Old April 25th, 2016, 08:50 AM   #1
abhijitz
Motorcycle(s): Many Two Wheels ..
Difference between these models?
What is the difference between these models? I am trying to locate the right fairing part # for 2014 Ninja 300 ABS. Its white (i guess its called Pearl Stardust White?).
NINJA 300 ABS (EX300BEF)
NINJA 300 ABS (EX300BEFA)
NINJA 300 ABS (EX300BES)
NINJA 300 ABS (EX300BESA)
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
abhijitz is offline   Reply With Quote
Old April 25th, 2016, 08:52 AM   #2
abhijitz
I now see "A" at the end means Special Edition. That leaves to what does "F" and what does "S" stand for?
Old April 25th, 2016, 09:16 AM   #3
Brother Michigan
Motorcycle(s): 2013 Ninja 300
I do not know for sure, but I'm betting one is the CARB-compliant model and the other is not. If that's the case, fairings meant for ether model would be fine.
DISCLAIMER: I generally have no idea what I'm talking about.
Old April 25th, 2016, 09:42 AM   #4
abhijitz
Called Kawasaki, they said "F" stands for lime green and "S" stands for all other colors.
Old April 25th, 2016, 09:43 AM   #5
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
The F and the S seem to have slightly different part numbers for a lot of the painted parts. Tank, fender, fairings, etc. But I can't seem to see much difference. There's one clamp different between them on the fuel evap system, so I don't think it's a CARB thing.
I'm curious to see if we can find an official answer of what it means. What model does your bike's VIN up as?
Old April 25th, 2016, 09:44 AM   #6
It the "marketing code" assigned to the model
first box: A = w/o ABS : B= ABS
second box: D = 2013 : E= 2014; F= 2015;
third box: F = green : S = not green
fourth box: A = special edition (SE)
Not sure how official this is though... :\
Old April 25th, 2016, 09:48 AM   #7
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
It's been a while since I heard anyone argue this point so I will throw it out there. "F" stands for Faster which is obviously the color green. "S" means Standard .
So color means everything when it comes to Power:
Spoiler for topic:
It might just be the [you] tag
Old April 25th, 2016, 10:01 AM   #8
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Dirty Unicorns are the best.
Goin' fast on slow bikes!
Old April 25th, 2016, 10:03 AM   #9
InvisiBill
InvisiBill's Avatar
The F and S diagrams both contain part numbers for black/red/white. The FA and SA (Special Edition) diagrams both contain white/green part numbers.
https://www.kawasaki.com/Parts/Parts.../2014/EX300BEF
Code:
35004-0318-H8 	FENDER-FRONT,EBONY 	1
35004-0318-15I 	FENDER-FRONT,P.RED 	1 	CAUS
35004-0318-25Y 	FENDER-FRONT,P.S.WHITE 	1 	CN
https://www.kawasaki.com/Parts/Parts.../2014/EX300BES
Code:
35004-0318-234 	FENDER-FRONT,P.RED 	1 	CAUS
Neither of them have green, but they do have different red parts...
https://www.kawasaki.com/Parts/Parts...2014/EX300BEFA and https://www.kawasaki.com/Parts/Parts...2014/EX300BESA both show the same green and white part numbers (with the white being the same as the regular white above).
Code:
35004-0318-777 	FENDER-FRONT,L.GREEN 	1
*shrug*
P.S. Black is first because it's fastest.
Old April 25th, 2016, 10:51 AM   #10
APEmike
Motorcycle(s): 2014 Ninja 300
www.kawasakipartspitstop.com is the site I use for anything parts related. Usually easier to use that Kawi's own site and it includes just about every model.
I ride because therapy is too expensive, and less fun.
Old April 25th, 2016, 09:17 PM   #11
abhijitz
You are pretty much spot on. This is what the Kawi rep told me.
Old May 3rd, 2016, 09:17 PM   #12
Its_Scott
Motorcycle(s): 2009 Kawasaki Ninja 250R, 2014 Kawasaki Ninja 300 SE ABS
Thanks for this info! Been trying to figure this out for awhile now
Its_Scott is offline   Reply With Quote
Difference between these two PC5's ? Jason5885 2008 - 2012 Ninja 250R Tech Talk 7 January 16th, 2015 09:32 AM
Whats the difference? Armo55 2008 - 2012 Ninja 250R Tech Talk 15 January 21st, 2013 07:29 PM
What is the difference loz944 General Motorcycling Discussion 39 January 26th, 2012 04:43 PM
Is there any difference hmm ?? GiGs 2008 - 2012 Ninja 250R Farkles 4 January 6th, 2011 11:34 PM
Whats the difference ? Plasma 2008 - 2012 Ninja 250R Tech Talk 0 September 1st, 2009 03:48 PM
