October 13th, 2013, 01:12 PM | #1 |
Join Date: Sep 2013 Motorcycle(s): 2008 Ninja 250R Posts: 106
Mixture screw turns.
This is probably just one of those situations where I'm just over-thinking the technicality of what a "turn" consists of. For the life of me I can't find any reference on google or in any of my mechanical books.
So to help convey what I assume a turn is, here's a quick graphic. http://imgur.com/dT5jJ68 Right? |
October 13th, 2013, 01:43 PM | #2 |
Yes sir, one complete revolution.
October 13th, 2013, 01:45 PM | #3 |
October 13th, 2013, 01:46 PM | #4 |
October 13th, 2013, 02:00 PM | #5 |
I like to put a clear mark on the screwdriver handle in relation to the position of the blade to give you some reference when setting the screws.
October 13th, 2013, 02:26 PM | #6 |
October 13th, 2013, 06:45 PM | #7 | |
Start by turning the screw all the way in and seating it lightly, then note where the mark on the screwdriver is - that's your reference "0" point. |
October 13th, 2013, 07:26 PM | #8 |
Gotcha. That makes more sense if the carbs are still installed.
Stock mixture screw settings | ferret09 | 2008 - 2012 Ninja 250R Tech Talk | 6 | September 12th, 2023 11:00 PM |
what is the best idle screw mixture | vmax | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 1st, 2017 10:45 AM |
Idle Mixture Screw Problem | gogoKawi | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 23rd, 2013 07:07 PM |
Adjusting the Idle Mixture Screw | conrya5 | 2008 - 2012 Ninja 250R Tech Talk | 22 | March 18th, 2013 05:03 AM |
Idle Mixture adjustment screw Q | indr | 2008 - 2012 Ninja 250R Tech Talk | 1 | December 2nd, 2010 09:36 PM |
