Old December 25th, 2012, 01:04 PM   #1
skikman
Motorcycle(s): 1995 ninja250
bar ends
cant get my bar ends off. before i wreck the screw head thought i would ask.are they left hand threaded
skikman is offline   Reply With Quote
Old December 25th, 2012, 02:07 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
I hear a lot of people take a torch to them and cook the lock tight to loosen it up. I didn't plan on putting any bar ends back on so I just drilled off the end of the bolt, slid the barend over and use vise grips on the bare threads to remove the remainder of the bolt.
Old December 25th, 2012, 02:10 PM   #3
Joshorilla
Bass Master General
Joshorilla's Avatar
http://bit.ly/Vvtyj1
Old December 26th, 2012, 01:10 PM   #4
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
The screws are held in with red locktite. Use a propane torch and play the flame on the screw head for a minute, move it around, it should not be getting hot enough to damage the paint or make anything smoke. Once the screw threads get hot enough the locktite softens and the screw comes out.
Old January 3rd, 2013, 05:43 AM   #5
n4mwd
n4mwd's Avatar
I got mine off without using a torch. However, its very critical to get a Phillips bit that fits perfectly. I used this. It worked perfectly without marring or burning. The bit that comes with the kit is a perfect fit.
My Ninja Blog
Old January 3rd, 2013, 05:47 AM   #6
Ah yes.... impact driver, one of my favorite tools. Your normally pissed off when you need it and 9 times out of 10, it does the job and the world is right again. lol
csmith12 is online now   Reply With Quote
Old January 3rd, 2013, 07:26 AM   #7
lgk
i torched mine even though i had an impact driver.
worked great.
Old January 3rd, 2013, 03:26 PM   #8
n4mwd
n4mwd's Avatar
If you use it before you get pissed off, then the bit fits better.
My Ninja Blog
Old January 7th, 2013, 06:15 AM   #9
tdog7812
tdog7812's Avatar
Motorcycle(s): 2012 Kawasaki Ninja 250r
use a torch, if you are trying to take them off to put on new grips just cut the old ones off, and use some hairspray on inside of new ones and slide them over. hairspray will keep them stuck once it dries.
tdog7812 is offline   Reply With Quote
bar ends.... gkarats 2008 - 2012 Ninja 250R Tech Talk 9 October 30th, 2013 05:26 AM
Bar Ends skilletmo 2008 - 2012 Ninja 250R Tech Talk 8 March 8th, 2013 11:17 PM
!@#$!ing bar ends! Torch, impact screwdriver, breaker bar, etc ALL failed. :( CZroe 2008 - 2012 Ninja 250R Tech Talk 64 September 13th, 2012 11:50 AM
Bar ends james250ninja 2008 - 2012 Ninja 250R Tech Talk 8 October 22nd, 2011 08:54 PM
bar ends james250ninja 1986 - 2007 Ninja 250R Tech Talk 13 April 22nd, 2010 04:06 AM
