Old September 7th, 2013, 06:36 AM   #1
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
15/43 sprocket combo chain length?
Hello all. i am looking into changing my gearing to 15/43 to help on fuel economy. if i use that combo will i be able to use the stock chain still? I am halfway on the axle adjustment range. bike only has 1,000 miles so chain wear shouldn't be an issue yet. I'm not worried about loss of acceleration for the 250. I'm not riding it for the performance anyway. it will never be a speed demon so i might as well exploit its strong points. Thanks for any advice on this subject.
gantt is offline   Reply With Quote
Old September 7th, 2013, 07:00 AM   #2
Originally Posted by gantt View Post
.............Thanks for any advice on this subject.
http://www.rbracing-rsr.com/chainlength.html
You are welcome
Old September 7th, 2013, 07:02 AM   #3
I am thinking the stock chain should be just fine.
Old September 7th, 2013, 07:26 AM   #4
gantt
gantt's Avatar
Thanks for the link. yes that combo is almost exactly the same length. problem solved !!
Old September 7th, 2013, 07:30 AM   #5
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
My software says to adjust the sprocket 5mm more backward, with the FI-Model you have to go 4mm more forward.
Old September 7th, 2013, 07:49 AM   #6
gantt
gantt's Avatar
I can work with 5mm's. thanks for the support. best 250 forum around. by far the most lively too!
Old September 7th, 2013, 08:35 AM   #7
Thanks for the link. yes that combo is almost exactly the same length. problem solved !! ............
You are welcome.............. and thanks, there is great group here trying !!!
Old September 7th, 2013, 12:30 PM   #8
gantt
gantt's Avatar
Do you think this could be "too much" gear for the engine to efficiently operate?
Old September 7th, 2013, 01:31 PM   #9
It should be OK if your engine has good torque.
Check this old thread, where 15/41 is discussed:
http://www.ninjette.org/forums/showthread.php?t=64112
This is a leverage exercise, you gain some final speed but lose some torque, which is more noticeable at start ups, up-hill, counter-wind, etc.
Old September 8th, 2013, 05:39 AM   #10
infinitethrill
forever a n00b
infinitethrill's Avatar
Motorcycle(s): 08 ex250J, 78 GL1000, 01 ex250f, 99 VFR800FI
08 ninjette here, ran 15-45 for a few years and recently swapped to 15-43. The stock 106 link chain works fine, with room to adjust on the swingarm. Dropping to 4th to pass at freeway speeds (70-80 mph) is fine, and 6th will cruise at a cool 9k at 80 indicated. I did 1000 miles in a single sitting and having the revs lower definitely helps with that. Two up is a bit more difficult, the bike likes higher revs and lower gears however for acceleration. Went from averaging 55mpg to 65mpg with the changeover. Fill ups don't need to happen until 215 miles on the tank anymore. Positive change, do it!
infinitethrill is offline   Reply With Quote
Old September 8th, 2013, 06:31 AM   #11
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
stock length is good don't cut it please like the guy did that I bought my bike from.
Old September 8th, 2013, 06:40 AM   #12
gantt
gantt's Avatar
Thanks. i was hoping to hear some personal experience too. I think i will be happy with the swap. thanks a lot.
Old September 8th, 2013, 06:42 AM   #13
gantt
gantt's Avatar
Whatcha mean? He cut the stock chain?
Old September 8th, 2013, 10:21 AM   #14
I RACED on 15/42 with the stock chain. The only thing that sucks is steep hills while 2up.
Things you will notice right away;
Less buzzy at highway speeds
The bike feels more relaxed at highway speeds
You will shift LESS on a normal street ride but have to shift MORE on the track
It feels like 15/43 or 15/44 should have been stock gearing lol
Ebay chain/sprocket combo? corksil General Motorcycling Discussion 29 December 19th, 2013 06:52 PM
Getting a new chain and sprocket kittyslasher 2008 - 2012 Ninja 250R Tech Talk 10 December 9th, 2013 12:55 AM
Sprocket and chain length question. MKlein3004 Ninjettes At Speed 2 August 14th, 2013 06:40 PM
Will raising my suspension with shorter dogbones change my chain length requirement? CZroe 2008 - 2012 Ninja 250R Tech Talk 7 June 16th, 2012 02:53 PM
Front/rear sprocket combo wellcraft 2008 - 2012 Ninja 250R Tech Talk 17 January 31st, 2011 04:42 PM
