#1 |
Ninja noobie
Join Date: Aug 2012 Motorcycle(s): ninja 250r Posts: 498
Question about 1st gear ninja 250
Is it bad to rev to much on the first gear like up to 6000-7000rpm,
or should i just change from 1st to 2nd asap? what rpm should i change from 1st to 2nd because in traffic i find my self going really slow ![]() ![]() ![]() Last futzed with by Z300; September 7th, 2012 at 07:19 AM. |
#2 |
Ambrosia.
Join Date: Aug 2011 Motorcycle(s): 1974 Honda CB550K0 W.I.P. Posts: A lot.
In traffic I stayed in 2nd unless I came to a complete stop (sometimes. Just needs a bit more gas to take off in 2nd). If I was going to be going higher than 2nd, I'd usually run it up to about 15mph (probably 10k?) before upshifting.
Life's better on the Mountain. |
#3 |
Ninja noobie
so only use the 1st gear to get moving and shift to 2nd asap?
#4 |
MoVal's only ninjette :(
Join Date: Jul 2012 Motorcycle(s): 2012 Ninja 250r SE Black with a dash of yellow Posts: 120
I haven't been riding that long either, but when I learned to drive stick, that was the general rule my dad taught me. As long as you're moving use second. Just use a little more clutch and throttle.
As far as shifting out of first, I think it's a matter of how you're riding. Personally, If I'm planning on really opening it up, I won't shift until 9or 10k. But if I'm just cruising I might shift to second at around 6 or 7k. I think there is something about the shift schedule in the manual too. |
#5 |
Ninja noobie
YEAH IM A NOOB
when moving off lights i rev to much Last futzed with by Z300; September 7th, 2012 at 07:18 AM. |
#6 |
Welcome to the site, Yas !!
You can extend the first gear as long as you want up to 10,000 rpm. With more practice, you will find the sweet spot to change each gear, which also changes with the rate of acceleration that you want for any specific moment. If you need explosive acceleration, you will need keeping rpm's high. If you are giving a girl a ride, you can keep the rpm's low. Check this thread for examples of explosive acceleration: http://www.ninjette.org/forums/showthread.php?t=99216
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#7 |
/moved to riding skills
#8 |
Got a laugh about "explosive accereration". I've never experienced that on a 250. Back to the original post, the stock new gen in my opinion has an almost useless first gear. For normal driving I short shift out of it at around 6-7,000 RPM. 2nd is better but I usually short shift it too. If I were in a drag race I'd probaly come close to red line in all gears but it almost feels silly in
1rst and 2nd.. Once in third the bike comes alive and if you want to take it to red line it "feels" like that's what's needed for max performance. I love the new gen 250 but don't like stock gearing. I might not change it tho as I have other bikes that truely have "explosive acceleration". Just a note. Videos showing acceleration test showed driveways, mailboxes and traffic. not a great place to do acceleration test. Best wishes, Bill |
#9 |
I laughed a little at the "explosive acceleration" as well
![]() ![]() ![]() seriously though, take 1st as high as you wish. But for normal city traffic at a sane pace, 6-7k is a fine pace to shift. Heading up to 12k in 1st is just asking for some attention from the 5-0. If I'm slowing without stopping, I use 2nd and slip the clutch a little more to keep things smooth. |
#10 |
1st gear is pretty rough and jumpy on the 250. I get into 2nd ASAP. 1st is only good if you are going extremely slow. Like walking pace in a parking lot.
#11 |
No one has mentioned what I observe. Some have indirectly.
For me, shift RPM is directly proportional to throttle position. At WOT, i red line each gear until I reach my target speed. At granny commuting throttle position (about 25%), I shift at 8k (maybe earlier in 1st) and try and keep the rpms between 5 and 8. For any in betweens, the shift rpm increases proportionally. High RPMS sound strained to me if the throttle position isn't right, I wouldn't cruise in 1st or 2nd gear over 7k rpms. In fact, the only time I maintain high rpms is on the freeway because 6th gear is geared that way. |
#12 |
Join Date: Jul 2011 Motorcycle(s): 2008 Ninja 250r Posts: 784
I always shift at redline
#13 |
Also, general note:
This site is specifically for the 250. There is no need to put "ninja 250" randomly in the title. The whole forum is about 250's! |
#14 |
Ninja noobie
after about a month of riding iv started to get way better already done like 1k this month
![]() just got to rev it hard and your good to go |
#15 | |
#16 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
you can hit the rev limiter in any gear, it wont hurt the bike
#17 |
Ninja noobie
I didn't rev to much because of the break in period
Last futzed with by Z300; September 7th, 2012 at 07:17 AM. |
#18 |
you post like you're drunk.
#19 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
#20 |
#21 |
Ninja noobie
#22 |
"scandal!"
personally I shift from 1st -> 2nd anywhere between 4k and 12k rpms haha.
Mostly it matters if the bike is cold or not. When its warm I probably shift up after 6-7k and if its cold between 4-7k. Not sure why or how I came about picking up this habit. |
#23 |
not a drag racer
Join Date: Nov 2012 Motorcycle(s): 04 ninja 250(faster than jiggles) Posts: 1
fwiw... i had a track day with ridesmart a little over a year ago and the lead instructor, randy, raced ninja 250's. and he taught me this neat trick that's essentially a quick shifter, but it also may not be entirely "good" for your engine and its a little excessive for street riding. But if you keep your foot sort of weighting the shift lever LIGHTLY (dont stand on it) then just keep reving up and when it hits the rev limiter itll cut the gas a little and be like a clutchless upshift and voila
If the Ninja 250 doesn't have enough power for you, then you don't know how to ride it |
#24 |
Welcome Sam!
Many of us clutchless upshift but then again, many of us race too. Once your pretty good at it, it transfers over to street riding for some. The answer of when to shift is one of 3 possibilities. 1. You hit redline 2. You start to attract the attention of the po po 3. Your personal comfort or preference
#25 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
I'm still Leary of this clutch less shifting... One day folks... One day
Sometimes I shift early, sometimes late. I like this non explosive 250/300 buisness this had to be before peanut almost looped his bike on the starting line, and what about racerX ... Maybe your right, I haven't seen anyone's bike explode while accelerating yet
#26 |
I tended to rev 1st gear out to redline, if not pinging off rev limiter.
Probably not great for the bike, but at the time, was only way I could get front off the ground ![]() |
#27 |
#28 |
Track Clown
MOTM - Sep '15
Clutchless up shifting is a refined skill that takes time to learn, sadly my upshifts usually suck do to angle of shifter and size of my feet + lack of flexibility.
#29 |
Join Date: May 2013 Motorcycle(s): 2005 Ninja 250 Posts: 151
I still get a bit of a lurch as well!
#30 |
^^ Work on the timing of your throttle chop and your shifter bump. It should feel like a smooth continuation of power from one gear to the next. When you do it right, it feels like the only thing that changes is the sound of the engine, no jerk.
#31 |
King Hamfist
Join Date: Oct 2012 Motorcycle(s): 2007 Crf 150R, 2011 Hypermotard 796 Posts: 940
Today I was clutch less shifting up and down. Just remember when the throttled gets closed you can grab a gear. And yes if you just bang down and blip the throttle it will shift down smoothly. That's a trick I learned doing dirt track.
#32 |
Thanks for the help y'all... I'm sure my thoughts will unpetrfy one of these days and I will try it... I still don't even do it in the dodge, although I have once or twice by accident
#33 |
So, where's the reverse?
It's smoother doing clutch less once you get passed second gear. The throttle feels like an on/off switch if you're doing it right.
It's all in the wrist ![]()
Squidbusters. I ain't afraid a no squid. ![]() ![]() |
#34 | |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Lee Parks recommends clutchless. I use it often. When done properly, it's better for your bike and saves you some clutch life! Improperly though, you run the risk of hurting your tranny over time.
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
#35 | |
#36 |
"scandal!"
I like the first gear now. I used to shift at around 5-7k rpm due to some warmup/fuel-economy reasons. But since I've got a 650 going back to the 250 I like to revv it out to 10k+ rpms before shifting because its fun. I feel as long as the engine is nicely warmed up take it anywhere in the rpm range as you like.
#37 | |
Private Joker
MOTM - Mar '14
on topic, Usually I just rev it out in 1st gear and shift up near redline unless I'm stuck behind a car or the popo are nearby. I'm usually only in 1st if I'm going down a gravel road/driveway or at a stop so revving it high isn't a problem to me if I'm taking off, the acceleration is fun and you can pin it without worry of flipping it or pulling a wheelie unless your shifting isn't up to par (like mine xD) |
#38 |
King Hamfist
I've never really thought about it. On the dirt bike you get off the throttle and just bang down. You dump the clutch at the start and really don't touch it unless your backing it in or fanning it exiting a corner.
If I don't want the rear end to step out I think I'm just off the throttle and when I bang down I blip the throttle to rev match. That's what works on the ninjette. You can actually help it be completely seamless. Stay on the throttle. Bang down/let off and blip and that's it |
#39 |
Ninja chick
It's not like you're gonna send your tranny to hell with a mishap or two. You have to be willing to practice it to ever get it right.
#40 |
@ally99 lemme watch a video and hit the street again... I will let ya know how it goes... 60%?
Racing my 1st Ninja 250 | HotRedTurbo | New Members | 15 | August 23rd, 2012 07:48 PM |
Intro + Shifting from 1st question | tyronne1126 | Riding Skills | 27 | October 3rd, 2009 11:08 AM |
Finding 1st gear? | Focus Mike | 2008 - 2012 Ninja 250R Tech Talk | 38 | August 7th, 2009 01:11 PM |
1st gear locking | mista350z | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 5th, 2009 08:24 AM |
I did my 1st oil change question! | Duvivr6 | 2008 - 2012 Ninja 250R Tech Talk | 19 | July 7th, 2009 08:19 AM |
