Go Back   ninjette.org > General > !%@*#$%!)@#&!%@ I crashed!
Old August 17th, 2012, 03:07 PM   #1
nvxdiz
Motorcycle(s): 2009 Ninja 250R C.T. Blue
Dropped my bike...
I dropped my bike going 5-10 mph in a parking lot. Signaled for a turn, and my bike just gave out... It wasn't even that sharp of a turn... All I could think of causing this was that there was some oil where it gave or I'm just a noobie still learning.
Broken turn signal, scratched left faring, and some missing bolts.
Not a scratch on me, but my bike needs a little bit of work.
Do I call my insurance or find a shop?
nvxdiz is offline   Reply With Quote
Old August 17th, 2012, 03:11 PM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Just replace the turn signal and leave the fairing scratched up in case you drop it again. Maybe try and buff out the scratches but it's not worth replacing. As for bolts, bolts are cheap
AFM #676
Supersports are for n00bs
Old August 17th, 2012, 03:13 PM   #3
jhunter
jhunter's Avatar
What bolts are missing?
That doesn't sound worth reporting or taking it to a shop. You can get a new signal off ebay for $15 and install it yourself, it's pretty simple.
You could probably get new bolts too, depending on the kind. You can visit the following site to see what parts you need. You can order them from here too if you want, but it may not be the best price. I just use it for part numbers:
http://www.ronayers.com/fiche/
Fairings...eh...the main side ones are like $250 per side on average when I search for them on ebay, but if all it is is scratched, you probably don't need to replace it honestly.
Just imagine that there is something interesting here.
jhunter is offline   Reply With Quote
Old August 17th, 2012, 03:15 PM   #4
xSean13
xSean13's Avatar
I wouldn't make an insurance claim on something that isn't a good amount of money.
Determine which bolts are missing and order some more online (ronayers.com). I'd just leave the fairings...no need to pay $250 for a new one to just drop it and scratch it again. Replace the turn signal or get some flushmounts!?
Old August 17th, 2012, 03:18 PM   #5
nvxdiz
Alright, I might need a new fairing though... Its damaged to a point where the socket that holds the turn signal fell off along with the turn signal itself.
Old August 17th, 2012, 03:20 PM   #6
jhunter
jhunter's Avatar
Post a picture if you don't mind.
Old August 17th, 2012, 03:21 PM   #7
vman1313
vman1313's Avatar
Motorcycle(s): '14 Honda NC700X; '14 Honda CRF250L; '07 Lifan 200
@nvxdiz - sorry bro!!!
www.northgariders.com
NuBe4Life!!!
vman1313 is offline   Reply With Quote
Old August 17th, 2012, 03:25 PM   #8
nvxdiz
Sucks...
Old August 17th, 2012, 03:27 PM   #9
nvxdiz
I actually meant to say the turn signal broke off... Otherwise its working perfectly fine.
Old August 17th, 2012, 03:28 PM   #10
Chalk another one up to those damn turn signals.
Old August 17th, 2012, 03:39 PM   #11
jhunter
jhunter's Avatar
That's a big scratch.lol
Hmm...you might be able to get an adhesive and "fix" it, but it looks like there will be some gaping holes left (unless you have those pieces too).
I might pony up the $250 and order the fairing at that point, but it's obviously your call.
If you want to, go to eBay and search "ninja 250 fairing" (put a year in there too, like 08 or whatever) and browse around. You should be able to find the one you need.
Also, don't worry too much about it. It does suck, but it happens to a lot of people. I dropped mine on my second ride and busted a turn signal right off.heh
Old August 17th, 2012, 03:44 PM   #12
[rant]
There is just something not right with those turn signal stalks... I mean common, you walk by your bike and just barely hit them with you knee and they break. But... if you go down there is a hell of a good chance it will just punch a hole right in the fairing.
[/rant]
If you want to fix that, some plastic weld for the cracks, fiberglass for the hole and a blue sharpie should take care of the paint. Bummer
Old August 17th, 2012, 03:49 PM   #13
nvxdiz
Thanks for the advice guys. Man I suck at descriptions... for some reason I'm thinking scratch = crack..
I'm probably going to fork over the cash for a new fairing and probably invest in some flush mounts soon.
I found the left fairing on Ronayer, but can someone please verify if I'm ordering the right part. Part no. is 55028-0271-620. That should also be painted correct?
Old August 17th, 2012, 06:30 PM   #14
Z300
Ninja noobie
Z300's Avatar
Motorcycle(s): ninja 250r
would a 2008 fairing fit a 2012 ninja?
and nvxdiz just check again if they have it in blue cause I only saw green and red
Z300 is offline   Reply With Quote
Old August 17th, 2012, 06:32 PM   #15
Old Lemon
Lays er down
Old Lemon's Avatar
Motorcycle(s): 2008 Lime green Ninja 250R
sometimes, YOU JUST GOTTA LAY ER DOWN
(its my new meme. someone make a troll face picture for me)
Old Lemon is offline   Reply With Quote
Old August 17th, 2012, 06:33 PM   #16
seanshawnS
Motorcycle(s): Ninja250r(2012PR)
I dropped mine about a week ago. Wasn't even moving..Thankfully my clutch boot doubled as a frame slider.
Turn around at half a tank
seanshawnS is offline   Reply With Quote
Old August 17th, 2012, 07:44 PM   #17
ryan.chin
Motorcycle(s): 2007 R6
I UPGRADED to a YZF-R6 Mods:
Shermoto LF7 Levers / Proton Flushmounts / Puig Smoked DB / Woodcraft Sliders / Tech Spec C3 Tank Grips / Rizoma Grips / Jardine
ryan.chin is offline   Reply With Quote
Old August 18th, 2012, 09:36 AM   #18
fatestkid
fatestkid's Avatar
Work smart, play stupid.
fatestkid is offline   Reply With Quote
Old August 18th, 2012, 09:39 AM   #19
Originally Posted by ryan.chin View Post
I am so stealing that....
Old August 18th, 2012, 09:42 AM   #20
I believe so but don't hold me to it.
Old August 18th, 2012, 09:56 AM   #21
RiderOnTheStorm
Motorcycle(s): Blue 08 250 - Blue Magic
I'm sorry to hear about the bike, but glad you're alright.
I use partshark.com. I can't get to it on my phone, but they have the schematics with part numbers so you can verify.
And I have a mix of 08 and 09 fairngs on my bike and you wouldn't know. As long as the color matches, they should all be the same.
RiderOnTheStorm is offline   Reply With Quote
Old August 18th, 2012, 10:22 AM   #22
Old Lemon
Lays er down
Old Lemon's Avatar
Originally Posted by fatestkid View Post
yes! and the other one is good too, because that is exactly what happened when i dropped my bike the first time
Old August 18th, 2012, 10:32 AM   #23
xSean13
xSean13's Avatar
They'll fit, but the colors won't match..unless your bike is green or black. The blues and reds (maybe even the green, idk) are different each year.
Old August 22nd, 2012, 10:54 AM   #24
nvxdiz
Well I called Ronayers and ordered a new fairing along with some some other bolts and stuff I found missing. Ill put up a picture as soon as I replace the fairing.
Dropped Bike Raider24 !%@*#$%!)@#&!%@ I crashed! 7 June 19th, 2012 07:24 PM
Just dropped my bike hybridkid !%@*#$%!)@#&!%@ I crashed! 11 February 27th, 2012 05:23 PM
Dropped my bike... Cedilla !%@*#$%!)@#&!%@ I crashed! 21 July 3rd, 2010 05:05 AM
I dropped my bike! motorcycle_munge !%@*#$%!)@#&!%@ I crashed! 16 April 29th, 2009 06:21 AM
Dropped Bike Need Help! NewNinja !%@*#$%!)@#&!%@ I crashed! 7 March 16th, 2009 07:50 AM
