April 1st, 2011, 11:56 AM | #1 |
Join Date: Apr 2009 Motorcycle(s): 09 Ninja 250 Posts: 184
Help with confusion over tire sizes
I'm trying to order new tires for my bike and I'm confused over tire sizes. I want to order the Bridgestone BT45's but it appears that there are two different tires with the same tire size. One of the tires has the following info:
BRIDGESTONE 110/70-17 M/C 54H Battlax BT45 F NOTE: This tire has a code letter (G), which indicates that it is recommended for the specified motorcycles, and may also have been the original equipment tire. It can also be used on other motorcycles where appropriate. The compound and construction of the tire is uniquely suited to the weight, horsepower and handling characteristics of the motorcycles listed, even thought the rest of the description and specifications may match other tires with the same name. Would this tire work with the 2009 Ninja. What would be different about this one versus the 110/70-17 without the "G" rating? So confused... |
April 1st, 2011, 12:25 PM | #2 |
Join Date: Jul 2010 Motorcycle(s): 2008 Ninja 250r, 2007 Daytona 675 Posts: A lot.
http://www.webbikeworld.com/Motorcyc.../tire-data.htm
Never heard if a G rating though (other than kiddie movies!). |
April 1st, 2011, 12:53 PM | #3 |
Thanks! I think I'll wait until I can find one without the "G" rating just to be safe. Maybe a "G" rating means it's for people who ride like wussies! LOL
April 1st, 2011, 01:02 PM | #4 |
It sounds like it's just a database indicator and not a different tire. FWIW, that is a front tire.
April 1st, 2011, 01:32 PM | #5 |
Join Date: May 2010 Motorcycle(s): Current: '11 ZX-6R; Previous: '09 Ninjette; '08 ZX-6R (Ex-Wife '09 TU250X) Posts: 981
It's for the GS500/GS500F made by Suzuki. I ran into the same problems while I was doing my tire research. I would not buy it personally. There is no reason for Bridgestone to sell the tire with the "G" notation if it were exactly the same as the other "standard" tire. The Suzuki bikes are a good bit heavier, somewhere in the 75-100 lb range, and the compounds may not heat up as well as they should for the Ninja.
I was going to get BT-45s as well, then decided I wasn't as concerned about mileage. Again, after more research I went with the BT-016. The front comes in our Ninja's size, but the smallest rear is a 150/60/17, though many people have sworn by this tire in this size on the stock rims. There are pages about this stuff in the Tech section. I ordered a front last week at a killer deal through Rocky Mountain ATV/MC for $57 shipped. It came in yesterday. I will be ordering the rear shortly. |
April 1st, 2011, 02:10 PM | #6 |
More discussion on this same point in this thread.
April 1st, 2011, 03:01 PM | #7 | |
Join Date: Feb 2011 Motorcycle(s): '96 EX250 Posts: A lot.
April 1st, 2011, 03:43 PM | #8 |
Texas Newbie
Join Date: Sep 2010 Motorcycle(s): 07 Ninja EX250, 07 FZ6 Posts: A lot.
Where will you get your tires mounted in the DFW area???
Monkey Wrench in Arlington, said I could have my tires ship to the shop and they would mount for $70... |
April 1st, 2011, 03:48 PM | #9 |
April 2nd, 2011, 05:20 AM | #10 | |
I've not had any luck finding the BT45s online anywhere and CCoD has searched high and low for a set. I'm just going to go with a set of the Dunlop GT501s. Cycle Center keeps those in stock. I'm going on a trip on the bike at the end of April so I want to go ahead and get new tires before I go. |
April 2nd, 2011, 05:21 AM | #11 |
Thanks for all the help everyone!
April 3rd, 2011, 09:29 AM | #12 |
Join Date: Dec 2010 Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125 Posts: 812
Great tires, real soft outsides for cornering and hard center for speed and endurance. Good luck. Changing tires is one of the first DIY's all should equip themselves to do, especially if you ride "I just put them on" tires like I do.
April 4th, 2011, 09:26 AM | #13 | |
ModMy250.com
Join Date: Sep 2010 Motorcycle(s): 2009 Ninja 250R, 2005 R6 Posts: A lot.
As far as tire changing goes, I just purchased my BT-023's from Revzilla. I'm waiting for my tire irons, weights, and steel valve stems to arrive. I'll probably make a home made bead breaker with some 2x4's and buy the tire balancer from HF for $50. I think anyone who needs to change tires more than once a year or two should do their own tires. Youtube has a bunch of videos on how to change tires and it seems extremely easy. Scudman's videos are very informative.
The www.ModMy250.com guy |
April 4th, 2011, 11:56 AM | #14 |
I read the link Alex provided and would have gotten the BT45's with the "G" rating but I am kind of in a time crunch. I will be out of town next week, home for a week and then I'll be taking a trip on the bike so I needed to get my maintenance done this week. By the time I found out I could use the BT45's it was too late to get them ordered and delivered in the timeframe I needed them.
April 4th, 2011, 12:17 PM | #15 |
ModMy250.com
I was seriously considering the BT-45's but went with the BT-23's instead. The BT-023's are radial tires and from what I read on the net, radials > bias ply (which are what the BT-045's are). On Bridgestone's website, both the 23 and 45 are sport/touring tires. The bolded touring means the tires emphasize touring over sport. I've read a few different sites about radial vs. bias ply and it seems that for grip and tread life, radials are better.
Tire sizes/tire brand??? | Tadydrift | 2008 - 2012 Ninja 250R Tech Talk | 10 | January 5th, 2015 05:24 AM |
Mismatched Tire sizes... | DmbShn41 | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 11th, 2014 12:28 PM |
Tire Sizes | Kokosun | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 8th, 2013 08:47 AM |
Tire sizes | fredhsu | General Motorcycling Discussion | 12 | August 9th, 2012 07:37 PM |
Question about tire sizes! | claymaker | 1986 - 2007 Ninja 250R Tech Talk | 4 | July 14th, 2012 01:26 PM |
