Old April 30th, 2017, 08:05 PM   #1
Bluberryrain
Bluberryrain's Avatar
Just a friendly reminder
To check your tire's air pressure. I just checked mine, and filled the tires up.
Turns out they were both pretty low!
Bluberryrain is offline   Reply With Quote
Old April 30th, 2017, 08:28 PM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Sage advice.
Old April 30th, 2017, 10:38 PM   #3
MLR
MLR's Avatar
Opps, my front was 20 and the rear was 25.
I've just been using my bike around base and never really noticed, after putting 28 in the front and 32 in the rear there was a noticeable difference.
D'OH
Soooo, I then went for a ride around Brisbane and headed home to Amberley via Mount Glorious, sweeeeet.
It was good to stretch its "short" legs.
MLR is offline   Reply With Quote
Old May 1st, 2017, 02:44 AM   #4
Snake
Snake's Avatar
Great tip! Thanks.
Old May 1st, 2017, 07:03 AM   #5
MrAtom
MOTM - July '15
Does anyone else use a bicycle pump with a built-in gauge to fill up their moto tires? I bought a nice one a while back because I went through two cheap ones for my bicycle, and found that the nice one is really good for moto tires as well.
Old May 1st, 2017, 12:45 PM   #6
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I don't trust built in gauges of any pump I've owned. I have a dedicated gauge for checking tire pressure (moto/car/bicycle).
Riding it like I financed it.
Old May 1st, 2017, 01:04 PM   #7
And while you are at it, check the age of your tires too.
This article says 6 years is the max - http://www.tiresafetygroup.com/tires...-in-six-years/
On a cycle, 5 years is plenty IMO.
How to read the manufacture date on a tire -
Old May 1st, 2017, 05:08 PM   #8
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
We use a bicycle floor pump to fill the motorcycle tires, yep. Fourth bike with tire changes, and we used it to set the beads, too.
I pump it up, and check it with a good tire gauge. The one on the pump itself isn't terribly precise.
And yes, keeping an eye on the tire pressure is really good advice. We've got a safety check list posted in the garage that it's a good idea to check every ride:
Gas level; tire pressure; chain slack; bulbs all working; bolt tightness (marks painted on the engine motor mounts and several other bolts, so I can easily see if anything's loosening); and have a thought about rescue if anything happens. Can you call someone with a trailer or do you have tow insurance? Things like that.
Old May 1st, 2017, 05:23 PM   #9
Bluberryrain
This is absolutely great advice! After breaking down on I15, I had to reconsider that tow insurance
Every Sunday night, I check the chain slack, lube the chain, check to make sure any critical bolts are tight (such as the oil plug, chain tensioners etc) I'll add yours to my list!
I wish I knew how/could mark your post as helpful, but I can't seem to figure out how to do so?
Edit: Looks like you need 1000 posts before you can mark something as helpful. I'm almost 8 percent there!
4 out of 4 members found this post helpful.
Old May 1st, 2017, 06:33 PM   #10
MrAtom
MOTM - July '15
I've seen some bad ones and this one isn't perfect, but it's only 1 PSI off of my dedicated gauge, so I'm pretty dang satisfied.
Old May 2nd, 2017, 09:28 AM   #11
CaliGrrl
CaliGrrl's Avatar
The engine mount bolts back out easily, and it's good to keep an eye on them. I've also got the axle bolts painted with marks, but they've never moved.
It's good that you keep an eye on things! Little changes tell you what else is going on and what might need some attention.
Old May 2nd, 2017, 10:11 AM   #12
I have 3 friends... that bring their $100 pressure gauge to the track with them. By the end of the day we all use my $1.50 pressure gauge from the Dollar Store because we know it's accuracy can be trusted over the years of use. It's +3lbs off, always has been and most likely always will be.
Have your gauge tested every so often, no matter what kind it is... and you will not be playing any guessing games.
Old May 16th, 2017, 11:22 AM   #13
MrAtom
MOTM - July '15
Just tested my bicycle pump vs 12v car tire inflator vs harbor freight gauge. All are within acceptable parameters of eachother
Just a friendly reminder... DON'T TAILGATE!!! tjkamper Ride Reports 19 March 22nd, 2013 11:41 AM
Friendly reminder how not to ride TheMojoRider Videos 9 August 27th, 2011 12:37 PM
Just a friendly reminder about your shifter B2FiNiTY 2008 - 2012 Ninja 250R Tech Talk 14 May 26th, 2009 04:00 PM
Reminder islanderman7 General Motorcycling Discussion 2 May 18th, 2009 10:58 AM
