June 17th, 2014, 09:17 AM | #1 |
flexy frame?
so in high speed banked corners it feels like the frame is slowly twisting back and forth on my oem ex250j frame. i'm wondering if there are any technique or setup things i can change to lessen the frame flex without having to actually change the frame? would a shorter wheel base lessen the torque going into the frame? maybe the bike is sitting too high? or i am too far forward? maybe a stiffer front engine cradle mount thinggy?
June 17th, 2014, 09:30 AM | #2 | |
When you straightened your frame, you could see how much force was needed for twisting it back, and that was without the bracing effect of the installed engine. The forks may be the weakest link in your case. Here is a good link about what happens in the forks. http://www.tonyfoale.com/Articles/Steer/STEER.htm This is the general rule of thumb for tubes in structures. - Excellent for resisting twisting or traction forces. - Not so good for resisting compression forces, especially if they are slender. - Bad for resisting bending forces. Certain degree of yield or deformation always precedes any fracture, more for low carbon steel and vice verse.
June 17th, 2014, 09:32 AM | #3 |
You didn't know the frame is part of the suspension on 250s?
June 17th, 2014, 09:46 AM | #4 |
Seriously though... I think you're making (minor/unconscious) steering corrections mid-corner that starts the whole mess.
The frames do flex yes... but I have never felt it "twist". I would describe it more as a "humping" or "rocking back and forth" action and more toward the front near the narrow part of the frame head. I get the flex bad at Mid-Ohio but not near as much at Putnam (where I am faster and more confident).
Frame sliders | caineroad | 2008 - 2012 Ninja 250R Farkles | 2 | October 26th, 2013 01:36 PM |
Shogun frame slider frame bolt question | crankinaway | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 22nd, 2010 06:46 PM |
new generation of frame slider + frame reinforcement | samuel913 | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 12th, 2010 10:00 PM |
Do I need a new frame? | n4v1n | 2008 - 2012 Ninja 250R Tech Talk | 9 | August 18th, 2009 06:39 AM |
Frame Sliders | zenxfour | 2008 - 2012 Ninja 250R Farkles | 2 | July 27th, 2009 03:20 PM |
