December 10th, 2013, 10:50 PM | #1 |
Join Date: Nov 2013 Motorcycle(s): 02 ex250 and 12 m796 Posts: 7
help with acewell 2853 gauge install
New guy here, lurked for a long time and finally signed up. Working on kind of a street tracker-ish 01 250 project. About to attempt wiring up an acewell all in one gauge and am wondering if anyone has done this before and can walk me through it. (Wiring and reading diagrams are not my sting suit)
Thanks in advance gitter |
December 12th, 2013, 06:34 AM | #2 |
Welcome Joel!
No experience with that gauge myself but have you already attempted to install it? Run into any snags?
December 12th, 2013, 05:27 PM | #3 |
Haven't started the install yet. I wanted to map everything out first.
December 13th, 2013, 12:07 PM | #4 |
started wiring the gauge up last night. Issues I'm running into so far:
Gauge flickers when rpms are low. tack jumps around Also on a side note, can I just use the stock wire for the tack instead of the one that came with the gauge? And is the black wire in the stock wiring harness (going to the tach) the ground? or the supply wire for the tach? |
December 13th, 2013, 08:15 PM | #5 |
just to update, you can use the stock tach wire, and when you ground out the tach, ground it to the negative terminal on the battery.
DIY: koso gauge install | dyeforever | 2008 - 2012 Ninja 250R Tech Talk | 207 | March 30th, 2017 03:50 PM |
Acewell 2853 installed w/ pics | gitter85 | 1986 - 2007 Ninja 250R Farkles | 8 | April 6th, 2015 10:32 AM |
2012 Fuel Gauge Install on an 07 Ninja | burnrich | 1986 - 2007 Ninja 250R Tech Talk | 23 | September 15th, 2014 03:42 AM |
Koso gauge install question | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 17th, 2012 01:54 PM |
For the next person to install a Koso gauge cluster... | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 26th, 2010 06:25 AM |
