September 25th, 2017, 11:14 AM | #1 |
Join Date: Sep 2017 Motorcycle(s): 2010 Kawasaki Ninja 250R, 99' Suzuki Katana 600 (RIP) Posts: 95
Problem with Fuel and Air Hoses
Hi guys i have a 2009 ninja 250R, my problem is the next:
The bike only work when the petcock in "PRI" position, when i put in "ON", the bike dies because the fuel don't go to the carbs, i was watching a image, when shows what lines got the carbs, and my bike is not connected like the picture. Somebody can please help me if exist some picture or video to connect right the fuel and air hoses, because i read if my bike still running on "PRI" the carbs could be damaged Also my bike is the US Version, not the california version. Last futzed with by Darksik; September 25th, 2017 at 03:04 PM. |
September 25th, 2017, 11:23 AM | #2 | |
Hi and welcome!
1. First, test petcock for proper operation. Set to ON position and it should NOT flow any fuel. Apply vacuum of at least 10-in.Hg to vacuum nipple. Does fuel flow out of petcock? If not, R&R petcock as necessary 2. next if petcock confirmed operational, make sure hose labeled "vacuum hose to petcock" is intact with no cracks or leaks. Verify it's actually connected to petcock and clamped securely on both ends. If this doesn't work, use vacuum-T and measure vacuum in that hose. Should be at least 10-in.Hg at idle to keep petcock open and flowing fuel. 3. if you don't have sufficient vacuum in hose labeled "vacuum hose to petcock" to keep petcock open, then you've got leak in carbs. Verify all hoses are connected as shown in picture. I think the only difference with non-CA model is you don't have the plastic T in the middle of that hose section. Fast and efficient low-cost troubleshooting requires measuring and coming up with numerical data. Those numbers will help track down problem area so you can R&R just the bad part. All used parts should be tested and measured. Otherwise, you can just swap out petcock, vacuum hoses and carbs for brand-new units from dealer and problem should be fixed. |
September 25th, 2017, 03:21 PM | #3 | |
The petcock don't leak any fuel outside the petcock, when i put the petcock in "ON" the gas stoped to flow the fuel, also does not flow while the motorcycle is turned on, The only hose that is connected like the picture is the "Fuel Inlet line From Petcock" The vaccum from the petcock is connected to the T but the T is onlu connected to the Coasting Enricher from the right side. Also one hose is connected to the "Carb Sync adjuster screw" That is the level of my hoses problems |
September 25th, 2017, 03:47 PM | #4 | |||
Here's what you do: 1. test petcock for functionality, replace if not functional 2. remove ALL hoses, both ends of each 3. inspect ALL hoses for cracks & tears, replace if bad 4. reconnect ALL hoses according to diagram. One at a time, do one end, then other, clamp both ends. Then do next hose, one end, then other, until ALL hoses are routed according to diagram. Do you have long hose that connects to California Emissions Fitting T that runs to front of engine? Do you have a round vacuum valve hanging from frame between spark-plug boots? |
September 25th, 2017, 09:42 PM | #5 |
"a legend in my own mind"
Join Date: May 2017 Motorcycle(s): 2015 moto guzzi norge,2020 aprilia dorsoduro, 2014 yamaha fjr, 85 yamaha fj 1100 Posts: A lot.
MOTM - Feb '18
"trying not to get old" |
September 25th, 2017, 11:52 PM | #6 | |
2. if i got time, and be sure how are connected the hoses, tomorrow i can do that. 3. I already checked and the hoses are good, they don't have cracks. 4. Now i remember, the vacuum hose from the petcock is more narrow than the vacuum hose from the carbs. :/ maybe could work if i put a hose clamp using the vacuum hose from the carb Yes i have the long hose and the T, but i think one is connected to the right coaster enricher (as how shows the picture), another is connected to the vacuum from the petcock, and another is connected to the vacuum switch valve Yes the vacuum valve is there hanging. |
September 26th, 2017, 01:16 AM | #7 |
This is only 1/2 test. The other test is to make petcock flow in ON position. Apply vacuum to smaller port on petcock and fuel MUST flow in ON position. If it does not, petcock is bad. Replace petcock with new working unit.
September 26th, 2017, 03:23 PM | #8 |
The fuel must flow even when the bike still off?
September 26th, 2017, 03:49 PM | #9 |
Yes, we are testing only the petcock. It must flow when vacuum is applied to smaller port. You can use hand-held vacuum pump to create vacuum. Petcock should flow. If not, it is bad.
Right now, we don't know if problem is due to bad petcock or bad hoses. Need to test one at a time. |
September 26th, 2017, 09:48 PM | #10 | |
September 27th, 2017, 01:17 AM | #11 |
September 27th, 2017, 05:07 AM | #12 |
one o' these will suffice
Custom Carb Service |
DIY- Removing the Kleen Air System Hoses and Plugging the Holes on a 08 250R | kkim | 2008 - 2012 Ninja 250R Tech Talk | 152 | March 15th, 2019 07:37 PM |
Fuel Overflow Problem | CWLESQ | 1986 - 2007 Ninja 250R Tech Talk | 11 | September 26th, 2013 05:39 AM |
[RoadRUNNER] - Bazzaz Z-Fi Fuel Control Unit and Air Fuel Mapping Kit | Ninjette Newsbot | Motorcycling News | 0 | June 3rd, 2013 11:10 AM |
Fuel tank hoses ca model... | sixer | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 2nd, 2010 05:20 PM |
08 fuel cut out problem | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 21 | February 23rd, 2010 09:48 AM |
