Old May 10th, 2015, 02:54 PM   #1
Roark
Roark's Avatar
Motorcycle(s): 2007 Ninjette
Why does this Ninjette turn so weirdly?
A friend of mine has an '02 Ninjette with about 14,000 miles. I rode it recently and quickly noticed a few differences from my '07 Ninjette:
First, the whole steering assembly just feels heavier.
Second, when turning, at any speed, the bars seem to grab and tip past a certain angle of steering/lean. The steering would be heavy, and then it would randomly grab and make the whole thing lighter, so that I'd have to counter-counter steer to keep from slamming the thing into the ground!
Now, my initial thought was that it needs tires. BT45s, decent tread, adequately aired, with no noticeable cupping. Then I checked through the steering assembly, and it seems everything is tightened with no obvious blockages.
However, I don't know how old those tires are, even though they're in decent shape.. Could old tires in general cause this? Maybe it sat for a while, developed some hard spots or something?
I've also read that the forks could be bent, the steering bearings could be overtightened, and a few other potential causes, but it seemed that all of those caused much greater symptoms!
Any ideas?
*Edit*: what makes it worse is that this is my friend's first bike, so he doesn't notice the issue.. (or maybe he's just not that observant! )
"That's what" -she
Roark is offline   Reply With Quote
0 out of 1 members found this post helpful.
Old May 10th, 2015, 02:58 PM   #2
Originally Posted by Roark View Post
.......... Any ideas?
These are the main probably causes:
http://faq.ninja250.org/wiki/Steerin...ng_replacement
http://faq.ninja250.org/wiki/Servicing_the_swingarm
http://faq.ninja250.org/wiki/Uni_Tra...ge_Lubrication
http://faq.ninja250.org/wiki/How_do_...he_fork_oil%3F
He should also check the three bolts that hold the engine.
If those are loose, the whole frame wobbles.
Old May 10th, 2015, 03:21 PM   #3
Ignorance is bliss. I have seem some riders ride the balls off some pretty messed up equipment. why they don't complain but they make it work.
Check for shock stiction/issues, front and rear as it can change the bikes handling drastically and quickly like you describe.
Have another look and ensure it's not a safety issue for your friend. If so, tell him so he don't get hurt. Otherwise... let it go.
Old May 10th, 2015, 04:25 PM   #4
greg737
Motorcycle(s): -
Maybe the forks have been messed with. If they're mounted too high or too low in the triple clamp it will change the steering angle.
The "slow, slow, then suddenly fast" steering tendency you mention sounds like forks mounted too low in the triple clamp.
Old May 10th, 2015, 04:35 PM   #5
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
Sounds like you need to work on your riding skill's more.
Old May 10th, 2015, 05:34 PM   #6
Roark
Roark's Avatar
not sure if intentionally or unintentionally unhelpful
"That's what" -she
1 out of 2 members found this post helpful.
Old May 10th, 2015, 05:38 PM   #7
Roark
Roark's Avatar
Thank you for the links, Motofool.. I'll be sure to relay the information. Hopefully I can diagnose the issue!
"That's what" -she
Old May 10th, 2015, 05:42 PM   #8
Roark
Roark's Avatar
I don't think it's the shocks, only because the issue is consistent at every speed on any type of road (gravel, asphalt, dirt) and incline. However, I'll check anyways! Hopefully it'll resolve the issue.
And you're right.. I may just have to let it go. It worries me that he didn't notice the difference, considering he's eventually gonna move up to a 600cc supersport, but I may just have to let it go.. Can't convince someone they're feeling something that they don't know they're feeling!
"That's what" -she
Old May 10th, 2015, 05:43 PM   #9
Roark
Roark's Avatar
That sounds perfect!! And seems to be easy to check. Thank you!!
"That's what" -she
Old May 10th, 2015, 05:51 PM   #10
MrAtom
MOTM - July '15
It's fishdip. What do you think? :-)
Old May 10th, 2015, 06:04 PM   #11
You are welcome
Last futzed with by Motofool; May 11th, 2015 at 09:00 AM.
Old May 10th, 2015, 07:49 PM   #12
verboten1
verboten1's Avatar
MOTM - June '15
My wife's bike sucks. I hate riding it now. Same issue, it just feels weird, and everything seems fine.
She likes it, has no problems, so I'm fine with it as well!
Ride more, worry less.
Old May 10th, 2015, 08:09 PM   #13
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Good answer!
Sometimes different feels, well, different.
Old May 10th, 2015, 09:15 PM   #14
fishdip
fishdip's Avatar
You need to work on your riding skills at a slower speed.
0 out of 2 members found this post helpful.
Old May 10th, 2015, 09:41 PM   #15
Roark
Roark's Avatar
maybe you misspelled writing.. because my penmanship is pretty horrible
"That's what" -she
Old May 10th, 2015, 09:48 PM   #16
fishdip
fishdip's Avatar
Ask your self this "would the doctor have a hard time riding it" If no then work on your skills more.
Old May 10th, 2015, 10:39 PM   #17
MrAtom
MOTM - July '15
Everyone should always be working on their skills.
Old May 10th, 2015, 11:16 PM   #18
MrAtom
MOTM - July '15
Sorry @fishdip. Didn't mean to hurt your feelings :-(
Old May 11th, 2015, 05:10 AM   #19
verboten1
verboten1's Avatar
MOTM - June '15
My feelings are so hurt now.
Old May 11th, 2015, 09:02 AM   #20
Red face
You are welcome
I understand that you find the other 7 posts of mine fishy and unhelpful, @fishdip, ...... but what can be wrong with my previous "You are welcome"?
Mine too !!!
Old May 11th, 2015, 01:02 PM   #21
Finesse
ran when parked
Finesse's Avatar
Motorcycle(s): Freeride 250R, KLX250SF, mopeds
MOTM - Sep '17, Dec '14
didnt read the other replies...
steering stem bearings, wheel bearings, tires, clutch or throttle cables catching in the steering stem/triple tree.....
Instagram: @katie.baden
Finesse is offline   Reply With Quote
Old May 11th, 2015, 01:06 PM   #22
"A"
vampire
Motorcycle(s): 2 many 2 list
Have you checked the tire pressure?
"A" is offline   Reply With Quote
Old May 11th, 2015, 11:21 PM   #23
Roark
Roark's Avatar
I took his word that they've been adequately aired. He ordered new tires yesterday. Whenever he gets them mounted, maybe the problem will be solved!
"That's what" -she
Old May 11th, 2015, 11:21 PM   #24
Roark
Roark's Avatar
Steering stem bearings, wheel bearings, and bent/misaligned fork are the main suspects now. Thank you!
"That's what" -she
Old May 11th, 2015, 11:22 PM   #25
Roark
Roark's Avatar
@fishdip.. just you wait until I'm at 1000.. u git no respct bro
"That's what" -she
Old May 12th, 2015, 12:58 AM   #26
MrAtom
MOTM - July '15
Is that why you're replying to everyone in different posts instead of just multiquoting?
Old May 12th, 2015, 09:25 AM   #27
snapshot
Fogwalker
snapshot's Avatar
Motorcycle(s): '09 Ninja 250 "Matilda"
I'd check the air pressure in the front tire.
Test riding a few machines, I've noticed that they tend to tip in hard at low speeds when the front tire air pressure is low.
Ride on,
J~
Take care of new riders, for we were them, and they will be us. Y. Hong 2004
snapshot is offline   Reply With Quote
Old May 12th, 2015, 09:46 AM   #28
xorbe
xorbe's Avatar
Steering stem bearings are a popular upgrade at the N300 forum for steering feel.
Old May 14th, 2015, 10:42 AM   #29
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
As Finesse posted, check for anything binding, it sounds almost like a cable is catching somewhere and then the steering tension eases up when the cable or whatever rides over what it's being caught on.
I had a bike with rusted out steering head bearings, and the symptoms were very similar. I would check those steering head bearings ASAP. My bike eventually got so bad as it would lock up mid turn and you'd have to break the bars free to continue the turn (makes you realize how much you change your steering inputs through a turn when all of a sudden you can't) and scary as hell. Also mondo dangerous... So, make sure your buddy gets his bike checked out - removing the triple trees isn't that hard if you have stands/a way to support the bike...
Old May 17th, 2015, 03:12 PM   #30
Roark
Roark's Avatar
@spooph, thank you, sir.
I'll be seeing him tonight.. adding it to the list
"That's what" -she
Old May 17th, 2015, 03:58 PM   #31
Jono
Jono's Avatar
How is the front suspension? Are the forks lowered? Maybe Raised?
My guess is that the steering stem bolt is too tight. Or the ring nut below the top triple is too tight.
[crash.net - MotoGP] - Crutchlow 'fell at turn one, nearly landed at turn two' Ninjette Newsbot Motorcycling News 0 November 12th, 2014 11:40 AM
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
Electrical Issue - Turn signals turn to emergency blinkers. tgoff 1986 - 2007 Ninja 250R Farkles 6 July 6th, 2012 09:07 AM
My turn... poor ninjette Graugaard !%@*#$%!)@#&!%@ I crashed! 18 May 13th, 2012 04:44 PM
I need help replacing my turn signal on my ninjette! venmichaels 2008 - 2012 Ninja 250R Tech Talk 8 August 12th, 2011 10:46 PM
