinCajun's Avatar
I've got a little free time, so I'll dig through the service manual. I just had the impression that when I had neutral indicator problems a couple years ago, the bike would start while in gear when the neutral indicator was on, so I assumed that the same switch connects to the starter and neutral indicator circuits.
Update:
The service manual recommends inspecting the neutral switch if the neutral indicator on the dash doesn't light up when you start, so they are on the same circuit.
However, in the official inspection section, the manual recommends testing continuity to ground. The switch should have continuity with ground when the bike is in neutral (continuity means ~0 ohms resistance on a multimeter connected to the switch + ground.) Conversely, there should be a nonzero resistance reading when the bike is in gear.
Old August 24th, 2011, 10:16 AM   #26
CThunder-blue
ModMy250.com
Thanks Trey, good to know!
Old August 24th, 2011, 10:39 AM   #27
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
testing continuity
Told ya so.
LMFAO!
Weaksauce
Old August 24th, 2011, 11:10 AM   #28
nightrider
Hey guys all your input is appreciated. And i thought i said it does not turnover in a post earlier, but yeah it isnt cranking at all. Did the switch tests and they are all good, I'm about to push this over to the mechanic right now, I'll be sure to let you all know what was up with it. Thanks
Old August 24th, 2011, 11:49 AM   #29
LazinCajun
LazinCajun's Avatar
Originally Posted by ninja250 View Post
Told ya so.
Can you give any scenarios in which the neutral indicator works properly, but the neutral switch causes the starter logic to fail? I sure can't.
Old September 5th, 2011, 02:56 PM   #30
Where is the clutch sensor/switch? My bike only starts in neutral but I can cruise around all I want after that, so it's not the kickstand switch.
Old September 5th, 2011, 04:20 PM   #31
It's touching the clutch lever when the lever is fully released. As you pull in the lever to the bar, the little pin pops out.
Old September 5th, 2011, 04:43 PM   #32
nightrider
Hey guys got the bike back apparently the relay was unplugged and also the sparkplugs were dead from sitting for 2 years. Thanks for your input. finally riding this baby
Old September 5th, 2011, 04:44 PM   #33
Good to hear! Glad it's up and running.
Bike has trouble starting capriccio 2008 - 2012 Ninja 250R Tech Talk 7 July 19th, 2012 10:37 AM
Bike not starting.... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 2 April 29th, 2012 07:33 PM
Starting New Bike Club! MotoED General Motorcycling Discussion 4 September 20th, 2011 11:20 AM
starting bike james250ninja 1986 - 2007 Ninja 250R Tech Talk 3 April 3rd, 2010 12:12 PM
Bike is not starting now :( bikermunda 2008 - 2012 Ninja 250R Tech Talk 6 January 3rd, 2010 10:02 PM
