March 9th, 2011, 10:55 PM | #41 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
just hopped home to install them, took about 30 min~
in this picture, you can see the color difference quite well. where it was a little darker, it was less evident. once installed, it actually didnt look so bad. i have yet to take the bike out in the sun, where the color of the levers will probably change and look more like in the 1st pic. but im fine with it. now im wondering how well that color will stay on in the long run. installing them was a piece of cake. i took the opportunity to tighten all of the bolts on the levers, they were all quite loose. that took the wobble out of most of the joints, and im satisfied now that it seems like they wont be rattling away in my hands during a ride.
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
March 10th, 2011, 07:31 AM | #42 |
Join Date: May 2010 Motorcycle(s): 2010 Kawasaki Ninja EX250 Special Edition Red/Black Posts: 455
I bought those exact same levers, color and everything. They look really good. Can't wait for mine to come in. I have the 2010 se red/black. From the looks of those pictures, they should match my bike perfectly.
'10 Ninja 250R SE Red/Blk Mods: Projekt D FE, Protons, HB Blk Windscreen, HIDs, TBR Blk Series Slip-On, Shogun Sliders, Solo Cowl, Integrated Tail Light, Gls Blk Rear Fender, Red Accents |
March 12th, 2011, 12:32 PM | #43 |
Join Date: Jan 2010 Motorcycle(s): 09 Ninja 250R Posts: 4
I ordered a pair of the royal blue levers. They match the '09 candy thunder blue pretty well. I've had them on for close to two weeks now. I've had no problems with them at all. Here are a few pics taken with my iphone.
March 12th, 2011, 10:46 PM | #44 |
Join Date: Apr 2010 Motorcycle(s): 2009 Blue Kawasaki Ninja 250R Posts: 66
They look really nice. How's the adjustability range?
March 13th, 2011, 10:03 PM | #45 |
they adjust good from 1 through to 6, but not much past that! lol
well it depends on the size of your hands, or how you feel comfortable holding them i guess~ i have both set on #3 at the moment. i can 1 or 2 finger brake without having the brake lever touch my other fingers, but they aren't too far away to be akward to pull back on like they used to be. the clutch lever feels better now too. i used to have the clutch cable set a little loose, so that the lever didnt sit totally straight/tight when im not pulling the clutch in. now i got the tension good, and adjusted the levers, to bring them back a little, which eliminates the loose/free movement that i used to have with the oem levers.
March 17th, 2011, 01:27 PM | #46 |
My levers came in today. Ordered March 2, got them March 17th. Even faster than expected delivery date of 3/22. Quality looks really good. No scratches or anything on them.
March 18th, 2011, 08:47 AM | #47 |
Tooks some pics of the levers up against my tank. They are a little more pinkish red than my tank, but I think they match well.
Here's a pic of the adjustable lever versus stock lever. They are slightly smaller than stock. Here's the adjustable lever compared to the non-foldable shorty version of the 2wheels levers. They are slightly longer than the shorty version.
April 3rd, 2011, 06:08 PM | #48 |
Just got mine on Saturday, ahead of even the early shipping estimate (12 days order to door). They look/feel great and the 50-mi testdrive this afternoon was a delight. No more goalie-thumb from stretching for the clutch. The increased weight vs the stock handles seems to have helped with vibration as well.
The finish looks better than factory and fit is almost as good as factory. I say almost because I had to push the clutch cable into the adjuster bolt, while on the stock it just slid in. Seems like the receiver housing for the rotator cuff on the end of the clutch cable could've been cut about 1-2mm further towards the back of the bike to achieve a perfect fit. I don't think it'll cause any problems, though I'll definitely keep a close eye on it.
Proud member of the Blue Army Last futzed with by Momaru; April 3rd, 2011 at 09:37 PM. |
April 13th, 2011, 06:16 PM | #49 |
Well, you get what ya pay for. Just got mine 10 days ago and the inside corners of the switches are already turning purple; have been for a few days but I've been in denial.
This is indeed some cheap anodizing work. But the machining still looks good and that's what counts
April 13th, 2011, 07:46 PM | #50 |
on a totally different matter, but regarding paint issues... i found that black paint on the bars that hold the rear view mirrors on my bike have started to peel off
im thinking of getting them powder coated at some point maybe...
April 14th, 2011, 06:40 AM | #51 | |
April 20th, 2011, 03:28 PM | #52 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
it's not. i've had mine for about 7 weeks now and and the black is now light purple - guess the chinese anodizing couldn't hold up to the florida sun. other than that, i have no complaints - functionally, they're great. if it really starts to bother me, i'll get the black parts pced and they'll look perfect forever.
April 20th, 2011, 08:42 PM | #53 |
I contacted the seller/distributor (the2wheels) earlier this week about the fading. He's offered to send me a new set o' adjusters since that's the only place I've got that's fading. I don't know if these will be any better quality anodizing than the original ones, but he's at least willing to make the attempt.
Mechanically the levers are holding up very well and having them closer to the bars (than stock) has been a godsend. The minor issue of the clutch cable possibly rubbing/abrading on the adjustment bolt doesn't seem to be a problem. That said I slapped a pretty good bit of lithium grease on there.
June 3rd, 2011, 03:10 PM | #54 | |
Mechanically they still seem to be good, but the anodize
June 3rd, 2011, 03:59 PM | #55 |
Accesories Guru
Join Date: May 2011 Motorcycle(s): '99 EX250(Cafe/fighter project) Posts: 537
Does anyone know if this ones will mount on pre gen Ninjas? looking to get some for my cafe project and my 96 ZX6R street fighter.
June 3rd, 2011, 06:43 PM | #56 | |
June 5th, 2011, 04:04 PM | #57 |
Opinionated individual :)
Join Date: May 2011 Motorcycle(s): 2010 Ninjette Special Edition (red/black) Posts: 342
Yum, I want some for my SE red/black.
Although those red levers should be more red than pink :\
Yoshi slip on, shimmed 2 washers, zip tie throttle mod, pre-load #2, snorkel delete 2010 SE 250R! Miles in the saddle: 1000 |
June 6th, 2011, 11:07 AM | #58 |
Way too late. Before the feedback/buyer dispute window ended, they were still talking to me, about sending replacement adjusters. Now that it's closed, they play ignorant or don't respond at all. Coincidence? Possible, but...
June 6th, 2011, 07:46 PM | #59 |
Contact them to let them know their reputation is on the line.
Give them a link to this thread so that they can see for themselves. Im not buying from them until the discoloration and customer service issues are resolved.
June 6th, 2011, 10:16 PM | #60 |
the ones i bought havent faded. used them for a while already. the color matches perfectly with another anodize part that i added to the handlebar (the bar end weights) from KTC.
i bought it directly from their website and they shipped it from HK. i wonder if you bought it from ebay if its direct from them too, or if its a middleman, and maybe that middleman is the one whos playing "dumb" either way, the saying "you get what you pay for" is definitely relevant in most cases in life. you cant expect a 60 dollar piece of hardware to be identical to a $250 piece, hehe... personally i'm happy with the levers they sent me.
June 27th, 2011, 07:50 PM | #61 |
Join Date: Jun 2011 Motorcycle(s): 2009 ninja 250R Posts: 66
thinking on getting these in gold for my black 250r
2k9 250r, Gold Shorty Levers, Snorkel X, K&N filter, Fender Elim, Puig Racing Tinted windscreen, red wheel stripes, Akrapovic carbon slip-on, pro grip tank protector, Solo seat cowl, kleen air X |
June 27th, 2011, 09:00 PM | #62 |
i bought black... they're now silvery grey... maybe closer to gunmetal after a few months. i think i like the color they are now more than black, although it doesn't really match very well. still decent metal, and they look to be cut on a CNC with a decent blade, although they weren't polished up afterward. still worth what i paid for them.
August 12th, 2011, 09:26 AM | #63 |
Join Date: Jan 2011 Motorcycle(s): 10' Ninja 250R Posts: 164
That´s mine:
Sadly the golden in levers and grips doesn't match. Both pieces are from The2Wheels. But the quality's awesome. Cheaper and good.
August 12th, 2011, 10:07 AM | #64 |
muzur: I noticed your mirrors. Are those the ebay ones? Do you like them?
Sorry to 7500 the OT. EDIT: I just found your origional thread. Could you maybe post a follow-up on that thread? I want to make sure you still like them Sorry, back to topic....
August 12th, 2011, 10:14 AM | #65 |
Sexy Beast
Join Date: Mar 2011 Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster Posts: A lot.
Same here
August 12th, 2011, 10:26 AM | #66 | |
I like them. Almost the same view on the standard ones. I just needed to made some adjustments to fit. Just one con: A little rust in the first wash. I've used WD-40 to fix that and works fine. I made a DIY here: http://www.ninjette.org/forums/showthread.php?t=77788
the2wheels Adjustable Levers | TBC | 1986 - 2007 Ninja 250R Farkles | 40 | January 11th, 2014 10:13 AM |
the2wheels adjustable levers for newgen | leia | Motorcycle-related | 6 | March 27th, 2012 01:28 PM |
Review: Adjustable/Foldable levers by the2Wheels | Cuongism | 2008 - 2012 Ninja 250R Tech Talk | 16 | March 19th, 2012 12:30 PM |
What adjustable OEM adjustable levers fit? | ChaosFromAbove | 2008 - 2012 Ninja 250R Tech Talk | 6 | July 29th, 2010 11:49 AM |
