Old April 5th, 2012, 05:52 PM   #1
anabolicinsider
Motorcycle(s): 1998 Ninja 250
1998 Ninja 250 - Rebuilding Carb?
hello everyone, just got the carb off. exhaust was blowing white smoke out the RIGHT exhaust pipe. upon examining the vacuum diaphragm's i noticed the right diaphragm was very warped, and the left one was perfect with no warping at all.. what is your opinion? and also, if it does have to be replaced,, what is your opinion on stuff on ebay or amazon,, because those are like 30 dollars instead of 100+ for the diaphragm! and does it 100% have to be from a ninja 250 88-07, or is this a pretty universal part from kawasakis? just curious thanks in advance
anabolicinsider is offline   Reply With Quote
Old April 6th, 2012, 07:50 AM   #2
anabolicinsider
bump
Old April 6th, 2012, 07:59 AM   #3
Looks like it not making a good seal on the right side near the edge. Prices for those things suck. It can be cheaper and easier to find a used carb setup. No clue on the ebay/amazon stuff.
Old April 6th, 2012, 08:06 AM   #4
anabolicinsider
Prices do suck bad. 80-125 roughly.
Old April 6th, 2012, 07:50 PM   #5
anabolicinsider
My buddy has a Carb from a 95 Kawasaki 650. Would the Carb or diaphragm fit from that?
Old April 6th, 2012, 09:28 PM   #6
anabolicinsider
I mean 600
Old April 7th, 2012, 07:26 AM   #7
Trash Can Man
Trash Can Man's Avatar
Motorcycle(s): Ninja 250, 87 & 99 Concours, Buell 1125CR
That part probably won't fit, but you can cross-reference the files at Bike Bandit to find out. Have you tried searching for motorcycle salvage yards in your area for the part?
Bumpty,bumpty, bump
Trash Can Man is offline   Reply With Quote
Old April 7th, 2012, 07:28 AM   #8
anabolicinsider
the closest salvage yard is slicks in mason MI,,, and they are crooks when it comes to part costs.. (close to retail new price for scrapped) and my buddy that sold me the bike told me that when he was looking at prices for the diaphragm that people on this board offered to sell him a cleaned carb off a working bike for literally almost the same price as the diaphragm.
Old April 7th, 2012, 07:31 AM   #9
anabolicinsider
!!!! The part number on bikebandit is the same for both the 600 and the 250 !!!!
Old April 7th, 2012, 08:35 AM   #10
anabolicinsider
i spoke too soon,, the REFERENCE number is the same,, not the part number.. still going to take apart buddies carb to see if it looks the same though.
Old April 7th, 2012, 09:16 AM   #11
Skippii
Milkshake Drinker
Skippii's Avatar
White smoke in the exhaust usually means a bad head gasket or piston, not anything to do with a carb.
Posted via Mobile Device
Old April 7th, 2012, 09:22 AM   #12
anabolicinsider
@skipp,,,, carb in general, upon opening it, does need to be cleaned as is sat for quite some time with gas in it. in regard to the asked question, is about the diaphragm, not the white smoke, if in deed that needs to be addressed at a later date then it will be. what is your opinion on the diaphragm as many new ones i see for sale have ripples in it and arent perfect like the one on the opposing carb?
Old April 7th, 2012, 09:25 AM   #13
anabolicinsider
not really too worried about having to do a top end job on the engine. piston being roughly 40-50, head gasket being 15-20ish and ring set being 40ish. quite affordable
Old April 7th, 2012, 12:08 PM   #14
anabolicinsider
<iframe width="420" height="315" src="http://www.youtube.com/embed/J2VvqwuVzkg?rel=0" frameborder="0" allowfullscreen></iframe>
this is the only time its been started while in my possesion. there is a low idle knock if you listen closely enough, 1 cylinder not firing properly. ignition coil wire on the non-firing side is pretty chewed up. will fix that then see if the other side kicks in. first though we're cleaning the carbs so much gunk isnt getting pushed through.
Old April 7th, 2012, 12:08 PM   #15
anabolicinsider
http://www.youtube.com/watch?v=J2VvqwuVzkg
this is the only time its been started while in my possession. there is a low idle knock if you listen closely enough, 1 cylinder not firing properly. ignition coil wire on the non-firing side is pretty chewed up. will fix that then see if the other cylinder kicks in. first though, we're cleaning the carbs so more gunk isn't getting pushed through.
Last futzed with by anabolicinsider; April 7th, 2012 at 12:34 PM. Reason: typos
Old April 8th, 2012, 02:50 PM   #16
anabolicinsider
http://www.youtube.com/watch?v=tyuah...ens0Y8uBFlOoo=
Cleaned the carbs again instead of taking the previous owners word on it. They were quite nasty inside! Started first try now with choke on. And with warmer weather the rest of the day it even started without choke.
Old April 14th, 2012, 03:07 PM   #17
anabolicinsider
Screwed up the carb
Old April 14th, 2012, 03:13 PM   #18
anabolicinsider
The pilot air screw tip was stuck in the hole and I didn't know it while unscrewing it. To back up I should mention I purchased a rebuild kit cause I needed only the gaskets. And it came with everything. So I figured while it was apart...
Old April 14th, 2012, 03:15 PM   #19
anabolicinsider
Anyone else have a carb for sale?
Old April 14th, 2012, 03:17 PM   #20
anabolicinsider
Realistically my budget is 100 plus whatever shipping will be to michigan
Old April 14th, 2012, 03:18 PM   #21
anabolicinsider
Or if someone has for sale only one side of the duel carb setup I am willing to purchase one side if the price is right.
Old April 14th, 2012, 03:25 PM   #22
anabolicinsider
The tip broke off in the hole. Tried using a dentist pick tool to force it back out. Ended up bending the tip making it worse and harder to get out. The more I tried the more I widend the hole... And it's really stuck... So now... I much buy a used carb..
So again I ask..
1988-2007. Anyone have a carb? Budget $100 plus shipping
Old April 14th, 2012, 06:43 PM   #23
http://www.ebay.com/itm/2008-NINJA-E...#ht_1199wt_952
^^ this will need pregen needles, 105 main jets, (and possibly pilot jets?) but a jet kit (or jetsrus.com) will solve that.
http://www.ebay.com/itm/95-96-KAWASA...#ht_1294wt_952
^^ you might get lucky and they might accept $100 + shipping. It's worth messaging the seller.
http://www.ebay.com/itm/2005-NINJA-E...#ht_500wt_1202
http://www.ebay.com/itm/K54-88-07-KA...83e81a&vxp=mtr
^^ worth asking about just the carbs.
http://www.ebay.com/itm/2007-Kawasak...#ht_500wt_1202
Old April 15th, 2012, 06:29 AM   #24
anabolicinsider
thanks everyone, if everything goes right, ive lined up a carb for 100 shipped
Old June 15th, 2012, 12:04 PM   #25
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
Cool it daddy-o
About your original question....that diaphragm should be OK if there are no holes or tears in it and if you can get the lip of it to sit in the channel of the carb body properly.
Whenever I do carb work with the diaphragm to be removed I place the diaphragm (attached to that plastic slide piece) in the freezer. When it's cold the lip just falls in the carb channel where it's supposed to sit. I guess it contracts slightly when cold.
This works for me every time and I've done it many times.
j98sprint
j98sprint is offline   Reply With Quote
From Michigan - 1998 Ninja 250 anabolicinsider New Members 11 April 8th, 2012 07:37 AM
Carb Cleaning/Rebuilding Question.... jboyd12 2008 - 2012 Ninja 250R Tech Talk 13 March 26th, 2012 08:58 PM
1998 Kawasaki Ninja 250 For Sale - Michigan Jax1512 Motorcycle-related 2 April 14th, 2010 12:56 PM
