September 10th, 2012, 06:19 PM | #1 |
Bike completely dead - no electrical
Wife is on the way with tools, light, manual, etc. But at the moment I'm stranded at work and this thing is my only transportation.
Problem = As soon as I hit the starter button, I heard a noise. It was a single click, maybe a pop,..... I only heard it once, so it's hard to say what it was. The noise definitely came from the back half of the bike (possibly tail, but not positive). Thinking I may not have hit the button long enough, I hit it again and.... nothing. Then I noticed ALL the indicator lights were dead. I checked the 30A fuse, and it's all good. I have the BRT TIS installed, and think that may have died on me . If that's the case, it's fortunate I have the original OEM igniter, and it's on the list of things for wife to bring. Any tips or ideas will be greatly appreciated. Those that know me know I do all my own work, but don't really KNOW a ton about these things... it's mostly DIYs, trial & error.
September 10th, 2012, 06:21 PM | #2 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
the only pops i hear on start up are the rare miss fires (i think thats what they are called) where the exhaust just makes a huge pop. other than that idk sorry i couldnt be any help
September 10th, 2012, 06:24 PM | #3 |
Yeah, it definitely wasn't that.
September 10th, 2012, 06:42 PM | #4 |
Jigglin' your Jiglets
MOTM - Apr '13
Your battery is dead, the click is some thingymajig in the starter, someone will come in and clarify that.
Good news though, you can fix the bike without any tools! Just push start it and ride it for half an hour. Heres a guide
September 10th, 2012, 06:45 PM | #5 |
Join Date: Apr 2011 Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold) Posts: 479
Did you check all the other fuses?
September 10th, 2012, 06:49 PM | #6 |
Simple stuff first, fuses & battery connections.
September 10th, 2012, 07:14 PM | #7 |
The main 30a fuse, and IG fuse in the little box looks good.
Battery reads 12.9v Also, plugging in the OEM CDI didn't do anything.
September 10th, 2012, 07:18 PM | #8 |
I'm trying to test the ignition relay, but am really dumb at this.... looking at the manual, but don't know what to set the multimeter at, and manual refers to an infinity vs. 0reading, but dont' know that that would be on the display....
September 10th, 2012, 07:19 PM | #9 |
Means nothing if not under load.
If you measure it while cranking the starter and the volts fall close to nothing, the battery is dead. I would try what Jiggles has suggested or would jump start the bike from a car (not running engine !!). http://faq.ninja250.org/wiki/How_to_...attery_is_dead http://faq.ninja250.org/wiki/How_to_...ike_from_a_car
September 10th, 2012, 07:19 PM | #10 |
MOTM - Apr '13
Push start the bike.....
September 10th, 2012, 07:40 PM | #11 |
Ignition relay seems fine too..... as far as I could tell. It clicks when you connect it directly to the battery, reads 1 w/o power, and 0 under power (on the multi meter).
I'll try push or jump start to satisfy you guys, but I'm nearly certain the battery is good.... but I'm hoping to come back so you can all tell me you told me so There is no weak cranking, because it is 100% lifeless. The dash (including my little gear indicator LED gauge) is completely dead too. It was all on until I hit the ignition that one time, then it all went dead.
September 10th, 2012, 07:49 PM | #12 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
if its a relay, just tap it to "shock" into working. Are any lights coming on? brake? turn signals?
September 10th, 2012, 07:51 PM | #13 |
MOTM - Apr '13
Cmon guys!
push start it Push start it Push Start it Push Start It PUSH START IT PUSH START IT! PUSH START IT!!!
September 10th, 2012, 07:59 PM | #14 |
i did that yesterday for shits n giggles, was surprised how easy it was.
did u check the mini fuses ? |
September 10th, 2012, 08:08 PM | #15 |
ninjette.org mafioso
Join Date: Jul 2012 Motorcycle(s): 2009 Ninja 250R Posts: 337
I'd take Jiggles' advice to just get it home, then take a look at fuses and relays. A pop and then nothing (not even another pop) sure sounds like a fuse.
September 10th, 2012, 08:08 PM | #16 | |
I tried, but pushing wasn't very effective because having not eating in 12 hrs, I was afraid I would drop it jumping on.... I tried, but wasn't moving very fast when I hopped on. Yes, fuses also looked good.
September 10th, 2012, 08:10 PM | #17 |
Yes, one pop (or click, not sure which).
September 10th, 2012, 08:18 PM | #18 | |
MOTM - Apr '13
Cmon man, if a guy who can't walk for more than 5 minutes can push start this bike then
September 10th, 2012, 08:24 PM | #19 |
Yeah, I actually did watch your vid, and was impressed how easy it was.... but alas, I'll need a push. Going to jump off the car, and hopefully my next response will be from home.
September 10th, 2012, 08:29 PM | #20 |
Best of luck Bob!
September 10th, 2012, 08:30 PM | #21 |
Good luck, Bob!
September 10th, 2012, 10:05 PM | #22 |
Well, I am writing from home, but my bike is not here .
With a little help I was able to push start it, BUT it had "issues." The lights and RPM stayed very low, even when it was warmed up. I also noticed the tach was pegged all the way right, and when I touched the throttle might jiggle a little erratically. When I tried to give it gas, it really wouldn't rev.... too much would kill it, and anything less would make it feel like it was knocking inside. I tried this with both the OEM CDI, and the BRT TIS units. They acted a little differently, but essentially did the same crazy stuff. On a whim I checked both header pipes, and they where both hot..... I don't know if that actually tells you if both cylinders are running, but it's all I got. Next I hooked it up to the truck, and it fired right up and acted normally. I let it run for a few minutes while hooked to the truck, and then disconnected the jumpers. As soon as I did the lights on the bike got really dim, and the engine idle got really weak. At this point I was too tired to wait for a tow so I left it there. Actually I tried to push it into the office, but it wouldn't round a hallway corner. It was interesting trying to back it out.... what a day. Soooo... I haven't a clue at this point. Does it still sound like the battery? Charging issue? Diode, rectifier, or other electrical?
September 10th, 2012, 10:07 PM | #23 |
MOTM - Apr '13
Yes, your battery is dead, the tach goes wacko when the battery is weak like that
Honestly it sounds fine to me just a dead battery
September 10th, 2012, 10:11 PM | #24 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
Have you checked all the grounds? Battery negative and the ground to the frame?
September 10th, 2012, 10:13 PM | #25 |
I sure hope you're right; and if so I'm going to send you the REAL pictures as a prize for solving my problem.
September 10th, 2012, 10:13 PM | #26 |
As far as I know I did. They seemed fine to me.
September 10th, 2012, 10:56 PM | #27 |
Join Date: Aug 2009 Motorcycle(s): '08 250R (sold), 2013 300SE Posts: 276
Big clue was when hooked to the truck battery, EVERYTHING WORKED! Good chance it's the battery or the main battery leads. Take your battery with you, if your getting a new battery, and have them do a load test just to make sure that it is the battery; before you buy a new one.
September 11th, 2012, 05:18 AM | #28 |
I think Jiggles has this one right. I dealt with similar issues on a buddies 250 that stranded him at work. The dummy lights, tach, and speedo will do weird things when your battery is dead or more likely what I like to called "killed". We were able to get his bike started by push starting and it ran really rough on the commute to his house. I had him replace the battery the following day and that was the fix.
September 11th, 2012, 06:31 AM | #29 |
Yup. Shorted/failed battery.
September 11th, 2012, 06:34 AM | #30 |
Sounds like a battery. Did you check the voltage drop on the battery? It was 12.9 when you checked, was the key on or off?
September 11th, 2012, 08:06 AM | #31 | |
Replaced fuse and diode and all was well until i blew the diode again a couple of weeks later. The one in line with the starter button will get hot and fail open. You can tell its about to go because sometimes you hit the starter and nothing, try again and you're good. Other times you push the button and hold and the starter will turn after 1-2 sec. It did this for a week or so then I was done until I replaced the diode again. This started after about a month of killing the motor by dropping the side stand. I'm still not convinced that this was the cause but the bike was fine for the first few months I owned it, then after a month of doing this, it dies. I have since started using the key instead and it hasn't happened for about 5 weeks. I've checked all of the diagrams and it doesn't seem like it should make any difference but it is the only change I've been able to isolate. I haven't replaced the battery yet but voltage checks fine.
September 11th, 2012, 08:13 AM | #32 | |
Wife was kind enough to go out of town this morning and leave her car, so I get to go down to Cycle Center for a new battery before work.... and whatever else I really shouldn't buy. Stay tuned for updates.... (hopefully happy ones)
September 11th, 2012, 08:14 AM | #33 |
Join Date: Jun 2012 Motorcycle(s): 2010 Ninja 250 Posts: 212
Replacing a fuse and diode is stupid... they'll just blow again.. you gotta find what caused the fuse and diode to blow, fix that then be good, Since the fuse blew, circuit resistance dropped causing current to rise, now you gotta find what caused this drop in resistance, so start looking for shorts... measure voltage in and out of the fuse, switch, load, etc if there is a big difference in voltage in and out then theres your problem
September 11th, 2012, 08:16 AM | #34 | |
September 11th, 2012, 08:19 AM | #35 |
I'm pretty sure he's just speaking of that guys diode problem. Batteries die and sometimes it seems for no good reason. I'll be surprised if it is not the battery.
September 11th, 2012, 09:08 AM | #36 |
Another vote for the battery.
September 11th, 2012, 12:30 PM | #37 |
Just picked up a new battery & filled it in my complex's men's room. Someone made asked about my "chemistry" experiment. It later occurred to me how strange this might look, possibly a little unnerving for some on this 9/11 anniversary. There are coincidently a couple LEO offices in the complex, which could have made for an interesting conversation. Not worried, as my dead bike will back-up my story ;p
Battery is on the B. Tender under my desk, and will be installed at my next break. Voltage was 12.89v immediately after pouring in the electrolytes.
September 11th, 2012, 12:41 PM | #38 |
you're going to need new transflux confabulators in your anticoagulatory relays to regulate the antimater injectors better. you might go as far as to replace the entire field coil and transduction assembly. just make sure when you compress the antimater stream that the plasma is hot enough, otherwise the warp field will destabilize
September 11th, 2012, 12:46 PM | #39 | |
Honda Interceptor VFR800 DLX (2014, 8th gen) Honda CBR500r (2014) - FOR SALE Kawi Ninja 250r (2008) - Restored and passed-down within family, only to be abandoned Last futzed with by headshrink; September 11th, 2012 at 03:00 PM. Reason: spelling.... like always |
[superbikeplanet.com] - Hayden on '15: This Is A Completely New Bike | Ninjette Newsbot | Motorcycling News | 0 | February 6th, 2015 10:20 AM |
[urgent] my bike is dead. Very dead. Now what? | arnoldc6 | Riding Skills | 15 | September 8th, 2012 08:04 AM |
Electrical Issue - Dead Battery? | k24_cm7 | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 17th, 2012 12:25 AM |
[motorcyclistonline] - New Permatex® Liquid Electrical Tape Keeps Electrical Connect | Ninjette Newsbot | Motorcycling News | 0 | February 26th, 2011 01:20 AM |
[crash.net - MotoGP] - Fabrizio: A completely different bike. | Ninjette Newsbot | Motorcycling News | 0 | August 14th, 2009 11:40 AM |
