Old October 13th, 2012, 01:46 PM   #1
TGRIFF
Motorcycle(s): 08 Ninja 250R
GPX Pro
Any racers wire their GPX pro into their 250 to track some of the other features it offers? How did you do it? Any tips?
TGRIFF is offline   Reply With Quote
Old October 13th, 2012, 11:13 PM   #2
Gurk
Done here.
Motorcycle(s): -
I'm not a racer but I ride on track exclusively. I like to see my lap times so I got a GPX pro for my r6. I ended up getting rid of my stock dash board as I hooked up GPX to my bike and can monitor
Accurate speed via GPS,
RPM's,
Gear,
Water temperature,
Fuel Indicator,
Throttle Position (when and where I open/close throttle)
Brake Position (for now it's on or off but I'll add pressure sensor to show % for this one also)
Soooo, everything the dash shows + a hell lot more.
You gotta know that I'm an absolute noob as far as wiring goes. All I can do is cut wires and strip them together. What I did was go to XT Racing forums and asked for schematics. There's a few XT Racing employees there who monitor and post on the forums and one of them gave me a complete schematic showing which wire on the bike should be connected to which data cable on the GPX.
I suggest you go there and post your bike year/model and ask for the same thing.
Sorry all that type and not helping you directly but just wanted to say it's worth the effort and XT people can definitely help you! I got a response from them instantly.
Gurk is offline   Reply With Quote
Old October 14th, 2012, 12:14 PM   #3
TGRIFF
Thanks for the response. I will head over there and see what I can find. I will let you know how it goes.
Old January 19th, 2014, 11:37 PM   #4
chugs
Schönen Tag noch
chugs's Avatar
Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica
Just picked up a gpx pro for the ninja any updates to this thread?
chugs is offline   Reply With Quote
Old January 20th, 2014, 06:36 AM   #5
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Pics of install?
Old January 20th, 2014, 08:32 AM   #6
I think @iZapp has one that he mounts on his son's 250.
Old January 20th, 2014, 01:24 PM   #7
iZapp
former ninja 250'er
iZapp's Avatar
Motorcycle(s): Aprilia 1000R, CRF450, CBR600RR tracktoy, Ninja 250 -- GONE!!!!!
hiya buddy! yah we've got one on his bike, and the install is nothing more than a big piece of velcro right on the stock speedo cluster. RPM taps into the crank sensor, and for TPS i had to make a little bracket to hold the string-pot sensor that connects to the throttle lever. i can upload a photo if interested. - funny story... i had csmith convinced it was actually a remotely controlled throttle servo i could use when the kid wasnt going fast enough!!
iZapp is offline   Reply With Quote
Old January 20th, 2014, 01:35 PM   #8
Hahahahahahahaha, yep! I remember that too.
Old January 20th, 2014, 02:15 PM   #9
DCMoney
DCMoney's Avatar
Details on the string potentiometer would be awesome! I hate not knowing my throttle position...
MCRA.com
Old January 20th, 2014, 03:31 PM   #10
chugs
Schönen Tag noch
chugs's Avatar
+2 pix would be awesome.
Old January 20th, 2014, 04:01 PM   #11
iZapp
former ninja 250'er
iZapp's Avatar
the blue circles are the two tapped holes for the screws on the pot (screws come in from back side). the red arrow shows the string going to the throttle. the pot is mounted to a 1/8" thick aluminum plate which is trimmed to fit perfectly in the tiny little spot in that corner and is held in place with the large rear motor mount nut. the string pot is an early billet alum one that XT was selling. dunno if they still are. the electrical cord is shown leaving the pot from about the 9 oclock position. sorry for the crap photo.
Old January 20th, 2014, 09:37 PM   #12
sierrahotel
CVMA #92
Motorcycle(s): harleys
Crank sensor works ok? For some reason I thought it wouldn't, so I use inductive- which is really noisy.
sierrahotel is offline   Reply With Quote
Old January 21st, 2014, 04:59 AM   #13
iZapp
former ninja 250'er
iZapp's Avatar
plug n play
Old January 21st, 2014, 09:53 AM   #14
zvonler
Motorcycle(s): 250R
chugs, I see you found my thread over on xtracing.com already, but here's a link to my post about what I've got the GPX monitoring, in case others want to see.
I've got the device wired up to monitor/record RPM, oil pressure warning, coolant temp warning, fuel level, and brake activation. The oil pressure, coolant temp, and fuel level sensor circuits are all simple voltage dividers that use the 5V reference supply from the GPX and a resistor, just like the diagram that's posted earlier in that thread. For the oil and coolant sensors, the resistors are 1k ohm, and for the fuel level I used a 100 ohm resistor. I made another voltage divider using the front brake switch by wiring one of its contacts to ground and using a 10k ohm pulldown resistor on its other contact.
I can take some pics later to post but I don't know how helpful they'll be - I've shrink-wrapped and electrical taped all the solder joints and then covered them with plastic loom.
zvonler is offline   Reply With Quote
Old January 21st, 2014, 11:47 AM   #15
DCMoney
DCMoney's Avatar
Thanks, was hoping you found a cheap source for the sensor.
MCRA.com
Old January 21st, 2014, 12:52 PM   #16
chugs
Schönen Tag noch
chugs's Avatar
Can u provide a visual schematic for each voltage divider?
Old January 22nd, 2014, 08:16 AM   #17
Knolly
Motorcycle(s): Daytona 675
Finally unpacked my GPX Pro last weekend, so this is all pretty great stuff. Gotta sit down and hammer out some of this before the season starts.
Knolly is offline   Reply With Quote
Old May 6th, 2014, 04:08 PM   #18
iZapp
former ninja 250'er
iZapp's Avatar
the string-pot (linear potentiometer) used for throttle position that's shown above is for sale. we sold our 250 track stuff and the pot is no longer useful to us. PM me if interested. 75 plus shipping.
Old May 13th, 2014, 03:28 AM   #19
rc-rick
Motorcycle(s): '09 ZX6 (street), '04 RC51 (street/track), '08 Ninja 250 (race)
There is only one position for the throttle...PINNED!
That's why I'm up front.
rc-rick is offline   Reply With Quote
XT Racing GPX Pro green_bread Items Wanted 2 October 28th, 2014 04:44 PM
Gpx 250 clutch issue (i think) bowerbird100 1986 - 2007 Ninja 250R Tech Talk 3 June 22nd, 2014 03:14 PM
New GPX 3rd Gen Owner From Australia burnrich New Members 14 January 22nd, 2014 08:46 PM
XT GPX Pro DCMoney 2008 - 2012 Ninja 250R Farkles 16 September 25th, 2013 05:40 AM
FS: Joe Rocket GPX 2.0 Gloves rasta Gear-related 11 September 24th, 2013 10:00 PM
