November 17th, 2012, 06:42 PM | #1 |
Love my kittehs!
Join Date: Apr 2012 Motorcycle(s): 2011 Ninja 250R SE Posts: 266
Other stock mufflers work on 250?
I have seen a lot of member pictures of their bikes, with, what looks like stock mufflers from other bikes, one even looked like a 650 muffler.
Question is, is there a other stock muffler that works with the 250R from another Kawasaki or other manufacturer and do you need to shim? I was just thinking that I wanted to change the look of my bike, but not invest a ton of money in a custom slip on. I like the looks of the new 300 muffler, and the 2012 650 muffler, but could it be done? |
November 17th, 2012, 06:49 PM | #2 | |
I told you bro
Join Date: Jun 2012 Motorcycle(s): 1996 Ninja 250r Posts: 680
November 17th, 2012, 07:00 PM | #3 | |
Love my kittehs!
So, as to the original question, could say a 650 muffler be put on a 250? What would need to be done,to limit the amount of exhaust pressure? |
November 19th, 2012, 09:03 PM | #4 |
Join Date: Nov 2012 Motorcycle(s): Ninja 300, KTM EXC610SMR Posts: 913
The 2013 300 muffler bolts right on and looks a ton better. Just put mine on my son's 2012 250.
November 19th, 2012, 09:24 PM | #5 | |
Nerd
Join Date: Mar 2012 Motorcycle(s): Ducati Hyperstrada Posts: 672
How was performance? and sound? Any degradation in performance by doing a straight swap?
It doesn't LOOK that steep. But you can go first... |
November 20th, 2012, 12:14 AM | #6 |
No difference we could hear or feel, but it looks alot better.
April 2nd, 2013, 11:21 AM | #7 |
Join Date: Jan 2013 Motorcycle(s): 2012 FZ6R, 2006 Ninja 250, 1977 Suzuki GS550 Posts: 186
Got a pair of GSXR 1000 mufflers for our white pregen. I gotta sell the old 1977 GS500 so I can pay someone with welding skills to make it work though....
+ these
2012 Yamaha FZ6R (mine) 2004 Kawasaki Ninja 250 (wife) 2003 Kawasaki Ninja 250 Street Fighter project |
April 2nd, 2013, 03:47 PM | #8 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
Too much work IMHO just for another "stock" muffler
In regards to straight pipe , I ran the bike without the muffler on and it sounded like crap.
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
April 2nd, 2013, 04:07 PM | #9 |
Straight pipe is a no-no. It just sounds shallow and metallic. No rumbling, just ninja 250 powered didgeridoo. More like didgeridon't
April 2nd, 2013, 04:37 PM | #10 |
Board Member
Straight pipe will hurt your power even when jetted well. And its just obnoxious.
August 26th, 2013, 03:36 PM | #11 |
Certified looney toon
MOTM Jul '13, Jul '14
Necrobump
If swapping from a stock 2012 pipe to the stock 300 pipe, does anything need to be done other than just bolt it on? I'm an engine idiot, so I don't know what terms to use to ask the question.
August 27th, 2013, 05:19 AM | #12 |
Join Date: May 2013 Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s Posts: 628
The 300 canister fits right on but i couldn't line up my brackets from canister to pegs. I'm waiting on some 300 passenger pegs now. that should fix my problem. it doea look MUCH better than stock.
August 27th, 2013, 05:26 AM | #13 |
Already shimmed the carb needles? Although it may not be required, shimming wouldn't hurt things one bit. It takes longer to go find and buy the washers than to do the mod. It's 100% reversible as well.
August 27th, 2013, 07:55 AM | #14 | |
But you don't think that will be required to go straight to a 300 canister? I know it just bolts on though I didn't know the bracket didn't line up.
August 27th, 2013, 07:59 AM | #15 |
Nope, I don't think it will be required. Just a "what feels good thing".
August 27th, 2013, 08:42 AM | #16 |
Awesome, thanks.
August 27th, 2013, 08:43 AM | #17 |
Big Dreams, Small Wallet
Join Date: Feb 2013 Motorcycle(s): 08 Ninja 250R (Sold), 93 VFR750F (In Pieces) Posts: 508
As said, you don't "have" to do it, but once you do, you'll likely be glad you did.
Chris is totally right about the effort required to shim the needles. You aren't opening anything more than 2 covers over the carbs, so it's not like you are swap in a taller 3rd gear.
~BRad |
August 27th, 2013, 09:02 AM | #18 | |
I've skimmed the DIYs before just to get an idea of what everyone else was talking about, but still too advanced reading for me. Maybe one day, down the road, when I feel like it, maybe... I was mostly checking to see if I could get the 300 canister and not be required to adjust anything since its a stock pipe. I read on other exhausts more work is involved so didn't want to go through that.
August 27th, 2013, 09:05 AM | #19 |
I think you just need someone to walk you through it hands-on first. Don't think of it as scary engine-work, so much as "remove this bolt, remove this bolt, remove this cover... replace this cover, replace this bolt, replace this bolt".
~BRad |
August 27th, 2013, 09:23 AM | #20 |
YES, I would totally go for that!! Wanna come over? I can get pizza and cookies and beverage of your choice.
August 27th, 2013, 09:33 AM | #21 |
Memphis to Nevada... Those better be some bad@$$ cookies!
~BRad |
Pregen stock mufflers (or just the baffles for them) | 2weelz | Items Wanted | 6 | June 7th, 2014 10:39 AM |
Prejen Stock Chrome Mufflers | Kruse08 | Items Wanted | 2 | June 6th, 2014 09:16 AM |
WTS...Stock '06 header/mufflers & stock pair of red rear pod lens | Ninja Nut | Motorcycle-related | 6 | October 21st, 2012 01:36 PM |
